The MP3car.com Store
Go Back   MP3Car.com > Mp3Car Technical > Software & Software Development
Thread Tools Display Modes
Old 01-22-2005, 05:12 PM   #1
dodgetimes2's Avatar
Vehicle: 99/Dodge/Durango and 97/Dodge/Ram
My Photos: (0)
How to make Frodo's RoutisLauncher work with iGuidance
Not sure if you guys are still having trouble getting rid of the warning screen in iGuidance, but here's a new way (I think). By using info from these 2 threads
http://www.mp3car.com/vbulletin/showthread.php?t=29610
http://www.mp3car.com/vbulletin/showthread.php?t=37702
I was able to figure out a way to make Frodo's RoutisLaunch work with iGuidance. Once I read that Frodo was looking for the Dialog window name ("Warning" in Routis) and noticed that by using the Resource Hacker program you could change the iGuidance Dialog window name from blank to "Warning" I discovered that Frodo's RoutisLauncher works with iGuidance. Use Resource Hacker to change the warning window's Dialog name, it is located in "Dialog", "1028", "1033". Once you have the right file edit the CAPTION = "" to CAPTION = "Warning", save the changes. Then download Frodo's RoutisLauncher (if you don't already have it) and edit the RoutisLauncher.ini file to point to the proper directory where iGuidance is installed and change the DELAY to 0 (this way you will barely even see the warning). Only problem is now I have embedding issues with some of the frontends used here.
1.6GHz HP e-PC, 768MB RAM, 120GB WD HDD, Slim DVD-ROM, Onboard sound & video, 7" Lilliput, USB GPS Mouse, Audiovox FM Modulator, Vector 400 Watt Power Inverter, Windows XP Pro SP2, iGuidance 2, 15" Samsung LCD for the rear *Carputer not installed*
dodgetimes2 is offline   Reply With Quote
Sponsored Links
Old 01-22-2005, 07:37 PM   #2
SMKFree
liquid_smoke's Avatar
Vehicle: VW Passat
My Photos: (0)
nice
liquid_smoke is offline   Reply With Quote
Old 01-22-2005, 08:37 PM   #3
My Photos: (0)
Update:
I now have this working flawlessly with Centrafuse and also hacked up a nicer warning screen for the hell of it.
Old 01-22-2005, 08:57 PM   #4
My Village Called
0l33l's CarPC Specs
0l33l's Avatar
Vehicle: 1995 Lexus SC300 1997 Mazda Miata
My Photos: (0)
NaviVoice has a launcher for iGuidance/Routis. Too bad there's no way to send command line parameters through CF and Frodo's command line parameters are broken till take4
PowerVoice v1 | NaviVoice Source
GammaControl v2.4
SKINbedder v3
1995 Lexus SC300 <-- Weekend Car
1997 Mazda Miata <-- Daily Driver
0l33l is offline   Reply With Quote
Old 01-23-2005, 06:06 PM   #5
Raw Wave
tj!2k4's Avatar
My Photos: (1)
Very Nice!
To further add, if you were to change the string "Warning" to "Loading GPS Module" in:
String Table -> 376 -> 1033 -> 6007
and change the warning message (can't remember exactly what it says) to "\n" in:
String Table 379 -> 1033 -> 6058
you wind up with something that looks even more informational, and even less like your computer's gonna blow up..
I still had to modify the height of the dialg box, that was where we originally modified the Window caption to Warning:
Dialog -> 1028 -> 1033 - modified values are bold
1028 DIALOG 0, 0, 137, 75
STYLE WS_POPUP | WS_CAPTION
CAPTION "Warning"
LANGUAGE LANG_ENGLISH, SUBLANG_ENGLISH_US
FONT 10, "Tahoma"
CONTROL "OK", 1, BUTTON, BS_OWNERDRAW | WS_CHILD | WS_VISIBLE | WS_TABSTOP, 28, 50, 40, 15
CONTROL "Cancel", 2, BUTTON, BS_OWNERDRAW | WS_CHILD | WS_VISIBLE | WS_TABSTOP, 78, 50, 40, 15
CONTROL 158, 611, STATIC, SS_BITMAP | WS_CHILD, 33, 4, 69, 13
Dodgetimes2, thanks for the info!
Dr. Ron Paul for President 2008
Hope for America - http://www.ronpaul2008.com
Who is Ron Paul? - Why do we need Ron Paul?
CarPC Newbs Start Here: All your questions answered, as if by E.S.P.
tj!2k4 is offline   Reply With Quote
Old 01-23-2005, 07:23 PM   #6
My Photos: (0)
I was wondering where that red "Warning" text was, thanks, I changed mine to look like yours, much better. Just wish the Main Menu would work like I want it.
Old 01-23-2005, 11:54 PM   #7
Jesus Freak
antimatter's CarPC Specs
antimatter's Avatar
Vehicle: 2006 Mazda Mazdaspeed 6 GT
My Photos: (0)
You guys ROCK...
