Go Back   MP3Car.com > Mp3Car Technical > Software & Software Development
Old 09-14-2004, 09:13 PM   #1
jeremyp111 is on a distinguished road
WinXP Hibernation Problems
I have my carpc set up to go into hibernation. It goes into hibernation fine, but when I turn it back on it does a full boot instead of coming out of hibernation. I can't really figure out why. I have an EPIA MII10000 with a Morex 60w PS & Carnetix P1260. WinXP is set to go into Hibernation when the powerswitch is pressed. I had this working fine when I had it set up with an Opus 90w powersupply, but it doesn't want to work with the Morex/Carnetix combo. Any ideas?
jeremyp111 is offline   Reply With Quote
Old 09-14-2004, 09:20 PM   #2
Super Moderator & Wal-Mart Greeter
Tidder's Avatar
Tidder has a brilliant futureTidder has a brilliant futureTidder has a brilliant futureTidder has a brilliant futureTidder has a brilliant futureTidder has a brilliant futureTidder has a brilliant futureTidder has a brilliant futureTidder has a brilliant futureTidder has a brilliant futureTidder has a brilliant future
That's weird man.
Tidder
Try RevFE
The best frontend I've ever used, period.
Best Quote EVER!!
Quote: Originally Posted by bramlet View Post
I try to search but I usually only find posts where people ask questions and darquepervert tells them to search.
Tidder is offline   Reply With Quote
Old 09-14-2004, 09:23 PM   #3
LekanB is on a distinguished road
Quote: Originally Posted by jeremyp111
I have my carpc set up to go into hibernation. It goes into hibernation fine, but when I turn it back on it does a full reboot instead of coming out of hibernation. I can't really figure out why. I have an EPIA MII10000 with a Morex 60w PS & Carnetix P1260. WinXP is set to go into Hibernation when the powerswitch goes on. I had this working fine when I had it set up with an Opus 90w powersupply, but it doesn't want to work with the Morex/Carnetix combo. Any ideas?
jeremyp111.... I have the same problem. I too would appriciate a solution if anyone knows of something!
-Thanks
LekanB is offline   Reply With Quote
Old 09-14-2004, 09:33 PM   #4
Tidder's Avatar
I've noticed sometimes my computer freaks out if I'm accessing the hard drive constantly like booting for instance. (only when the car's off and my voltage is lower than it should be) It causes freaky things with the power. What/how many drives do you have? CD-rom, hard drive, USB devices, etc. That's the best I know where to start man, sorry.
Tidder
Try RevFE
Best Quote EVER!!
Old 09-14-2004, 09:40 PM   #5
Bravellir's Avatar
Bravellir is on a distinguished road
I’m using a inverter+itps and a amd board, but i very occasionally get the same problem. I found out that when power its shut down ( in my case, when the itps cuts the power to the relay that is between the battery and the inverter). The itps feeds a very small pulse to the output that is connected to the pc power switch. This sometimes is enough to make the pc start, and since its power is cut immediately after, when it boots again it no long resumes from hibernation.
Don’t know if it's your case, but I thought you might want to explore the possibility.
Ikea Case. Epia M10000.M1-ATX. 512 Mb. 2,5" 80 GB HDD. 7" Lilliput. BU-303 GPS. Sony Joystick.
Status -->
Lilliput Installed (not indash yet..)
BraveCar 2.5
Bravellir is offline   Reply With Quote
Old 09-14-2004, 10:03 PM   #6
Here's what I have:
EPIA MB (as above)
512mb ram
(1) 2.5" 60gb HD
(1) slim DVD
wi-fi PC card
USB GPS mouse
USB gyration keyboard/mouse combo
Lilliput USB touchscreen controller
Lilliput is powered from 12v+ regulated from Carnetix P1260
Old 09-14-2004, 10:06 PM   #7
I've watched it to see if anything funny was happening, but it does go into hibernation properly. Power is shut down shortly there after. Most of the time it looks like it's trying to come out of hibernation and then just goes into a full boot like it was never in hibernation. Do you think i should try to repair the XP installation?
Old 09-15-2004, 03:53 AM   #8
Raw Wave
Laidback's Avatar
Laidback is on a distinguished road
Does it still work ok with the powerswitch button?
Laidback
Laidback Carputer
Laidback is offline   Reply With Quote
Old 09-15-2004, 04:00 AM   #9
l9nux's Avatar
l9nux is on a distinguished road
I'm not 100% sure on this, but does the motherboard still need power whilst in hibernation? I know it does for stand-by, but if your power supply is completely powered off (rather than just the PC), then this might be the cause?
-= I took the red pill =-
l9nux is offline   Reply With Quote
Old 09-15-2004, 04:05 AM   #10
Raw Wave
Laidback's Avatar
They don't need power in hibernation.
Laidback
Laidback Carputer
Old 09-15-2004, 06:24 AM   #11
No because the powerswitch button is disconnected from the MB. It's replaced by the green/black wires that come from the Carnetix P1260 to control shutdown. It's weird cuz it worked flawlessly with the Opus, but not the Carnetix. Sometimes it works (not very often) but most times it doesn't.
Old 09-15-2004, 04:10 PM   #12
Bravellir's Avatar
I sugest that you try it with the powerswitch. This will allow to narrow the possible causes. But if with the opus it worked ok, I think it's a shutdown controler problem.
Status -->
BraveCar 2.5
Old 09-15-2004, 04:18 PM   #13
I actually tried it with the powerswitch before installing the Opus and it worked fine then. No problems. I think it might not be hibernating fully before the Carnetix is shutting off power. It's set for 30 seconds. I'll see if I can change that to a longer time.
Old 09-15-2004, 05:16 PM   #14
MoFo's Avatar
MoFo is on a distinguished road
I had this problem after doing some tweaks that were supposed to increase my boot time.
The laptop would go into hibernation, but when turning back on it would not un-hibernate, it would give me the option to 'delete restoration data' and reboot from scratch. I had to reformat to get hibernate working again.
You could try just re-installing windows though
MoFo is offline   Reply With Quote
Old 09-15-2004, 05:22 PM   #15
Curly_cat's Avatar
Curly_cat is on a distinguished road
I'm using a Carnetix CN-P1260 with a Cubid 3688 case and Epia MII12000 mobo.
It is set to hibernate when the power switch is pressed an when the PSU turns it off it enters hibernation Ok and resumes when I turn the ignition on again.
You could check your settings in the power options in control panel and also check to see if you get the "Resuming Windows" display at boot time.
: Jetway J7F2 1.5Ghz Mainboard : Cubid 3688 : CarNetix CNX-P1260 :
: Netgear 802.11g PCMCIA : 2 x LinITX 7" Screens :
: BU353 USB GPS Mouse : Panasonic UJ845 DVDRW :
Curly_cat is offline   Reply With Quote
XMPCR has hibernation problems? MikeH FrodoPlayer 29 09-24-2004 11:08 PM
GS Reciever, WinXP SP2, and Hibernation captain_jim1 GPS 10 09-19-2004 04:12 PM
Dell Inspiron 8200 & Lilliput TS problems? bkpsu LCD/Display 1 08-15-2004 02:55 PM
Problems Enabling Hibernation divinity Software & Software Development 16 05-16-2004 01:03 PM
windowsMe hibernation moahdib Software & Software Development 4 08-04-2000 12:07 AM
