Go Back   MP3Car.com > Mp3Car Technical > Software & Software Development
Old 06-02-2004, 05:03 AM   #1
See me in my wet t-shirt.
stevieg's Avatar
stevieg is on a distinguished road
GPS/MapPoint VB Source Code
Hiya
I've made a simple GPS/MapPoint application for anyone who wants to write their own VB app to capture and process GPS data.
EDIT: A version that doesn't need a MapPoint control is also available
It's not intended as a app to actually use in your CarPC but it is intended to help anyone who wants to get their app started quickly without having to work out how to do the GPS capture from scratch.
The code is licensed under the BSD License so you're not oblicated to release the source code of anything you make using my code. There may also be bugs in the code, if you find any feel free to tell me so I can update the code. I don't guarantee it to be perfect, but it should help get you started.
It's fully commented so you shouldn't have any problems working out what does what.
It is availble for download from http://www.stevieg.org/opensource
If you need an app to simulate GPS data while you are testing I can recommend 'GPSGate' - http://franson.biz/gpsgate/ which is $29 and also allows you to split your actual GPS as well if you want to make an app that runs alongside your usual Navigation software.
Thanks to James Warner for letting me look at his GPS/MapPoint source code to get the idea of how it's approached, however this was coded on a clean machine without looking at his source code with my own research and approach, none of his code is in this whatsoever.
Hope this helps someone
Steve
Ford Focus MP3 : www.stevieg.org/carpc Blog Updated 29 January 2009!
Car PC Status: Complete - Undergoing Software Redevelopment
stevieg is offline   Reply With Quote
Old 06-02-2004, 05:33 AM   #2
Raw Wave
Laidback's Avatar
Laidback is on a distinguished road
Thanks, reference code is always handy!
Laidback
Laidback Carputer
Laidback is offline   Reply With Quote
Old 06-03-2004, 06:07 AM   #3
SilentAdmirer's Avatar
SilentAdmirer is on a distinguished road
Hi Steve,
I have a question regarding the GPS init. "$PRWIILOG,RMC,A,T,1,0" . What is PRWIILOG Statement ? I tried searching on the net and only thing I could find was this page http://www.gpsinformation.org/dale/nmea.htm . According to the page $PRWIILOG is used for initialising gps reciever based on Rockwell chip. I thought that most of the new GPS reciever is based on SiRF or SiRF II chipset. The initialising string for SiRf is $PSRF . Can anyone tell me more about it ?
Regards
Satish
VOICES Status : Rework in Progress [||--------](20%)
Preview Version at http://voices.techworldonline.com
SilentAdmirer is offline   Reply With Quote
Old 06-03-2004, 06:23 AM   #4
stevieg's Avatar
Quote: Originally Posted by SilentAdmirer
Hi Steve,
Regards
Satish
I used it becaus e it was the command James Warner used to init the nmea device, I don't think it is neccessary though as RMC is supposed to be the minimum data required so all GPS devices should be sending it anyway, but if there is a chance they aren't then hopefully this might catch the device and make it start sending.
Old 06-08-2004, 03:24 PM   #5
stevieg's Avatar
Updated - non mappoint version also available for download
Alpha Release: XMPC-CAR for XM gork Software & Software Development 88 01-11-2006 01:19 PM
XMPC-CAR source code now available! gork Software & Software Development 6 04-06-2004 01:33 PM
me vb source code ch0g ME Archive 9 03-20-2003 08:46 AM
Motherboard Monitor VB Source Code veedubya Software & Software Development 0 01-08-2003 03:06 PM
Dos MP3 player/decoder source code? Fosgate Software & Software Development 4 03-23-2000 04:46 AM
Content Relevant URLs by vBSEO 3.3.0
"VaultWiki" powered by VaultWiki v2.5.2.
Copyright © 2008 - 2009, Cracked Egg Studios.Ad Management by RedTyger