So now yours embeds properly into CF?
I was having problems with that. WHat are you centrfuse settings for the gps portion?
What screen name and path do you use?
antimatter is offline   Reply With Quote
Old 01-24-2005, 12:03 AM   #8
Raw Wave
tj!2k4's Avatar
My Photos: (1)
Quote: Originally Posted by antimatter
You guys ROCK...
Window name for embedding iGuidance in Centrafuse is just "iGuidance" (no quotes, sorry if it's overkill to state that) and the path needs to point to wherever you have the Routislauncher files, since the location of iGuidance.exe is specified in the Routislauncher.ini. I just extracted them into the same dir as iGuidance is in.
So, in my case, as described above, the CF config looks like this:
GPS Path:
C:\Program Files\iNav\iGuidance\Routislauncher.exe
GPS Window Name:
iGuidance
And Routislauncher.ini looks like this:
[MAIN]
PATH=C:\Program Files\iNav\iGuidance\iGuidance.exe
Delay=0
Interestingly enough, prior to using Routislauncher, iGuidance would sometimes embed off-center when launched, but if I went to Music and then back, it would be fine. Since I started using the launcher, it now embeds perfectly every time. =)
Old 01-25-2005, 12:29 PM   #9
Jesus Freak
antimatter's Avatar
My Photos: (0)
GPS Path:
GPS Window Name:
iGuidance
[MAIN]
Delay=0
Sweet. It's time to give centrafuse a try
Old 01-25-2005, 12:47 PM   #10
Vehicle: 2002 Acura RSX-S
My Photos: (0)
Nice. Had never heard of this. Just used it to modify Window name of XtreMe PCR -- had been having problems getting Centrafuse to embed the window named 'XtreMe PCR'. Changed it to 'XM', now it embeds like a champ, no problems.
I also make heavy use of AutoIt for stuff like this -- that's how I wrote a simple script to click the acknowledgement for iGuidance. I don't have any VB programming experience so I can write simple scripts like this to do just about anything, works great. Ex: when I was running FrodoPlayer I made a script that added a GPS button to all screens: it would run in the background and wait until a certain portion of the screen was pressed. Then it would send the key commands/mouse clicks to switch to my GPS app (in my case iGuidance, with FP in mini-mode). Then I just modified the screens of the skin to include a GPS button on all of them. Could do this from Music, XM, external app, anywhere. It's a simple way to 'add in' any functionality of your choice until the next release of your favorite front end.
rjoek is offline   Reply With Quote
Sponsored Links
Old 01-25-2005, 12:51 PM   #11
VanMan69's Avatar
Vehicle: 1995 Chevy G20 Van
My Photos: (0)
Quote: Originally Posted by dodgetimes2
Update:
Oh crap! Run for your lives! The GPS module is loading!
95 Chevy G20 Vroom Boom Room
...with a whole bunch of nifty ****... go check it out: VanDomain Page
VanMan69 is offline   Reply With Quote
Old 01-25-2005, 01:49 PM   #12
Jesus Freak
antimatter's Avatar
My Photos: (0)
I am still having a problem embedding it in CF but i was able to do everything you did with resource hacker. Thanks for posting the settings.
I think my problem is that i am ruinning the test machine on Windows 2000. I will give it a shot on windows XP at lunchtime
Old 01-25-2005, 02:59 PM   #13
Jesus Freak
antimatter's Avatar
My Photos: (0)
I just tried it in the car and it works perfectly. I think it was a windows 2000 problem
Old 01-25-2005, 04:43 PM   #14
Raw Wave
tj!2k4's Avatar
My Photos: (1)
Werd? I've been using XtreMe PCR as well and only sometimes have a problem with it. What happens then is that it embeds that damn mini-mode player pos, but I sort-of was able to disable that. Now it happens maybe every one-out-of-twenty times.
Although.. once Frodo implements a window name in his standalone XM module, I'll start using that in Centrafuse, as it his app is hibernate-aware, and XtremePCR isn't.
Old 01-25-2005, 08:13 PM   #15
My Photos: (0)
Updated "Warning" screen.
Sponsored Links
vB code is On
Trackbacks are Off
Will the Toshiba LTM10C021 (10.4") LCD work ok with an AD2 (standalone) controller? pooshda LCD/Display 4 11-18-2002 08:59 PM
What do I need to make this LCD work with compoosite video? pigseye General Hardware Discussion 5 02-19-2002 08:36 PM
50 pin on board connector, 30 pin lcd cable-> Can I make it work? crazyshaxs LCD/Display 2 10-07-2001 11:43 AM
Whats requried to make the EIO.com 5" display work Squeezer General Hardware Discussion 1 07-15-2000 02:20 PM
Can you make a portable TV work? type2guy General Hardware Discussion 1 08-23-1999 10:39 PM
Sponsored Links
SEO by vBSEO 3.1.0
Ad Management by RedTyger
