The MP3car.com Store
Go Back   MP3Car.com > Mp3Car Technical > Software & Software Development
Thread Tools Display Modes
Old 12-14-2006, 06:48 AM   #91
My Photos: (0)
da_teach, i'm doing a system for my Cabriolet and i need your sourcecode, because i'm doing an interface for activate when i would. It's possible that you give me your sourcecode?
Renault Megane Coupé Cabriolet
P3 550 mhz 256 mb RAM 15 gb hd, dvd.
gps handsfree parrot ck3300
windows xp sp2
road runner
map monkey and viamichelin mapsonic
Touchscreen 7" fully motorized in-dash
xuri is offline   Reply With Quote
Sponsored Links
Old 12-14-2006, 12:01 PM   #92
Vehicle: 1994 Honda Accord LX
My Photos: (0)
Da_teach hasn't been on for the longest time, i doubt you could find him
HitmanZ is offline   Reply With Quote
Old 12-14-2006, 07:30 PM   #93
My Photos: (0)
having some trouble installing...
Alright guys im feeling a little dumb here but today i tried installing this service and i could not get it to work. I run the InstallUtil.exe and it opens up for about 2 secs then closes before i can enter anything. I know im probably going about this all wrong so if someone could clear this up for me id appreciate it tia.
fuguaa is offline   Reply With Quote
Old 12-15-2006, 01:55 AM   #94
My Photos: (0)
actually i start and stop the service.
Fuguaa it's because you have not configured the config file. Try tu change the com port
windows xp sp2
road runner
Old 12-15-2006, 02:18 PM   #95
Thann's CarPC Specs
Thann's Avatar
Vehicle: 2004 Nissan Murano SL AWD
My Photos: (0)
Quote: Originally Posted by mbkowns View Post
I can say I hooked up the serial cable right up to the amp remote line and it works. I have changed it though and I have it now so it goes through a relay. That if the the Accessory is on then it jumps the relay to enable DTR from the serial port to go to the amps but if the accessory is off it cuts that.
DTR will ditch the startup speaker pop by itself but I was also having a turn off speaker pop so that fixed that and its perfect now.
mbk - this is exactly what I need to do for my system. I was already using a relay because I need to turn on two amps at startup. What are the specs on the relay you're using (such as amperages, etc.)?
Ride: 2004 Nissan Murano SL AWD/Sheer Silver/Black Leather/factory HIDs.
MoPuter: Transflectivized Lilli 7", EPIA M-10000, 512Mb RAM, 160Gb WD, SBLive!, 54g WLAN, Holux GM-213, 160W M2-ATX PSU
Thann is offline   Reply With Quote
Old 01-28-2007, 07:59 AM   #96
Mañana's CarPC Specs
Mañana's Avatar
Vehicle: 98' VW Passat
My Photos: (0)
To all that didnt get this to work, make sure you dont have any "spaces" in your filepath (ie, dont place it on the desktop as it is in c:\documents and settings\...).
I moved it to c:\ampctrl and suddenly, it worked... (You must reinstall the program at the new location afaik)
My carputer
Old one
Mañana is offline   Reply With Quote
Old 02-16-2007, 07:15 PM   #97
keygen's CarPC Specs
My Photos: (0)
hi what is DTR?
keygen is offline   Reply With Quote
Old 02-17-2007, 04:50 AM   #98
Raw Wave
Rob Withey's CarPC Specs
Rob Withey's Avatar
Vehicle: '97 Vauxhall Corsa 1.5 TD
My Photos: (0)
Quote: Originally Posted by keygen View Post
hi what is DTR?
http://en.wikipedia.org/wiki/RS232
6yr old first install died 20/8/2005 as result of bad bios flash.
New system : 6x5x2" contains 1GHz C3 PCM9373, ISR based PSU, 512Mb flash DOM, 8Gb CF HDD, 98Lite, DirectShow based frontend.
GPS : Rikaline 6010.
Display : LTM08C351 + LVDS receiver.
Rob Withey is offline   Reply With Quote
Old 04-05-2007, 03:11 PM   #99
crooper's CarPC Specs
crooper's Avatar
My Photos: (0)
I know this is an old thread, but I'm trying to get it to work so I don't have to listen to my hard drive spool up.
The ampctrl service works great, DTR voltage swings -11.2v to +11.2v from off to on, and the signal will switch on ONE of my 3 amps. I have an automotive relay switching +12v to my amp REM inputs -- works great but DTR can't power it. I tried an 800 mA NPN transistor to switch the relay but it doesn't work. I measured the resistance across the emitter/collector as well as the output voltage with the service on and off and they don't change.
Does anybody have this kind of setup (with the transistor) or just a good explanation sans electronics skematics? I'm not an EE, they make no sense to me.
crooper is offline   Reply With Quote
Old 04-10-2007, 12:14 AM   #100
rcubed3r's CarPC Specs
rcubed3r's Avatar
Vehicle: 2005 Pontiac GTO
My Photos: (0)
I am having trouble getting this installed.
Can someone step me thru it?
Thanx,
Ron
rcubed3r is offline   Reply With Quote
Sponsored Links
Old 05-03-2007, 09:07 PM   #101
Banned
My Photos: (0)
If anyone needs helps with this, send me a PM. I've done it many times and it's pretty simple.
salvi is offline   Reply With Quote
Old 05-17-2007, 01:57 AM   #102
Griff1's CarPC Specs
Griff1's Avatar
Vehicle: 2001/Vauxhall/Zafira 1.8 16v
My Photos: (4)
Salvi,you've got a Pm.
Is there anyone else who can help me get this working?
When i run InstallUtil it closes instantly so i can't enter the command line.....
I spent 9 hours on this yesterday and got nowhere,i'm totally stumped.
P4 2.8 HT, 1GB Ram, 200Gb 3.5 HD, M4-ATX,2 x Silabs USB, SB Audigy2, BU353, Lilliput TS,Soundgraph Imon VFD,SONY Optiarc dvd Burner,RoadRunner, iGo8,Custom Freedom 2.1
Griff1 is offline   Reply With Quote
Old 05-17-2007, 09:51 AM   #103
Griff1's Avatar
My Photos: (4)
To anyone creating software......
If your gonna post your work don't assume that the bits you leave out of the instructions are irrelevant.............DOS...........that went out with the Ark but it's assumed i will understand how to navigate to a given folder in that poxy black screen........and all you put is "when you get to that folder type this" well thats a great help.
Old 05-17-2007, 10:00 AM   #104
Nerd2's CarPC Specs
Nerd2's Avatar
Vehicle: Ford Mondeo 96
My Photos: (0)
Why don't you try googling "How to navigate using the Command Prompt" or something similar to solve your problem?
A manual can be infinitely detailed. You've got to stop somewhere.
Nerd2 is offline   Reply With Quote
Old 05-17-2007, 10:10 AM   #105
Griff1's Avatar
My Photos: (4)
I'm not lazy,I did google for it but it didn't return anything i can understand.
Never mind, i give up,stuff it.
Sponsored Links
vB code is On
Trackbacks are Off
Sponsored Links
SEO by vBSEO 3.1.0
Ad Management by RedTyger
