If you are running windows XP, you can automatically switch into 640x480 when an app launches, and then back to your original desktop res after it exits.
Just right click on the .exe, select properties
then the compatibility tab
then check the "run in 640x480" screen resolution.
That is, assuming 640x480 is the resolution you want to run in :-)
