Go Back   MP3Car.com > Mp3Car Technical > Software & Software Development
Old 05-09-2004, 05:30 AM   #1
Engine sensor meters
Anyone can come out with a engine sensor gauges like those from motecs.
I have pcbs of the ADC-11 offered by www.picotech.com. Its a 11 channel 12 bit ADC plugged into the parallel port.
A cool idea would be to hook up some pressure sensors/temp sensors etc and have a nice read out for exhaust temp, oil temp, airtemp, airfuel ratio, boost meter gauge on the car pc. Connecting the sensors are relatively easy. To measure temperature I took some PC CPU temp sensors and stuffed it into the water hose. one end goes to ground while the other goes into the ADC input. Another resistor is connected across the ADC in and +5V. that forms a voltage divider. In the software provided by PICO you can set a formula in which the data will be displayed....
PCBs available from me at $5 worldwide postpaid. the software can be downloaded from the picotech website. You will need the IC TLC2543 DIL.
see attached picture. For $5 you wil get the PCB with chipresistor and chipcaps. The reason I'm selling it cheap its cos I would like someone to come out with some cool software... to make an ADC-11 you will need to purchase:
2 x 25w D-Type connector
1 x Housing as used in gender changers
1 x TLC2543CN available from Newark cost $8.90 ea
http://www.newark.com/NewarkWebComme...Text=TLC2543CN
hope this helps
and yeah PICO is crazy for selling it for $200!
robyn3d(at)h0+ma1L(dot)c0m
Robyn is offline   Reply With Quote
Old 05-10-2004, 02:10 PM   #2
very nice, i m interested.
what is the refresh rate on these channels?
xtra is offline   Reply With Quote
Old 05-11-2004, 09:46 AM   #3
refresh rate
The software allows max of 30Hz (30 reads per sec)
Old 05-13-2004, 04:22 PM   #4
any chance you can provide the schematic?
Old 05-14-2004, 12:00 PM   #5
it hardly has any external components. It is directly connected to the parallel port. the inputs have 100K buffer resistors to prevent damage from spikes...
Adding text-to-speech functionality to Media Engine skippy76 Media Engine 14 04-19-2004 01:38 AM
Adding file syncronisation to Media Engine skippy76 Media Engine 7 03-26-2004 11:01 PM
Playing files from CD in Media Engine tczbu Media Engine 2 03-25-2004 11:04 AM
Useing GPS with Media Engine and other Question Twizted ME Archive 4 01-10-2004 06:36 PM
MyHTPC or Media Engine? e36mp3 Software & Software Development 1 03-30-2003 01:43 PM
