Go Back   MP3Car.com > Mp3Car Technical > Software & Software Development
Old 12-14-2003, 04:24 AM   #16
Registered User
Quote: Originally Posted by mst
andrea has a (new?)microphone with noice cancelling software for $35:
http://www.andreaelectronics.com/Buy...beam_Array.htm
I have bought it but not tried nor install it;at least it is cheaper then their $300 car microphone!
only works if you have their special sound card/chip. Theres an audio test on the page to see if you can use it on your system.
Alphared is offline   Reply With Quote
Old 12-14-2003, 05:34 AM   #17
mst
mst's Avatar
oups,I had not understood that,sorry,me bad
Back to the drawingboard
mst is offline   Reply With Quote
Old 12-14-2003, 09:19 AM   #18
Seraph's Avatar
andrea does make microphones for AutoPC. So I assume they have other choices too.
- Lwin M. Maung
If it's stuck, force it. If it breaks it needed replacing anyway
Seraph is offline   Reply With Quote
Old 12-14-2003, 08:12 PM   #19
Registered User
yup, but it's custom setup. I've email them about the car setup mics and they said that it was custom for each customer. Figure its gonna be pretty expensive.
Old 12-16-2003, 02:58 AM   #20
deadweasel's Avatar
You know, Dragon is a very slick piece of software, but only if you are willing to give your system your undivided attention for a little while. I got myself quite an image with my friends when they came over while I was training SASAMI. They started freaking out and trying to convince me to go out to a club or something, because apparently I had gone off the deep end, and was reading the ALECCS technical manual aloud to the machine.
I had quite a time convincing my (non-computer savvy) friends that I had to read text to the computer so that it would recognize my speech patterns. At first they scoffed at that, but when I started straightening my room while issuing commands to SASAMI to show me the weather and play some music, they quickly changed their tune. Didn't stop them from giving me hell in public though.
In any case, like I said, Dragon is sweet, but it takes too long to train (IMO), and it's a little too picky about the ambient noise in relation to the levels at which it was trained to begin with. Yes, an expensive mic could fix that, but as far as I'm concerned, that's not really worth it. Repeating the command just one time negates any real value to voice control, I think. I will use voice command for times when the car is silent (disable/enable security, diagnose engine computer problems etc).
So in the end, I will save my mic for the integrated cellphone (hopefully), and rely on the touchscreen to do all of the integral control.
The ALEXIS Project
MP3---VIDEO---GPS---REARVIEW---OBD---SKINNING
Color Coding :
DONE / MOSTLY DONE / BASE FEATURES / WORKING CONCEPT / NO CODE COMPLETED
deadweasel is offline   Reply With Quote
Old 04-15-2004, 10:03 AM   #21
Not necessarily true, they do have the USBD-2A adaptor that allows the hook up of the array to any USB port; the bundle of the Sunbeam array mic and the USB adaptor is still only around $90.
SoFlaLude is offline   Reply With Quote
Old 11-20-2005, 05:54 PM   #22
My solution
I got around the ambient background noise problem by using a throat mic (yes you yave to wear it, but it's small) that plugs in... http://www.basspro.com/servlet/catal...rTarget=browse
It cost $30 which is a lot cheaper than a good noise canceling mic. Needed a $4 adapter from mini to standard plug and a $3 airplane adapter to seperate mic and earbud, but it works great.
smkaplan is offline   Reply With Quote
Old 11-21-2005, 01:23 AM   #23
My Village Called
0l33l's Avatar
I got my noise canceling mic for $20. And that's expensive because there are some for around $10.
PowerVoice v1 | NaviVoice Source
GammaControl v2.4
SKINbedder v3
1995 Lexus SC300 <-- Weekend Car
1997 Mazda Miata <-- Daily Driver
0l33l is offline   Reply With Quote
