Go Back   MP3Car.com > Mp3Car Technical > Software & Software Development
Old 10-01-2004, 04:47 AM   #1
az1324
Programming Question in VB
So I wrote some code to take the map window in routis and embed it into the app i'm using without the menu and button bar etc...
Anyway, i just changed the parent of that window using setparent api call. It works great when testing on my desktop running xp but when i move it to the car which is running 98 it doesn't work. the map window disappears and the only two functions that could be causing it are movewindow or setparent. any ideas?
az1324 is offline   Reply With Quote
Old 10-01-2004, 05:13 AM   #2
Raw Wave
Gobby is on a distinguished road
Hi,
Never used the setparent or moveparent functions myself but could they be 32Bit XP only API calls?? If so, they won't work under '98.
Gobby is offline   Reply With Quote
Old 10-01-2004, 10:54 AM   #3
Chairboy's Avatar
Chairboy is on a distinguished road
98 is 32bit.
Run depends.exe on your application on XP and figure out which external files it's using. You probably need to update some component on your 98 machine.
Chrysler 300 - Fabricating
http://hallert.net/
Chairboy is offline   Reply With Quote
Old 10-01-2004, 04:24 PM   #4
Raw Wave
I put 32bit XP ONLY! API Calls, I didn't say that Windows 98 wasn't 32 bit.
Old 10-01-2004, 04:29 PM   #5
Super Moderator
xBrady's Avatar
xBrady is a splendid one to beholdxBrady is a splendid one to beholdxBrady is a splendid one to beholdxBrady is a splendid one to beholdxBrady is a splendid one to beholdxBrady is a splendid one to beholdxBrady is a splendid one to behold
Try this: XP only, API calls.
Installed.
-GPSSecure- - GPS Tracking
xBrady is offline   Reply With Quote
Old 10-01-2004, 08:37 PM   #6
az1324
Now that we are done with grammar discussions, ....
SetParent Function
Minimum DLL Version user32.dll
Header Declared in Winuser.h, include Windows.h
Import library User32.lib
Minimum operating systems Windows 95, Windows NT 3.1
MoveWindow Function
Here is the code:
Code:
Option Explicit Private Declare Function FindWindow Lib "user32" Alias "FindWindowA" (ByVal lpClassName As String, ByVal lpWindowName As String) As Long Private Declare Function SendMessage Lib "user32" Alias "SendMessageA" (ByVal hwnd As Long, ByVal wMsg As Long, ByVal wParam As Long, lParam As Any) As Long Private Declare Function FindWindowEx Lib "user32" Alias "FindWindowExA" (ByVal hWnd1 As Long, ByVal hWnd2 As Long, ByVal lpsz1 As String, ByVal lpsz2 As String) As Long Private Declare Function ShellExecute Lib "shell32" Alias "ShellExecuteA" (ByVal hwnd As Long, _ ByVal lpOperation As String, _ ByVal lpFile As String, _ ByVal lpParameters As String, _ ByVal lpDirectory As String, _ ByVal nShowCmd As Long) As Long Private Declare Function PostMessage Lib "user32" Alias "PostMessageA" (ByVal hwnd As Long, ByVal wMsg As Long, ByVal wParam As Long, ByVal lParam As Long) As Long Private Declare Function ShowWindow Lib "user32" (ByVal hwnd As Long, ByVal nCmdShow As Long) As Long Private Declare Function SetParent Lib "user32.dll" (ByVal hWndChild As Long, ByVal hWndNewParent As Long) As Long Private Declare Function MoveWindow Lib "user32" (ByVal hwnd As Long, ByVal x As Long, ByVal y As Long, ByVal nWidth As Long, ByVal nHeight As Long, ByVal bRepaint As Boolean) As Long Private Declare Function SendMessageLong& Lib "user32" Alias "SendMessageA" (ByVal hwnd As Long, ByVal wMsg As Long, ByVal wParam As Long, ByVal lParam As Long) Private Const WM_LBUTTONDOWN As Long = &H201 Private Const WM_CLOSE As Long = &H10 Private Const WM_LBUTTONUP As Long = &H202 Private Const WM_KEYDOWN = &H100 Private Const WM_KEYUP = &H101 Private Const VK_SPACE = &H20 Private rHwnd As Long Private okHwnd As Long Private Sub Form_Load() On Error GoTo errortrap ShellExecute 0, vbNullString, "c:\program files\routis\routis.exe", vbNullString, "c:\program files\routis", 1 Form1.Width = Screen.Width Form1.Height = Screen.Height Form1.Top = 0 Form1.Left = 0 Timer1.Interval = 500 Timer2.Interval = 500 Timer1.Enabled = True errortrap: End Sub Private Sub Form_Unload(Cancel As Integer) Call SendMessageLong(rHwnd, &H10, 0&, 0&) End Sub Private Sub Timer1_Timer() Timer1.Enabled = False rHwnd = FindWindow("#32770", "Warning") okHwnd = FindWindowEx(rHwnd, 0&, "button", "OK") SendMessage okHwnd, WM_LBUTTONDOWN, 0, 10 SendMessage okHwnd, WM_LBUTTONUP, 0, 10 Timer2.Enabled = True End Sub Private Sub Timer2_Timer() Timer2.Enabled = False If FindWindow("#32770", "Warning") <> 0 Then rHwnd = FindWindow("#32770", "Warning") okHwnd = FindWindowEx(rHwnd, 0&, "button", "OK") Call PostMessage(okHwnd, WM_KEYDOWN, VK_SPACE, 0&) Call PostMessage(okHwnd, WM_KEYUP, VK_SPACE, 0&) End If embed End Sub Private Sub embed() rHwnd = FindWindow("intellinavwcls", "Routis") okHwnd = FindWindowEx(rHwnd, 0&, "afx:400000:b:10011:6:0", vbNullString) Call SetParent(okHwnd, Me.hwnd) MoveWindow okHwnd, 0, 0, Screen.Width / Screen.TwipsPerPixelX, 7 / 8 * Screen.Height / Screen.TwipsPerPixelY, True Call ShowWindow(rHwnd, 0) End Sub
I don't think it really matters that much cause i like copilot better but it would be nice to figure out.
Old 10-01-2004, 09:00 PM   #7
I'm sorry, and you are....?
frodobaggins's Avatar
frodobaggins will become famous soon enoughfrodobaggins will become famous soon enough
Hey some of that code is mine
[H]4 Life
I'm a lesbian too.
I am for hire!
frodobaggins is offline   Reply With Quote
Old 10-01-2004, 10:13 PM   #8
az1324
yeah true i based it on your source for routis launcher but it is heavily modified
Do you see any reason it wouldn't work on a 98 based system?
Old 10-01-2004, 10:24 PM   #9
Add some debug code to print out your handles. See what's happening.
[H]4 Life
I'm a lesbian too.
I am for hire!
This may be more of a programming question.. but here goes bklynkaos General Hardware Discussion 1 02-09-2004 11:11 PM
Question for VB Developers Seraph Software & Software Development 3 12-26-2003 08:15 PM
Programming help needed (DirectShow & VB) All4Norway Software & Software Development 0 01-06-2003 06:42 PM
Question abou thte different VB interfaces ppl have. Red95GST Software & Software Development 1 08-02-2002 01:12 AM
Out of topic programming question (VB) darkwingduck Software & Software Development 5 09-01-2000 07:55 AM
Content Relevant URLs by vBSEO 3.3.0
"VaultWiki" powered by VaultWiki v2.5.2.
Copyright © 2008 - 2009, Cracked Egg Studios.Ad Management by RedTyger
