Go Back   MP3Car.com > Mp3Car Technical > Software & Software Development
Old 05-15-2004, 04:54 PM   #1
TheKurbster's Avatar
Heat problems??
HELLO,
just wonder if anyone ever has any problems with heat, it gets about 90 degress in the summer down here. Will that mess up any of my system? So far i have XENARC 700TSV screen that i just put in the car. (looks good too ) Nest to install the pc part which is a MiniQ. but i'm worried about the heat issue. wondering if anyone could give me any ideas? Sorry wrong thread...
Last edited by TheKurbster; 05-15-2004 at 04:56 PM. Reason: Wrong place for thread
TheKurbster is offline   Reply With Quote
Old 05-15-2004, 10:16 PM   #2
Raw Wave
TruckinMP3's Avatar
If the processor heat sink is well seated and has a fan.... and your case fan moves a reasonable ammount of air you should be fine.
Read up, many ideas some of them are crazy. Try a search on cooling, heat or fans
TruckinMP3
Self Proclaimed Spoon feeder!
Read the FAQ!
TruckinMP3 is offline   Reply With Quote
Old 05-17-2004, 09:27 AM   #3
samc's Avatar
What I have noticed so far is if the temperature gets towards 80F here in New York the carputer heats up too much but if I run my air conditiioned on the coolest level low speed then the cabin cools enough to keep my proc/case temp running at 45C/<20C. THat's my only solution so far. And I have 3 fans on my "case"
EDIT: also my computer is in my glovebox
Mine needs to be updated.
samc is offline   Reply With Quote
Old 05-17-2004, 09:43 AM   #4
Raw Wave
god_of_cpu's Avatar
I use to have heat problems, but since I upgraded my processor fan to an extra high RPM one and glued a heatsink to my onboard GeForce processor, its been fine running in the trunk outside of a case.
StreetDeck.com Developer (I am Chuck)
Get StreetDeck at http://www.streetdeck.com
The Official StreetDeck Forums have moved, please visit us at http://www.streetdeck.com/forum for official support for Streetdeck.
god_of_cpu is offline   Reply With Quote
Old 05-22-2004, 11:25 AM   #5
Well I live in Las Vegas and my shuttle has not had a problem so far. I just remember to put a cover over the Lilliput when I leave the car in the sun (and to hide it from prying eyes).
I am about to install the whole thing from the Shuttle case into the VCR case that was an optional fit in the Chevy Venture that I have and turn it into a 'stealth' install. To avoid heat problems I am tapping into the A/C pipework and feeding cold air to the front of the unit so that the rear fans will then pull the chilled air across the board and through the heatpipe of the shuttle mobo. As we always run A/C here in Vegas it should be fine.
If you can redirect A/C air to the trunk or wherever you install your PC and feed it into the opposite end from the fans it will certainly help on those hot days.
Steve
RV : Samsung Q1 + Kyocera KR1 (EVDO) + GPS<br>
Car: AMD 3000+ Book PC + Lilliput 8" Touch + 13" TFT
Webmaster for the European Ford Scorpio Site
SteveC is offline   Reply With Quote
Old 05-22-2004, 12:19 PM   #6
Raw Wave
TruckinMP3's Avatar
Quote: Originally Posted by SteveC
SNIP
Steve
Carefull, even in Vegas you might want the heat at some point.
TruckinMP3
Read the FAQ!
Hard drive shock problems. Michael Szilagyi General Hardware Discussion 8 03-21-2005 03:37 PM
CPU Heat question: Which one would generate less heat? kiztope General Hardware Discussion 6 02-12-2004 02:14 AM
First generation install in ...but I have too problems. Skraggy_uk General Hardware Discussion 3 06-26-2003 12:28 PM
Heat problems? thaladyzman General MP3Car Discussion 1 02-07-2003 08:48 AM
COOLING THE CARPUTER moahdib General Hardware Discussion 33 07-04-2002 08:18 AM
