Quote: Originally Posted by wi77iam
Cool. How does it look at 800x600? Can it stretch to fill a 7 in screen? I just got a Kworld to replace my Dlink for FM, but neither one had large enough interface to work with touchscreen.
With a good antenna, it seems to be ok, but I haven't had the chance to put it in the car yet.
At 800x600, it's ok, the button hotspots are bigger than they look on my skin. I would recommend you set presets (9), and use them instead of tuning up and down (takes forever, does it in .05mhz increments, blah)
However, on the widescreen 800x600, its a little squashed. It would look best at 800x480ish, but my savage IX/MX vidchipeset doesn't support custom resolutions
. At 800 wide, it takes about 75% of the width of the screen. I want to use external buttons for a lot of things anyway, so I'm not too worried about the touchscreen usability.
There aren't that many hotkeys available for all the functions. Here is a list of what's available.
MpegTV-Station provides a set of hot keys for your convince. The function of each key is as following:
Arrow Keys:
Up and Down:
In TV mode, they are used for channel up and channel down.
In FM mode, they are used for Scan Up and Scan Down.
Left and Right: Volume Adjustment.
Numeric Keys: Used for Channel Selection.
Function Keys:
F1: Pop up this Online Help.
F2: TV/FM mode switch.
F3: Mute/Un-Mute mode switch.
F4: Still Image Capture.
Come to think of it, that's probably adequate for external buttons to work well with it. We will see.
