Go Back   MP3Car.com > Mp3Car Technical > Software & Software Development
Old 07-06-2004, 02:59 PM   #1
The Grinch's Avatar
Are there any software EQ solutions?
I'm planning to run my EPIA directly into a power amp. Are there any software solutions in existance (besides WinAMP) that will provide a graphic or parametric EQ? It would be really cool if this was built in to one of the car media players.
The Grinch is offline   Reply With Quote
Old 07-06-2004, 03:05 PM   #2
None that I know of unless you write your own. My software uses the fmod with a 10band graphic EQ built into it. You can also use bass.dll.
www.DurangoSUV.com
The Durango Kid is offline   Reply With Quote
Old 07-06-2004, 03:57 PM   #3
not as simple as the EQ in winamp but you might want to look at dee2/dee3
krystar is offline   Reply With Quote
Old 07-06-2004, 08:46 PM   #4
The Grinch's Avatar
I just found an EQ for my EPIA board. I found the latest audio drivers for it, installed them, and there was my EQ.
I'm not sure if it was there before installing the new drivers, but all that matter is that I have it now. If your mobo has the matching chipset, you can find the VIA Stylus drivers here:
http://www.viaarena.com/?PageID=69
-> Launch the "VINYL DECK" from START->Programs->Vinyl Deck. Once it loads, click on the Sound Effects tab.
I still wish this functionality was built in to the car media players, but it's better than nothing.
Old 07-06-2004, 11:24 PM   #5
mobileh1's Avatar
Before you all rush off and try this here's a word of caution.
I did just that, and I run winamp, plays muffled and awful. If I bring up the vinyl deck app and adjust one of the eq sliders even the slightest bit its bright and sounds perfect again. Then I restart mediacar/winamp etc and its back to muffled.
Ill play with it some, but the M10,000 and these drivers seems to have some problems...
.//Daren
(Epia M10000/C134) (C137/MII 10000) Liliput /Opus 150W/DVD/512MB/80GB/Hummer H1
MediaCar/CoPilot7/Routis
mobileh1 is offline   Reply With Quote
Old 07-06-2004, 11:34 PM   #6
The Grinch's Avatar
I've got it installed on my MII-10000. It seemed ok with WMP. I'm still setting up and configuring the system (brand new), so I'll see what happens once I get other software installed.
Old 07-07-2004, 10:02 AM   #7
I found this, might help but havent tested it yet...
There is demo available....
http://www.audioenhancedps.co.uk/rad...oundRouter.htm
It allows to route audio through directx plugins and there is many professional EQ:s available so i think this is best solution yet (if it works that way)
Try that.
JanneZ is offline   Reply With Quote
Software solution for gLCD-based car-mp3 Novgorod Software & Software Development 1 07-01-2004 07:59 PM
myHTPC Software the_new_guy Software & Software Development 1 06-05-2004 03:51 PM
CoPilot Software or USB GPS Receiver package Zip-Lock Classified Archive 5 05-13-2004 07:30 AM
Winamp 2.9x and 5.x EQ. stevewm Software & Software Development 0 12-23-2003 10:17 PM
My numpad controlled custom MP3Car software - need your opinions PorscheMP3 Software & Software Development 7 04-11-2002 10:30 AM
