Go Back   MP3Car.com > Mp3Car Technical > Software & Software Development
Old 01-16-2004, 05:46 PM   #1
Mastiff
A few observations in OS and why I'm now using Windows 2003...
My car system has undergone a major change the last week after a lot of experimenting. The main reason is ease of use and reliability. I have now a 100 % reliable setup in my house, with two computers running a multi-zone sound system and a home theater. Everything is so easy to use and so reliable that my eight year old son can use it. He still asks me before he uses the home theater, but one of these days I'm sure I'll find him down there watching Star Wars or Jurassic Park without us knowing it... It took two years before I got my wife to use the system regularly, mainly because the two first years I used one zone with Media Center (then Media Jukebox 8) and two zones with Winamp, probably the most unreliable piece of software I have ever seen! It has a very bad habit of changing what sound card it has playback on every time you change the default sound card (and my play list selecter system in Girder relies heavily on changing default sound card for each button pressed for audible feedback (you'll hear "one" in Norwegian when the system has sensed a button press of 1 on an IR remote)). So now that this works perfectly (you can see it on my homepage, btw) the time had come to the around 80 % reliable car system. For the WAF (wife acceptancy factor) that score's exactly 20 % too low. And that is the main reason for my week of "play".
I have now started using Windows workstation 2003 (which is basically the standard version of the Windows 2003 Server with a bunch of changes and tweaks). I believe I have found the perfect answer for my system. You may have other requirements (in fact if you're a small footprint fan you might as well go on to the next message - there's nothing for you here), but there may be something interesting for some of the rest here.
I have had a carputer for a few years now, started up with old trash (Celeron 450 with Windows 98SE) and then bought my current system in the fall of 2002, I believe. With a few changes and modifications it now looks like this, in my 1995 Chevrolet Suburban 1500 5,7 4x4:
Plywood tool suitcase with diamond patterned aluminum foil outside
MSI M2M Combo socket A mobo (can take both SDRAM and DDR)
AMD XP1800 with Igloo Silent Breeze cooler
2 x 128 meg 133 SDRAM
2 Soundblaster Live! 5.1 with kX drivers (lets you address each output plug as separate sound cards)
Trendnet 54 mbit PCI WLAN card
IBM 120 gig harddrive
Maxtor 160 gig harddrive
Cheap *** powersupply with fan mod (pretty silent)
Papst 120 mm case fan in top, run at 7 V in the summertime, with a rheostat that's turned for even quieter operation the rest of the year
300 watts inverter controlled with relays in this fashion: The 12 V output on one of the harddrive connectors keeps the relay open so power comes to the inverter when the computer is running. When the computer shuts down or hibernates the power is cut after about 3 seconds and the inverter shuts down. To start the inverter I have a push button jumpstart on the dashboard. I press it for about one second, which is enough for the computer to start booting (of course it's set to fire up when the PSU gets power). Also there's a second button on the dash which is used to send the computer into hibernation (it's just an extension of the regular ATX power button with the OS set to go into hibernation when the power button is pressed) or in extreme cases (which I hope I'll avoid from now on) to turn it off brutally by holding it in for three seconds. The next time power is applied the computer will do a full boot.
The most important parts of my current software setup are:
OS: Windows 2003 Server set up as workstation
Audio Player: J.River's Media Center 9.1 version 313 witgh multi-zone capabilities used to give one zone to the car audio system and two zones to the two kids in the back seat with very nice JVC old school big headphones - they block almost all the sound from the car and the car audio system, so they won't have to turn the volume up all that much to be able to hear their own stuff
Video/DVD Player: ZoomPlayer with WinDVD Platinum 5 video filter, AC3 filter audio filter and ffdshow for added extras (this is not yet in use in the car since I haven't got a monitor yet - I'm still wondering if I should build a CRT monitor into the mid console between the front seats or get a used LCD, hack it up and put it on a hinge from the roof)
FileSync 2.18 for keeping the collection up to date (the car system is basically the backup I need for my home system - I don't want to loose 40 000 tagged and treated mp3 tracks and a bunch of digital photos because of a power spike or something, so I had to have a full backup anyway)
Girder - the glue that keeps it all together
The control is done in three ways:
1. NetRemote with my Ipaq 5450, PocketLoox 600 or SIMpad via WLAN
2. Two IR remotes for the kids in the back seat
3. An ATI Remote Wonder RF remote in the front of the car that can control both the zone that goes to the car audio system and the kids' zones (nice to be able to pause them and tell them something they need to hear)
Car audio system:
Midrange Pioneer headunit with AUX box for the carputer
Alpine DDDrive speakers in the front doors driven by a 2x50 watt speaker
Magnat 16x9 speakers in the rear doors driven by the headunit
Custom built approximately 140 litre bass reflex subwoofer behind the back seat with two JL Audio 12" subs driven by a Soundstream Li'l Wonder (but believe me, the sound is huge!)
