Go Back   MP3Car.com > Mp3Car Technical > Software & Software Development
Old 06-13-2003, 03:42 AM   #1
e1fnd's Avatar
Anyone knows how can I convert the mileage to digital values?
Hi... I am a newbie here... I have been refering to your forums and examples for the past 8 months.... Just a quick question... I am in the midst of developing a mileage calculator software... A few ideas I have... but none would be 100% accurate but mere estimation..... Is there a method where i can grab the values of the car's mileage to the carputer?
Hope anyone has any idea ...
e1fnd is offline   Reply With Quote
Old 06-13-2003, 03:50 AM   #2
Are you interfacing to the ECU?
chiark is offline   Reply With Quote
Old 06-13-2003, 03:53 AM   #3
e1fnd's Avatar
That's what I heard ... need to interface the ECU... but I have no idea on the schematics and converting it to digital.... Is there a way u could recommend?
Old 06-13-2003, 04:00 AM   #4
I'd start off by seeing if anyone else has done the same - have a good google.
If that fails, see if your car has a standard OBDII interface as that might greatly simplify things by defining standards etc.
If your car was an Impreza, either I or a friend could give you guidance, but as it isn't then I'm sort of stabbing in the dark.
FWIW, I'm going to interface to my ECU through a serial port connected to the car's OBDII connector using a Max232 chip to convert TTL to RS232 levels. The hardware is simple, it's the interrogation of the ECU that will be fun.
Or you could put a webcam pointing at your odometer, then OCR the resulting picture
Cheers,
Nick.
Old 06-13-2003, 06:13 AM   #5
C4M
C4M's Avatar
Do you have a GPS? This is how mine calculates distance travelled (although I didn't write the code, so don't ask me *how* it works!)
C!
http://carpc.riposte.net
I reserve all rights in connection to each post I author, without exception.
C4M is offline   Reply With Quote
Old 06-13-2003, 07:14 AM   #6
Registered User
aoLhaTer's Avatar
Quote:
lol
i like that one
aoLhaTer is offline   Reply With Quote
Old 06-14-2003, 01:32 AM   #7
go find a vehicle speed sensor off a older ford or otehr fuel injected beastie and a analog to digtal converter and use a rs 232 converter to run it into a comm port
i have some info on making a stand alone digispeedo but i don't think it would be too hard to adapt to computer .. but what do i know i just think up stuff i can't code to save my life
WINNER!!!!
run-on sentance comp 2002!!
oddcomp is offline   Reply With Quote
Old 06-14-2003, 11:27 AM   #8
GTC
Might want to check out Vetronix.com (I think that's the spelling). They provided and ODBII interface called the "CarPort" with usb or com port interface (can't remember which) that connected to the Clarion AutoPC (Windows CE Radio), which was based on standard i/o ....
I don't know that they sell the device anymore, but you can sometimes pick them up on eBay, and they may have information on their website ...
GTC
GTC is offline   Reply With Quote
Old 06-14-2003, 03:51 PM   #9
OOh.. be careful. Any commercial hardware for interfacing with the computer will be severely protected from doing any damage to the ECU. Just because the scanner port is there doesn't mean you should be randomly hooking up your carputer to it. A glitch to the wrong pin could kill the computer. We've lost enough ECUs just trying to use them correctly at my local tuner shop, it would really suck to have it happen on the street instead of a track or garage.
Check back soon for the 7" Lilliput VGA USB Touchscreen for only $300! :D http://www.dscustoms.com
dscustoms is offline   Reply With Quote
Old 06-14-2003, 05:54 PM   #10
DodgeCummins's Avatar
I can't think of the name but...
You get a magnet, and a matching weight to put somewhere on the driveshaft, (or for you FWD cars on one of the axle shafts) then a simple reed relay (or other more sensitive sensor) closes every revolution.
Add up the revolutions, multiply by the distance traveled by the tire in one revolution...you have distance...
Not pretty but that is how the tachometer in my truck works...and the speedo on my bicycle.
current projects
DodgeCummins is offline   Reply With Quote
Old 06-14-2003, 06:32 PM   #11
GTC
I did some checking and the Vetronix unit has a USB interface, and as such should comply to the USB 1.1 standard (it's a few years older); since it was originally intended to hook up to the ODBII port and a small Windows CE computer, I wouldn't be overly worried frying anything ... There's no custom wiring involved (according to Vetronix, it's plug&play) unless you want to tap into door lock or window relays. I suspect the most involved part would be creating (or buying from Vetronix) the software compatible with standard Windows ...
GTC
Old 06-14-2003, 10:14 PM   #12
cproaudio's Avatar
GTC, why bother buying a WinCE OBD-II scanner and try to find win based software when you can get OBD-II scanner that's already windows based.
dscustoms, for OBD-II interface, There are 3 protocols VPW, ISO and PWM. When in doubt, get one that reads all 3 protocols and let the scanner auto detect. As for dianostic ports under the hood, those are propriatary. Each auto maker uses their own protocol. Those are the ones not to mess with unless you have the right scanner for them.
DodgeCummins, Or you can locate the VSS wire at the cruise control module. Or if you cant find it, you can goto the local cruise control installation center and ask them "hey which wire is the vehicle speed sensor wire for my 96 Dodge Ram 2500?"
He has a 99 Proton Pesona. It's new it's most likely fuel injected, There's gotta be a VSS wire somewhere going to the ECU. If it has ABS it definately has VSS wire.
BTW what do you mean by calculate the mileage? Do you mean calculate the vehicle speed as in how fast your going? or by actual "mileage" as in miles per gallon or in Malaysia kilometers per liter?
NEW complete and updated My project with 100+ pics on 7-4-03
If you have a Shuttle FV24 motherboard in perfect working condition for sale, please PM me.
cproaudio is offline   Reply With Quote
Old 06-14-2003, 11:59 PM   #13
GTC
cproaudio - I agree 100% with you - I was only aware of the WinCE scanner since I had worked with the system before (other periferals, not that specific device), so I suggested it as a starting point ! There's certainly no reason to try to hack something together if a different "working" product(s?) on the market.
Can you recommend a good brand of scanner, and where more details might be found? I have basically zero knowledge about scanners, though I've managed to install a piggy-back computer into my car (VAFC controller) without doing any damage (made a custom harness instead of splicing!).
Thanks,
GTC
Old 06-15-2003, 12:58 AM   #14
I'm sorry, and you are....?
frodobaggins's Avatar
Here is a good starting point
http://www.google.com/search?hl=en&i...=Google+Search
[H]4 Life
I'm a lesbian too.
I am for hire!
frodobaggins is offline   Reply With Quote
Old 06-15-2003, 10:22 PM   #15
e1fnd's Avatar
hahaha good one frodobaggins.... What I meant was on how can I take the miles that has been traveled by my car.... This is funny , good one... hahhaa: Or you could put a webcam pointing at your odometer, then OCR the resulting picture ... Just wanted to make use of carputer so it will calculate the distance travel... Anyhow... the suggestions that all of you made, is it already in your car? Or has it been tested out?
