The MP3car.com Store
Go Back   MP3Car.com > Mp3Car Technical > Software & Software Development
Thread Tools Display Modes
Old 03-13-2006, 11:20 PM   #76
djmickyg's Avatar
Vehicle: 2006 Ford XR6 Turbo Ute
My Photos: (3)
Quote: Originally Posted by Hark
Wow, this worked great for me - I'm using a usb-serial converter, with the DTR wire triggering my amp. Finally I have a way to power the amp without EVER hearing thump - standby, hibernate, full-shutdown. Thanks a lot DaTeach!
did u connect it straight to the amp from pin 4??
djmickyg is offline   Reply With Quote
Sponsored Links
Old 03-14-2006, 01:23 AM   #77
mbkowns's Avatar
Vehicle: 2005 Ford Mustang GT
My Photos: (0)
I can say I hooked up the serial cable right up to the amp remote line and it works. I have changed it though and I have it now so it goes through a relay. That if the the Accessory is on then it jumps the relay to enable DTR from the serial port to go to the amps but if the accessory is off it cuts that.
DTR will ditch the startup speaker pop by itself but I was also having a turn off speaker pop so that fixed that and its perfect now.
2005 Ford Mustang GT <- - - UPDATED PICTURES
2003 KAWASAKI Z1000 - CUSTOM MODZ
MBK (AIM = IllMBKllI)
mbkowns is offline   Reply With Quote
Old 03-14-2006, 01:28 AM   #78
djmickyg's Avatar
My Photos: (3)
dam why wouldnt it work for me directly in
i was only geting 6V out the dtr line.. grr
doesnt mater i dont have the car anymore so nowhere to put the pc
Old 03-14-2006, 01:55 AM   #79
mbkowns's Avatar
My Photos: (0)
Some amps can't handle the lower voltage maybe yours had a problem or maybe you shorted it slightly. Your problem would of been easily fixed with a relay that was triggered by the DTR and kicked on 12v from the accessory to the amp.
Old 03-24-2006, 01:53 PM   #80
My Photos: (0)
Testing DTR circuit...is this correct?
I'm testing this on my laptop to make sure it works before I tear into my car stereo wiring. Can somebody confirm that how I'm testing it and what I'm seeing in my testing is correct?
I installed the AmpCtrl.exe service and configured it to work on port 3...my USB port. I plugged this USB-Serial converter into my USB port. When I turn on the computer, I connect my multimeter to pins 4 and 5 of the male-terminated serial cable like this:
The multimeter shows a constant 9.06V. Just before the Windows boot screen appears, it swings between -1V and -4V for a second or two...then back to a constant 9.06V. Is this about what I should expect?
For sale:
AOpen Pandora MiniPC
Quack is offline   Reply With Quote
Sponsored Links
Old 03-24-2006, 04:38 PM   #81
My Photos: (0)
well mine gave me -11.98 before the service started then 11.98 when it turned on but thats on my atx mobo and it turns my amp on perfectly connected directly to pin 4 so i think only way your gonna tell is if you hook your amp up and see if it turns it on. may be a problem if your just getting 9 and ur amp needs 12v remote on?
bigbun is offline   Reply With Quote
Old 03-25-2006, 04:31 PM   #82
Hark's Avatar
Vehicle: 2000 BMW 328Ci (E46)
My Photos: (0)
I thought you were supposed to use pins 4 & 7 when measuring voltage - maybe it doesn't matter if it's 7 or 5? I got 12V on my Thinkpad T30.
Hark is offline   Reply With Quote
Old 03-26-2006, 05:58 PM   #83
checksum's Avatar
Vehicle: 05/Nissan/Altima
My Photos: (1)
Most power supply I have seen here have a RMT pin, which is used for powering the amp. Wouldn't it be better and just easier to hook it up to that pin?
Just Starting my project
checksum is offline   Reply With Quote
Old 03-26-2006, 06:05 PM   #84
My Photos: (0)
Some installs have electrical noise or thumps while powering up the computer. Using the remote turn-on lead of the PSU powers up the amp when the ignition is turned giving this noise a chance to be heard. Turning on the amp after Windows has started will eliminate this noise. There are other ways to turn on the amp later in the power-up cycle like using a delay switch. Personally, if DTR works like I expect, I prefer it over a delay switch because it will be more precise about turning on the amp at the right time after Windows is booted.
For sale:
Old 09-23-2006, 12:04 AM   #85
Vehicle: 1994 Honda Accord LX
My Photos: (0)
does anyone have a update on this program? Or is it done with
HitmanZ is offline   Reply With Quote
Old 09-23-2006, 10:51 AM   #86
mbkowns's Avatar
My Photos: (0)
no need for a update it runs like it should if you can't download it from the links check my car thread i have a link there.
Old 11-13-2006, 10:44 PM   #87
Banned
My Photos: (0)
Can someone please post up the DB9 pinout including each wire color and its corresponding pins?
salvi is offline   Reply With Quote
Old 11-14-2006, 02:35 PM   #88
My Photos: (0)
I was thinking I would just write some code to turn the volume down, kind of like a good home stereo will do when it's powered off. That way if I get out of the car with the vol up high, when I go to leave for work at 6am I don't wake everyone up
mplex2000 is offline   Reply With Quote
Old 11-21-2006, 10:45 AM   #89
My Photos: (0)
confused
Old 11-21-2006, 06:53 PM   #90
Banned
My Photos: (0)
Go with the DTR method, works perfect.
Sponsored Links
vB code is On
Trackbacks are Off
Sponsored Links
SEO by vBSEO 3.1.0
Ad Management by RedTyger
