Go Back   MP3Car.com > Mp3Car Technical > Software & Software Development
Old 09-30-2004, 11:52 PM   #1
Dexter172
Relay source code
Is there any realay source code for the parallel port written in C or make it really simple Basic? There was alot of talk about the relay setups but it never really got off the ground. Just code to read a signal and a code to send a signal to a relay.
Dexter172 is offline   Reply With Quote
Old 10-01-2004, 03:55 AM   #2
mushin's Avatar
mushin is on a distinguished road
Google for "dlportio", you'll find a C library for raw access to the parallel port under Windows. The code will be *really* basic, since all you're going to be doing is setting particular bits high for each relay.
mushin is offline   Reply With Quote
Old 10-01-2004, 09:57 AM   #3
Raw Wave
god_of_cpu's Avatar
god_of_cpu has a reputation beyond reputegod_of_cpu has a reputation beyond reputegod_of_cpu has a reputation beyond reputegod_of_cpu has a reputation beyond reputegod_of_cpu has a reputation beyond reputegod_of_cpu has a reputation beyond reputegod_of_cpu has a reputation beyond reputegod_of_cpu has a reputation beyond reputegod_of_cpu has a reputation beyond reputegod_of_cpu has a reputation beyond reputegod_of_cpu has a reputation beyond repute
I got a parrallel port based relay card and wrote my own control software using dlportio, the problem is its absolutly unusable in the car since random bits will get sent to the parallel port when booting and trigger the relays on the port. You could perhaps get around this by using a relay to trigger the power going to the parrallel port card only when the computer is finished booting, problem is you now need another relay card to start your first relay card.
StreetDeck.com Developer (I am Chuck)
Get StreetDeck at http://www.streetdeck.com
The Official StreetDeck Forums have moved, please visit us at http://www.streetdeck.com/forum for official support for Streetdeck.
god_of_cpu is offline   Reply With Quote
Old 10-01-2004, 12:11 PM   #4
Marsupial's Avatar
Marsupial is on a distinguished road
what if you use a USB parallel port... it theory it won't send anything to tbe LPT port until the PC is booted and the USB has kicked in... or maybe I am wrong.
just an idea
-Mars
Carputer progress meter:
[----------] - 0%
status:
Changing project. The kiosk I have will end up in the kitchen! Reviewing carPC ideas...
Marsupial is offline   Reply With Quote
Old 10-01-2004, 12:22 PM   #5
Registered User
Gruneun
Do a search for the "Mini SSC II" servo controller card. It's about $40, is a couple inches square, controls 8 servos (chainable up to 256), and takes 3-byte commands from a serial port. There's plenty of free software for controlling it. If you're dead-set on it using the parallel port, you can use an adapter.
Gruneun is offline   Reply With Quote
Old 10-01-2004, 12:39 PM   #6
Raw Wave
god_of_cpu's Avatar
just an idea
That would be too easy... I haven't tried it myself but someone else on here said they don't work with the USB converters.
Alpha Release: XMPC-CAR for XM gork Software & Software Development 88 01-11-2006 01:19 PM
GPS/MapPoint VB Source Code stevieg Software & Software Development 4 06-08-2004 03:24 PM
XMPC-CAR source code now available! gork Software & Software Development 6 04-06-2004 01:33 PM
Will someone help me program my relay control module cproaudio Software & Software Development 6 09-04-2002 05:50 AM
Dos MP3 player/decoder source code? Fosgate Software & Software Development 4 03-23-2000 04:46 AM
