12-21-2004, 03:20 PM
#1
Change volume with Engine RPM
I think this would be a great feature, or standalone program. You could use an OBD II device or a mic.
Change the volume by percentages based on the rpm of the engine. Vehicle speed could also be taken into consideration.
up 50% at max rpm.
Eg. (volume is set at 33%, if you rev to max rpm it is now at 50% because 33% x 150% = 50%)
up 30% at interstate speeds.
Eg. (volume is set at 33%, at 60mph the volume is reset to 44%, if the engine rpms are at max then it becomes 66%)
arg.. i just need to get off my *** and program.
12-21-2004, 03:26 PM
#2
Mercedes release this function over microphone. Mesured sound level change audio system volume.
12-21-2004, 03:38 PM
#3
MySQL Error
Vehicle: 2003/Acura/RSX
There are plenty of head units that use the same technology. JVC el kameleon is one. Someone could use that technology as a reference
12-21-2004, 03:52 PM
#4
I got the rhythm.
Vehicle: Mitsibushi FTO GPX V6
We are considering this by picking up on the engines tacho froma relay card a level of sensitivity could be set in the seetings in any case
Co Develper of A.I.M.E.E Automotive Intelligent Multimedia Entertainment Engine
www.aimee.cc
12-21-2004, 03:59 PM
#5
I have one of those, how do I get that working??
12-21-2004, 04:10 PM
#6
FreeDrive Creator
Vehicle: Ferrari 360 (nearly)
could you just not increase the volume by the speed of the car.. ie. at 60mph the volume is increased by a extra 5%.. or to make it easy an extra 1% per 10 miles an hour extra.. so if a gps is connected then thats all you need. Its more road noise, then engine rev noise I would of thought..
12-21-2004, 04:35 PM
#7
Vehicle: 2001 Chevy Tahoe
Speed would make more sense than RPM. Your car moves faster in higher gears at the same RPM generating more noise from the road and wind. My factory Tahoe stereo has SCV or speed controlld volume.
ATVMS.com
12-21-2004, 04:40 PM
#8
Vehicle: Porsche Boxster S
We experimented with this a while ago based on the car speed from GPS, the fundamentals are easy really.
12-21-2004, 04:58 PM
#9
Vehicle: 2004 Chevy Silverado
up 50% at max rpm.
That big of a change in volume would be annoying and sound wierd you would have to make much smaller changes i think. My stock headunit in my chevy does this (using speed not rpm), the trick is gettin it to change gradually so you dont notice, also rpm def. wouldnt work, every time you shif the volume would drop and it would just not work. At least that's my opinion.
EPIA MII-1200, 512 MB Ram, Seagate 7200 RPM 160GB hard drive, Orinoco Gold with 5.5 dB external antenna, Lilliput 7" TS, DVD-ROM, M2-ATX, Rikaline 6010 GPS, Running Frodo Player
My Truckputer
12-21-2004, 05:48 PM
#10
Stank Cheese
Vehicle: 2001 Chevy Silverado escalade front end Posts: 69
Chevy's have been doing this for 15 years now. This is nothing new.
2.4 celeron
150 watt OPUS
micro atx
xp pro
tv/radio tuner card
audigy
Dual monitor Radeon
802.11G Mimo
xm pcr
dvd
gps
8" Lilliput touch screen
IGuidance
dual optimas
battery isolator
15" screen
My Truck
12-21-2004, 05:53 PM
#11
My Village Called
Vehicle: 1995 Lexus SC300 1997 Mazda Miata
RPMs would be a good way to change volume if you have lots of engine noise. Now speed from GPS is a good idea, but we'd have to remember the original volume also.
12-21-2004, 05:59 PM
#12
n00b 4 life
Vehicle: Mazda Bongo MPV
I'm sure I remember someone building a device that used a microphone to do this, and I believe he also 'subtracted' the audio output from the sound in the same way that noise cancelling headphones work.
Sounds too complicated for me, but I'd add it if someone else designed it!
New Car
New Car computer will follow........
(Gazes at pile of components)
12-21-2004, 06:11 PM
#13
Of course... those were just example values. A final program would also allow the user to adjust sensitivity.
Agreed
Maybe if the RPM sensor had a "damper" on it. If a sudden change in rpm was sensed, it would wait X amount of seconds to change the volume. Every car would be different, so I am assuming that a program would need a big INI file and require the user to experiment with settings.
Now speed from GPS is a good idea.
I would prefer a direct interface to the car's computer using OBD. No down time if you have a crappy GPS.
Yea.. wow.. um.. does your PC do it?
This isn't the "stock chevy head-unit" forum...
12-21-2004, 06:15 PM
#14
My Village Called
Don't have a crappy GPS
12-21-2004, 06:16 PM
#15
haha, well... it does take the gps a minute or two to lock in. Wouldn't you rather have this feature running immediately?
| Thread Tools |
| Display Modes |
Linear Mode
