Go Back   MP3Car.com > Mp3Car Technical > Software & Software Development
Old 10-16-2004, 12:24 PM   #1
99bravada's Avatar
Need coding help
I'm working on a front-end and it's coming along nicely; plays media through Winamp, reads/writes config file, custom skins working including background animations/animated buttons... I'm using Flash actionscript and Flash Studio Pro which is basically based on Visual Basic. I can send and receive SQL commands to my .mdb file no prob; however, I need to figure out how it can look in a location and parse through the files for ID3/meta tag information and spit it back to the database in tables/cells that I specify. I can accomplish everything else through actionscript and by utilizing Flash Studio Pro instead of trying to learn VB, but this one has got me stumped.. I think I'll have to go the VB or C# route... Flash Studio Pro can call external VB or C libraries, so even a DLL could suffice... Any help is very appreciated; I'll surely put anyone who helps in the credits.
Thanks guys,
99Bravada.
Current:
2007 Black Diamond Toyota FJ Cruiser | Mac Mini (in dash) | Carnetix P1900 (in dash) | Apple Bluetooth Keyboard | Kicker KX350.4 amp | Pair Polk Audio 6.5"s in front
Coming soon:
12.1" touchscreen LCD (in dash) | US GlobalSat USB GPS receiver
99bravada is offline   Reply With Quote
Old 10-16-2004, 12:29 PM   #2
grepzen's Avatar
found: http://www.vb-helper.com/howto_read_mp3_id3_tags.html
•Micke
grepzen is offline   Reply With Quote
Old 10-16-2004, 12:31 PM   #3
IntellaWorks's Avatar
I've never used winamp's DLL's but I have done a bunch of media player and to get ID3 tags you must draw from a member in the media class. This is done with VB or C++ pretty easily.
Progress [I will seriously never be done!]
Via EPIA MII
512MB RAM
OEM GPS (embedded)
nLite WinXP pro on
1GB Extreme III CF card
Carnetix 1260 startup/ DC-DC regulator
Software: Still, re-Writing my existing front end in .Net
IntellaWorks is offline   Reply With Quote
Old 10-16-2004, 01:00 PM   #4
Clover
Grayscale's Avatar
frodo gave me his old DB builder as an example, it was tremendous help. when he wakes up ask him for it
Sorry didn't see you didn't know VB. Well in that case...I don't know, just look at the code anyways, you might be able to modify it if you know basic programming fundamentals.
CarPC install is starting to come along again...
Grayscale is offline   Reply With Quote
Old 10-16-2004, 01:03 PM   #5
You could find someone to write you a custom dll in C# or VB, which would do just that. I'll look around the net and see if i can find one. I'm pretty heavy into VB.net right now.
I'm assuming that all the component will need to do is look at a directory/sub directories and parse all the id3 tags and insert them into a database, kind of like what frodo player does to build/sync your music collection. Is that right?
ea972271 is offline   Reply With Quote
Old 10-16-2004, 03:24 PM   #6
Clover
Grayscale's Avatar
if frodo gives the OK i'll post the DB Builder code or give it to someone to port to a DLL. sorry but i don't do dlls
Old 10-16-2004, 05:17 PM   #7
I'm sorry, and you are....?
frodobaggins's Avatar
I don't give a ****.
FrodoPlayer.com
TeaBaggins.com
[H]4 Life
I'm a lesbian too.
I am for hire!
frodobaggins is offline   Reply With Quote
Old 10-16-2004, 11:11 PM   #8
99bravada's Avatar
Quote: Originally Posted by grepzen
Thanks grepzen, but I cannot code in visual basic; I guess I need to learn someday
Current:
Coming soon:
Old 10-16-2004, 11:13 PM   #9
99bravada's Avatar
ea972271, that is exactly what I need, you are dead on... since I am using Flash Studio, I'll probably have to get someone to muck with the VB code a bit to work as I need it to... basically I'll have a folder browse icon or a field that the user can type in the location and a button (all in Flash) that will launch a VB function with the location variable as a parameter.
Current:
Coming soon:
Old 10-16-2004, 11:17 PM   #10
99bravada's Avatar
Thanks Grayscale and Frodo; this would be a tremendous help... I think there is someone in my office who knows VB so I could always get with one of them to put into a dll.
Current:
Coming soon:
Old 10-16-2004, 11:28 PM   #11
Raw Wave
Tidder's Avatar
That's the funniest damn thing I've seen all day!
Tidder is offline   Reply With Quote
Old 10-19-2004, 12:27 PM   #12
99bravada's Avatar
Hey Grayscale, did you find that code? I'll make sure to give Frodo credit in my app.
Current:
Coming soon:
Old 10-26-2004, 07:29 PM   #13
I used VB6 a few times years ago to create executable files no problem. But a couple of years ago I bought VB studio.net but the exe file would only run on the machine that I developed the application on. If I recal it was due to the fact that I had to deploy the .net framework. At this point I let it and have not used it since. Is this correct and if I create new aplications using VB.net will they run ok on other machines since the .net framework is on most machines as part of the operating system.
What is the most common development platform that people seem to be using?
Cheers Sick J
SICK J is offline   Reply With Quote
Concrete Blonde is Conducive to Coding. frodobaggins FrodoPlayer 11 10-01-2004 05:54 PM
Q about vb coding of ME GUI CorollaVerso'04 Media Engine 1 06-12-2004 07:19 AM
Mediacar V1.8.5 coyote MediaCar 47 02-16-2004 01:16 PM
You know you spend too much time coding / computing when... frodobaggins Software & Software Development 20 01-03-2004 02:01 AM