So this last week I have experimented while on the job (I'm a selfemployed translator and can work while the computer is installing and rebooting, and it only takes a little input to do all this testing) and I have found a few very surprising conclusions (at least to me). The result is that I'm using Windows 2003 server set up as workstation. Let's first have a look at my main gripes with XP:
1. A few days ago I asked about hibernation times, and I got a few answers. But not the ones I wanted. It seemed that most people were satisfied with a return from hibernation between 20 and 30 seconds.
2. A year ago (maybe) I asked about Windows XPs biggest problem when it comes to automation in automobiles: If you start a return from hibernation and something happens (like my wife often does - press the pc start button on the dash first and then turning the iginition key) you'll get a screen that tells you that the pc had a problem returning from hibernation, and do you want to delete the hibernation data and do a normal boot. This is of course very difficult to see without a monitor and it's one of those things that does not help the WAF of the system!
3. I measure a reboot from the moment I press "restart" to the second the music starts playing on MC9, not a boot since when I'm not resuming from hibernation a reeboot is more common than a regular boot. With the original XP carputer system I had a boot time on around one minute and six seconds. That was on a heavily tweaked system with all unnecessary services disabled, heavy use of bootvis and all the boot speading tips I could find here.
So first of all I tried a fresh install of XP, with no services disabled, no tweaks at all except for my little bootvis, and I got a boot time of...one minute and six seconds! And the old system was not weighted down with anything special. So obviously that was the time I could expect on this motherboard and with these sound cards, harddisks and the wireless network card. And maybe a lot of the disabling of services and other tricks really doesn't do all that much?
Then, in the beginning of this week while reading an OS thread here in the forum, I saw a guy recommending Windows Server 2003. No reason, no answers to later questions. Only those three words, I believe. Since I had it laying around (sometimes you get fringe benefits from being in business for yourself) I decided to try it. So in with the OS, and with a few PowerQuest Drive Image images on crucial points (to avoid a full re-install if something messed it up) I had it up and running in a couple of days (remember this was done while working full days translating, so we're not talking many hours of effective installation here). The first snag was that the old bootvis.exe did not work, but I managed to find an msi installation package that works on XP and 2003.
And after a few turns of that the reboot time was...40 seconds! We're talking a 26 second difference, with everything else exactly the same. The same hardware, the same software installed with the same settings. The time to hibernate has gone down from 6 seconds to 4, and a resume is now down to 15-16 seconds (from I press the power button to MC starts playing), with 256 meg ram, while it used to be closer to 20 with 128 meg ram! So there is no doubt that the OS is faster in those respects. A slightly weird thing is that if I do a hibernation trace and then optimize it, the hibernation times will increase, but if I then do a boot+driver delays trace and optimize, the times will decrease to the original times again. Go figure!
Finally, and what really makes me choose this setup, of course besides the fact that Micro$oft's server systems always has been so stable that you'll need to shoot them to make them crash if you don't do something totally idiotic (like putting them in a car, maybe? ) is that Windows 2003 will always resume from hibernation without prompts no matter how many times you pull the plug in the middle of a hibernation! So mission seems to be accomplished - I believe I have found the system that works perfectly for me. And if even one person bothered to read all this (which I'm going to use as a basis for a homepage about my car audio system some time this spring) I would really like to know!
Tor - The MediaSUV
Mastiff is offline   Reply With Quote
Old 01-16-2004, 06:02 PM   #2
MeanGT's Avatar
MeanGT
Quote: Originally Posted by Mastiff
And if even one person bothered to read all this I would really like to know!
I read about 2/3's of it, ,, I have a relay setup similar to yours, except I have a second relay that turns the whole thing on when I turn the key forward
My OLD Carputer: http://www.mp3car.com/vbulletin/showthread.php?t=17412
Currently, Don't have a carputer :( I sold my lincoln and bought a '93 Acura Vigor, plan on putting a carputer in it one of these days. You can see my vigor at: This Site
MeanGT is offline   Reply With Quote
Old 01-16-2004, 06:55 PM   #3
AlienEclipse's Avatar
AlienEclipse
Very interesting read. I would much love to see some pics of this setup. I might grab a copy of Win2003 from work and try it for myself.
Is your website up and running already? what is the URL?
EDIT: Don't worry i found your site - it needs work (no offence)
We are, will have and forever will be...
But not tommorrow!
AlienEclipse is offline   Reply With Quote
Old 01-17-2004, 05:51 AM   #4
Mastiff
I will take some pics one of these days. But I actually take offense, at least a little. Mainly because I don't think you have read the disclaimer:
Quote:
Oh, if you find this website's style boring, you're probably right. I'm not creative in the web design, just like with my audio and video I prefer functionality and simplicity.
I have no knowlegde aboug or even interest in webdesign. I like to show people what's possible to create without spending all that much money and your comment is the first about the design that I've had in the close to one year I've had the site up. Everybody else has raved about the info and the system.
