The MP3car.com Store
Go Back   MP3Car.com > Mp3Car Technical > Software & Software Development
Thread Tools Display Modes
Old 01-25-2005, 08:19 PM   #16
Raw Wave
tj!2k4's Avatar
My Photos: (1)
Quote: Originally Posted by dodgetimes2
Updated "Warning" screen.
I was thinking about doing that.. except with the Ford logo
Dr. Ron Paul for President 2008
Hope for America - http://www.ronpaul2008.com
Who is Ron Paul? - Why do we need Ron Paul?
CarPC Newbs Start Here: All your questions answered, as if by E.S.P.
tj!2k4 is offline   Reply With Quote
Sponsored Links
Old 02-02-2005, 07:31 PM   #17
Talon's Avatar
Vehicle: 2001 Lotus Esprit V8 / 2001 Lincoln LS
My Photos: (0)
Slick hack - worked great for me
www.carolinacarclubs.com
Talon is offline   Reply With Quote
Old 02-03-2005, 09:16 PM   #18
Raw Wave
tj!2k4's Avatar
My Photos: (1)
Quote: Originally Posted by rjoek
Nice. Had never heard of this. Just used it to modify Window name of XtreMe PCR -- had been having problems getting Centrafuse to embed the window named 'XtreMe PCR'. Changed it to 'XM', now it embeds like a champ, no problems.
Do you remember the location where you changed the window title from "Xtreme PCR" to "XM"? I've been looking, but can't seem to find it..
Thanks..
Old 02-05-2005, 09:37 AM   #19
Vehicle: 2002 Acura RSX-S
My Photos: (0)
I found every instance of 'XtreMe PCR' and changed it to 'XM'. Actually, turned out the app changes it back by itself, and I can't find the entry where it gets the 'default' name from. If I leave the PCR unconnected, however, bringing up the 'connect' dialogue, it will remain 'XM'. Then start Centrafuse specifying window name XM and it will embed. Funny thing is, ultimately I *was* able to get it to embed as 'XtreMe PCR' but only after going through this business.
Wish I could help more -- I think it's generally a problem with how David has written the embedding portion of his software that seems to give less than perfect results. Good luck!
rjoek is offline   Reply With Quote
Old 09-08-2005, 04:56 PM   #20
Vehicle: 02 Accord
My Photos: (0)
Quote: Originally Posted by antimatter
I just tried it in the car and it works perfectly. I think it was a windows 2000 problem
I am not having any luck with Centrafuse 2. Are you using version 2 because I have followed every step in this thread and all I get is a white screen. In version 2 Navigation is listed under Apps and I have changed the Eternal XML file to call up the folder with the routislauncher.ini file in it. I am pretty sure I have not made a misstake.
dapure is offline   Reply With Quote
Sponsored Links
Old 09-08-2005, 06:19 PM   #21
Raw Wave
tj!2k4's Avatar
My Photos: (1)
Look in the CF options and see if you have ONTOP enabled. If you do, turn it off.
Old 09-08-2005, 08:03 PM   #22
Vehicle: 02 Accord
My Photos: (0)
I have tried almost everything possible. I even tried changing the other parameters. The only thing I can get is a white screen to come up. I have also tried changing the directory name in External.xml. I noticed that you had yours directed to RoutisLauncher.exe. I have no such file. I only have RoutisLauncher.ini and I have set the correct directory for iGuidance and I changed the caption to Warning. In CF the app is directed to the folder with RoutisLauncher.ini in it. I am not sure why it won't work. At this point it is almost too much trouble for what it's worth.
My Project
Old 09-08-2005, 10:05 PM   #23
PURDooM's Avatar
Vehicle: 2008 Toyota Prius
My Photos: (0)
Why not use more up to date apps?
iglaunch:
http://www.mp3car.com/vbulletin/show...light=iglaunch
for greater pimpness:
http://www.mp3car.com/vbulletin/showthread.php?t=53988
and you could try the one in my sig if you like awesome programs that are a work in progress but not quite finished yet.
Current projects: iGmod reloaded (Latest release) (put on hiatus indefinatly)
Unlimited Internet and gps tracking for $6 a month with boost mobile!
Carputer 2: www.lmaocar.com
PURDooM is offline   Reply With Quote
Old 09-08-2005, 11:35 PM   #24
-zip-'s CarPC Specs
-zip-'s Avatar
Vehicle: 2000 Protege
My Photos: (1)
Bookmark
Carputer
Installed Since April 2, 2005
Intel D201GLY|Fusion Brain|Audigy2 NX||ODBPros ODBII|Engenius362ext |Motorized lilli|GPS Rikaline 6010|Opus 150|Powermate|Ergonomic Touchpad|
Sound Stage
Eclipse CD8455|MTX TA3404+421D|Infinity Comps|ID 12" Sub
-zip- is offline   Reply With Quote
Old 09-10-2005, 11:57 AM   #25
asci01's Avatar
Vehicle: Lexus GS300
My Photos: (0)
I also get a white screen even though ONTOP is turned off.
Any ideas how to solve this?
My Car PC
asci01 is offline   Reply With Quote
Old 09-10-2005, 01:47 PM   #26
Raw Wave
tj!2k4's Avatar
My Photos: (1)
Does it work properly if you just run the RoutisLauncher.exe by itself (ie not embedded in any frontend)?
Sponsored Links
vB code is On
Trackbacks are Off
Will the Toshiba LTM10C021 (10.4") LCD work ok with an AD2 (standalone) controller? pooshda LCD/Display 4 11-18-2002 08:59 PM
What do I need to make this LCD work with compoosite video? pigseye General Hardware Discussion 5 02-19-2002 08:36 PM
50 pin on board connector, 30 pin lcd cable-> Can I make it work? crazyshaxs LCD/Display 2 10-07-2001 11:43 AM
Whats requried to make the EIO.com 5" display work Squeezer General Hardware Discussion 1 07-15-2000 02:20 PM
Can you make a portable TV work? type2guy General Hardware Discussion 1 08-23-1999 10:39 PM
Sponsored Links
SEO by vBSEO 3.1.0
Ad Management by RedTyger
