Go Back   MP3Car.com > Mp3Car Technical Software > Software & Software Development
Old 12-31-2003, 08:11 PM   #1
Da_Teach is on a distinguished road
Cool Windows Service that raises DTR on powerup
I've written a small Windows Service that raises DTR on the com port of choice when the service is started... It will lower DTR when the computer goes into standby (probaby hibernate too, havent tested that) and it'll lower DTR when the service is stopped (which is also when your computer is shutdown, but before power is cut)...
Its written in Visual Basic.NET 2003, so it needs the .NET framework (v1.1) which can be downloaded via Windows Update...
You can download the service here:
http://www.wordtgek.nl/AmpCtrl_1.0.zip
To install the service you have to use InstallUtil which is present in the framework directory of .NET....
When your in the directory where you placed AmpCtrl, type the following:
C:\WINDOWS\Microsoft.NET\Framework\v1.1.4322\Insta llUtil.exe AmpCtrl.exe
(to uninstall : C:\WINDOWS\Microsoft.NET\Framework\v1.1.4322\Insta llUtil.exe -uninstall AmpCtrl.exe )
Modify the ampctrl.exe.config file and change the port number...
After that, the service should run next bootup...
The util is given as-is, dont blame me if something goes wrong... But it works like a charm for me (directly wired the DTR to my Amp)
Da_Teach is offline   Reply With Quote
Advertisement Sponsored links
Old 12-31-2003, 08:17 PM   #2
I'm sorry, and you are....?
frodobaggins's Avatar
frodobaggins will become famous soon enoughfrodobaggins will become famous soon enough
Interesting use.
[H]4 Life
I'm a lesbian too.
I am for hire!
frodobaggins is offline   Reply With Quote
Old 12-31-2003, 08:32 PM   #3
I saw people mention the 'DTR method' a few times when searching on how to eliminate the speaker thump... (when starting the car / carpc)
Seeing I'm a total 'hardware nono', this was still in my ability of things to do... Start timer would have worked too, but I have no clue on how to make those
Old 01-02-2004, 04:17 PM   #4
nottastocker's Avatar
nottastocker is on a distinguished road
i may seem stupid, but what exactly does it do?
Mozilla Search Plugin
nottastocker is offline   Reply With Quote
Old 01-08-2004, 03:17 AM   #5
burnout.no is on a distinguished road
Thanks, Da_Teach!
Excelent piece of work! Works like a charm..
Thanks again!
burnout.no is offline   Reply With Quote
Old 01-08-2004, 08:59 AM   #6
Custommx3's Avatar
Custommx3
And what exactly is it for?
what is DTR?
2007 Mazdaspeed 6
AMD X3 2.2 | M4-ATX | 16Gb SSD | 2GB DDR3-1333 | MSI GF615M-P33 MB
OBDPROS USB | BU-303 GPS l LILLIPUT TS | Car2PC adapter | XM Direct | USB Orinoco Gold
Custommx3 is offline   Reply With Quote
Old 01-08-2004, 09:54 AM   #7
what is DTR?
Atleast in my case, i use it for powering on the amplifier AFTER windows is ready.. It also turns my amplifier off before windows shuts down completely.. This way, i can avoid the start-up beep from my speakers.. Oh yeah, I also avoid the "bump"-sound from my speakers at shutdown..
It can ofcourse be used for something else than an amplifier.. DTR is the name of serial port pin no. 4 (Data Terminal Ready) .. You should find schematics on the web, if not - get back to me and i'll post one..
Good Luck!
Old 01-08-2004, 10:08 AM   #8
GingerPrince's Avatar
GingerPrince
You could also use it to power a relay to turn your neons on/off
GingerPrince
Car changed for TVR Griffith 500, so computer de-installed. Using a Dension 100ix w/60Gb HD unit in the interim.
Carputer Install - http://www.stuffandting.com/carputer/
CarBox Software -- http://www.stuffandting.com/carbox/
GingerPrince is offline   Reply With Quote
Old 01-08-2004, 10:41 AM   #9
MikeH is on a distinguished road
Another interesting use would be to signal an intelligent power supply that it is now OK to shut down power. My ITPS will shut down power in the middle of bootup if I turn on the engine, then back off within the boot period (approx 60 sec). This happens when I move my car from outside to the garage....very short trip.
MikeH
MikeH is offline   Reply With Quote
Old 01-09-2004, 04:08 AM   #10
But what about turning the monitor on? I'm not talking about feeding it 12V, but "pressing" the power button.. That would be cool!
Old 01-09-2004, 07:47 AM   #11
awh4992's Avatar
awh4992 is on a distinguished road
[QUOTE=GingerPrince]You could also use it to power a relay to turn your neons on/off [/QUOTE
that would hafta be a pretty small relay as the serial port DTR and RTS lines only supply ~10mA, which is barely enough to power a chip or 2, let alone an electromagnet in the relay. a better way would be to just use a transistor that can switch the amount of current ur neons use. the transistor only sucks nano to microamps through its base, so it's suited better for driving loads as opposed to sucking current from an output on the serial port chip. you would be using an npn transistor since the DTR pin is negative until the OS tells the serial chip to bring it to about +8 or +9v. a relatively simple circuit to build, providing you can get your hands on a transistor that won't blow up when u have ur neons connected directly to it.
awh4992 is offline   Reply With Quote
Old 01-09-2004, 05:11 PM   #12
numberone's Avatar
numberone
How do you connect your amp to the serial port?
My amp needs 12v to the remote input. Can I get this from the port?
http://www.m2visio.de
|CAR ENTERTAINMENT SYSTEM
|Epia m10000 w. 256mb
|20gb 2.5,slimDVD
|Morex Cubid 3688+ITPS
|Lilliput VGA+Touchscreen
numberone is offline   Reply With Quote
Old 01-09-2004, 07:47 PM   #13
crosseye's Avatar
crosseye is on a distinguished road
You can buffer the DTS line (or place two inverters back to back). The output of your buffer should then have enough current to power the relay.
crosseye is offline   Reply With Quote
Old 01-09-2004, 08:12 PM   #14
Twizted is on a distinguished road
Easy thing to do would prolly be use a general purpose transistor MPS2222 (prolly need something larger that can handel around an amp or two) for example to connect the 12v to a 12V Relay to turn on the neons... I would say you would need to so the same for the amplifier remote switch... I will have to look into this myself as I will need it.. If anyone can elaborate on my idea or share there design or idea please do
Here is a link to the
.NET Framework 1.1 Redistributable Package that Microsoft offers...
Last edited by Twizted; 01-09-2004 at 08:41 PM. Reason: Added link for .NET Framework 1.1
Twizted is offline   Reply With Quote
Old 01-11-2004, 07:06 AM   #15
After a bit of testing, I found out that directly wiring the DTR to the AMP works, but sometimes fails... So I'll have to put 'something' between the AMP and the serial port... So give easy idea's
Copyright ©2000 - 2010, Jelsoft Enterprises Ltd.