Tor - The MediaSUV
Old 01-17-2004, 07:31 AM   #5
AlienEclipse
Don't get me wrong. I hadn't actually looked through your site before i wrote my last post (first impressions last). After Reading through the entire site, i must say extremely impressed. I say you've spent a lot of man hours on this setup - great job.
I try not to offen when commenting about someones site, i'm not worlds best web designer or graphic artist myself. I'm just the sort of person who worries about the look rather than the content.
But not tommorrow!
Old 01-17-2004, 09:53 AM   #6
Mastiff
Thanks! That's more like the comments I get. I don't really worry about the looks of my webpage, but I do worry about the looks of my system. Which is why I for instance spent five hours in the bedroom when we put up new wallpaper and a new carpet, building all cables into the wall and floor. I have 7 or 8 cables running half the length of the room, and they're all invisible. And then of course with all the stuff I do, and something that's supposed to be a regular social life and famliy life for a guy at almost 40, with two kids, there's not much time left for web designing. So I spend the time I have available for projects like that on the actual projects not the website look. But if anybody wants to make my site look better (for free, of course...) I'd be all ears!
Tor - The MediaSUV
Old 01-18-2004, 05:05 AM   #7
none's Avatar
none is on a distinguished road
Good god! What a complex system! Very impressive. I myself have found Winamp to be very stable, but then I have a boring single soundcard setup, as I think most people do. I doubt many programs are developed with multiple soundcards in mind.
Thanks for the tip on win2003. If I had read this 6 months ago I would definitely have given it a try, but my system is now in the car and rock-stable with win2000 (hate XP,) so i won't be messing with it. Maybe on the next go-round
none is offline   Reply With Quote
Old 01-18-2004, 11:30 AM   #8
Phrozenpenguin
I read it all.
Pretty interesting, altho only a little on the xp vs 2k3 issue.
Nice multiroom/zone setup, i was going to do that at home but then realised i didnt have much use for it.!
Phrozenpenguin is offline   Reply With Quote
Old 01-18-2004, 12:10 PM   #9
Raw Wave
Defiler's Avatar
Defiler is on a distinguished road
Holy long posts Batman!!!
Good read. I have a copy of 2003 lying around...Maybe in the future I will try this but not right now. Good luck with the set up.
Defiler is offline   Reply With Quote
Old 01-18-2004, 12:42 PM   #10
mst
mst's Avatar
mst is on a distinguished road
Hi Mastiff
Thank you for a very interesting post and website.Just a small question,if I change from XP to Server 2003,will I have any problems with hardware or drivers,all that works under XP will work under Server 2003?
My system is not yet installed,but I will need the pc to start before the car so I need something there can boot quickly(from closed or hib or sb).
mst is offline   Reply With Quote
Old 01-18-2004, 02:28 PM   #11
Mastiff
Thanks for the praise, guys!
As of yet I haven't seen any drivers or other things that does not work, but if you haven't got a valid key you won't be able to do winupdates. Also there are a few applications that won't work on a server software, like Partition Magic and Drive Image (which I run from a separate partition) and Norton Antivirus 2003/2004 and so on (you need the enterprise version if you want to be sure that you don't catch a virus on Main Street...). Except for that it has been smooth sailing.
Tor - The MediaSUV
Old 01-21-2004, 09:59 AM   #12
sounder's Avatar
sounder
Well I have windows 2K3 enterprise here, and I have yet to use it in a carputer since, but have tried its server functionality, and I thought the damn thing was a pain in the ***. I know its a freaking server, but **** If I really want to shut down, I don’t want to have to say why...oh well there’s all good reasons for that, but it should be an option. (Probably is) Anyway...I have winxp and the whole car setup running under an optima battery, so I get days of use without turning on the car. With that in mind I setup winxp pro to go into s3 stand by mode, which is suspend to ram. So only the ram is running after 15min of inactivity. I have the bios monitoring the vga, so I turn on the screen and before the screen can display anything the carputer is running very functionally. This system can jump off the s3 standby in about 4-5 secs. No joke. I love my setup. That’s why I haven’t gone to S2K3. I also have the WOL running on it, and all I have to do from my home computer is send it a magic packet and boom 5sec ready to copy new movies and mp3s. When I get in the car I run a script and recompile my video and audio lists. I copy my album and movie art to an img folder, and I’m done. 15 later the computer returns to standby. The art is named after the file, so my vb program automatically displays any img in the 'img' folder with the file name that’s currently playing.
Later
Subject open, Subject closed.
sounder is offline   Reply With Quote
Old 01-21-2004, 10:11 AM   #13
Mastiff
If you didn't disable the shutdown tracker, you didn't read the guides. That's very easy. Anyway, it's nice in a hot climate like Atlanta, but since we only use the Suburban about twice a week (we drive a Mazda MX3 most of the time), it would kill any battery in 20 below...
Tor - The MediaSUV
Content Relevant URLs by vBSEO 3.3.0
"VaultWiki" powered by VaultWiki v2.5.2.
Copyright © 2008 - 2009, Cracked Egg Studios.Ad Management by RedTyger
