06-23-2004, 02:57 AM
#46
Vehicle: Alero
Possible to do this for the LPT port instead of the com-port?
I will have a OBDII reader on the com-port
06-23-2004, 10:20 AM
#47
Raw Wave
Vehicle: 2004 Toyota 4Runner
Yes, but you can also just buy a USB->Serial adapter for ~$15.
06-23-2004, 02:23 PM
#48
Vehicle: Alero
Yeah I now about them, but I have ALOT of usb devices already. So if a lpt is possible that would be the best
07-22-2004, 01:36 PM
#49
Vehicle: Pearl White 1998 3000GT SL
anyone still have this? the link doesnt work
07-23-2004, 03:38 AM
#50
Vehicle: 2002 Ford XR6T
yeah id like it too. anyone got it that can host it agian???
06-03-2005, 04:39 PM
#51
Vehicle: Seat Leon
I just don't get it. That's because it's not my thing.
I do have similar problems (huge!) when I startup my pc.
So I made an extra switch to power my amps after windows is started. Using a wire of the com port is to hard for me.
I was looking @ conrad and found this. Is it possible to use it:
Delayed On/Off Switch
Article No.: 195901 - I5
When I connect it to my iggnition wire and set it to 150 sec. the pc is already half way. 300~500 sec. would be even better..
Maybe this one is even better??
please help me (us) out here!
02-12-2006, 11:40 AM
#52
Vehicle: 2005 Ford Mustang GT
Here is the file everyone wanted. I attached it so it stays forever and I uploaded it to my webspace so those that don't login can still grab the file.
AmpCtrl_1.0.zip
Happy AmpCTRL'n
02-13-2006, 06:44 AM
#53
Vehicle: 2006 Ford XR6 Turbo Ute
this is a nice little app.. only thing i cant figure out is what pin do i connect it to in the serial port??
03-03-2006, 05:03 AM
#54
i tried this one out..
it switches the port but.. my amp wont turn on with the 6v it puts out
im gona have to use the 2n2222 trasistor
but it works nice.. thanks
03-03-2006, 06:56 AM
#55
Vehicle: 1998 VW Golf (MKIV) 1.6SE
another vote for a parallel solution here!
i've got no idea about programming so i can't do it myself but it would be really useful for people that
a)use their serial ports for ODBII or things like Cliffnet Wizard (myself included)
and/or
b)are lacking in free usb ports
03-03-2006, 08:04 AM
#56
Vehicle: 2000 BMW 328Ci (E46)
Interested if anyone is using this via usb-serial converter, and have they had any problems in general with using this service?
03-03-2006, 10:37 AM
#57
Vehicle: 2006 Ford Mondeo Diesel
This may be usefull, it can raise pins on the LPT port from command line.
03-03-2006, 10:46 AM
#58
so use a relay... Thats what I did but my amps turned on with out it I just thought it would be a better idea that way.
Wire it so when the the trigger from the amp ctrl engages it allows the normally closed part on the relay to connect the accessory wire to the amps.
This will do a couple of things for you. If your amp needs higher powered turn on then this will cover that. Windows will boot before any sounds get played but you won't miss any sounds becuase the service is started first. When you turn your key off it will stop playing music but if your car is like mine it doesn't stop until the door opens then it kills the accessory wire. That is one way to do it you could also wire the normally closed with a always connected 12v wire.
This service is the best way to control your amps.
03-03-2006, 11:18 AM
#59
Vehicle: 2004 Acura TL 6MT
Quote: Originally Posted by MikeH
Another interesting use would be to signal an intelligent power supply that it is now OK to shut down power. My ITPS will shut down power in the middle of bootup if I turn on the engine, then back off within the boot period (approx 60 sec). This happens when I move my car from outside to the garage....very short trip.
Mike, you got a solution for this? I'd love to not have to sit there and wait when I move my car a short distance.
CarPC #3: 99% CompletePentium M 1.7Ghz, 1GB DDR2 RAM
DVD/CD-RW installed in dash below monitor
OEM LCD relocated for 7" Touchscreen
Wi-Fi, GPS, PS2 controllers...
500+ full albums
4,000+ video games
music videos, movies, & more! old carPC
03-03-2006, 11:45 AM
#60
Vehicle: 99 Trans Am
I'm not sure I remember this thread so well, but I'll jump in here.
You could wire in a NC momentary switch inline from the PSU trigger to the mobo. Just push the button when you crank the car and the signal will not get sent to the mobo. Would that fix your problem?
| Thread Tools |
| Display Modes |
Linear Mode
