03-23-2004, 11:21 AM
#31
Vehicle: 2000 BMW M Roadster
I tested it on my machine at my desk and ended up getting -12.28 volts out of three of the wires coming out of the DB9 port. if the computer was on, without windows loaded it still had power. Not working yet....any ideas?
Stop Buying New Music CD's.
Hit The RIAA where it lives.
Indash Motorized 7", Epia Nehimiah, 512 MB, 80 GB, DVD, Wireless G, XP Pro, XM PCR, Kenwwod 5 Channel 1200 Watt Amp.
03-24-2004, 01:29 AM
#32
Vehicle: 1992 Mazda 323 Sedan
That's weird.. I'm also using the Nehimiah board.. It puts out like 12.2v.. :/
03-24-2004, 05:51 AM
#33
I haven't tried it on the machine in the car yet....We'll see about that this weekend, but it's a fence building weekend, so probably not.
03-24-2004, 02:40 PM
#34
Vehicle: 2003 Pointac Sunfire
So how did you build this cable? Can i take a serial cable that i might have kicking around and cut one end off...then which wire goes to the amp? Can this work for 2 amps off the same serial port? tnx
03-24-2004, 02:50 PM
#35
Raw Wave
Vehicle: '97 Vauxhall Corsa 1.5 TD
DTR
Yes, provided you want them both to switch on at the same time. Tie the remote switch on lines together and to DTR (preferably through an NPN transistor as above - emitter-follower should work just fine).
6yr old first install died 20/8/2005 as result of bad bios flash.
New system : 6x5x2" contains 1GHz C3 PCM9373, ISR based PSU, 512Mb flash DOM, 8Gb CF HDD, 98Lite, DirectShow based frontend.
GPS : Rikaline 6010.
Display : LTM08C351 + LVDS receiver.
03-24-2004, 03:00 PM
#36
Ok...i'm trying to follow you here...so i need a "DTR" cable? is that correct?  tnx
03-24-2004, 03:04 PM
#37
Raw Wave
Err, nope. DTR is one of the pins on the serial port. Stands for Data Terminal Ready. Search for stuff on serial ports. It will tell you all about it, and what pin it is.
03-24-2004, 03:22 PM
#38
perfect  thanks bud
Also I'm using my only serial port for my ir remote...would this work off a usb to serial adaptor or something like that?
tnx
03-24-2004, 03:53 PM
#39
You guys ever solve this one? So are you saying the Visa M10K puts a constant 12V out through the DTR as soon as power is supplied?
03-24-2004, 04:12 PM
#40
nope, i tried this on my desktop at work and got the above mentioned results...I haven't tried this on my carpc yet.
03-25-2004, 02:40 AM
#41
Vehicle: 2003 Toyota WISH 1.8VVT-i
I have tested and get a negative voltage when AmpCtrl service is turn off.
MediaCar
Girder with Igor plugin
EPIA-ME6000 w 256MB DDR
Morex 55W PSU
12VDC Regulator
IBM DJSA-220 20GB
90% completed in a plastic case (8"x10"x2.5")
04-02-2004, 11:09 AM
#42
Vehicle: Mercedes and Chrysler
Can't install the program....
 Not sure what the issue is here. I installed the .NET framework stuff and used installutil.exe to install ampctrl.exe. The install fails telling me about a win32 exception error and something about the username and or password is wrong. I'm installing using the administrator account so I'm not sure what up.
Can anyone help me?
05-02-2004, 03:31 PM
#43
Would it be possible to do this with the parrallel port as well? I already have both of my serial ports being used by the gps and touchscreen. I want to be able to turn the amp on post startup, since when I get the thump by amp will sometimes put itself into protect mode and I will have to power cycle the amp to get it up again.
05-14-2004, 07:23 AM
#44
Vehicle: Alero
Can anyone help me?
This is what happens to me to!!! Not on my home PC (WinXP) just my carPC (Win 2000). Anyone found a solution to this?
05-14-2004, 10:22 AM
#45
Vehicle: 1999 Chevy Venture
Yes it should be and you then have a whole bunch of extra lines to play with.
A small bit of programming should allow a user customizable interface that allowed individual pins to be 'switched' and as long as they were buffered with a bunch of transistors on a bit of breadboard you could build a really nice bit of kit. It could control the LCD touchscreen, remote amplifier, neons, spinning disco ball (lol) etc and you could also use a scripting language to control all of the functions with timers or event triggers.
A bit of C+ programming should do it.
Steve
RV : Samsung Q1 + Kyocera KR1 (EVDO) + GPS<br>
Car: AMD 3000+ Book PC + Lilliput 8" Touch + 13" TFT
Webmaster for the European Ford Scorpio Site
| Thread Tools |
| Display Modes |
Linear Mode
