The MP3car.com Store
Go Back   MP3Car.com > Mp3Car Technical > Software & Software Development
Thread Tools Display Modes
Old 02-04-2005, 12:22 PM   #1
BiohazrD's Avatar
Vehicle: 1994/Dodge/Spirit
My Photos: (0)
Damn visual basic
Check this out...
Code:
Imports System.IO Public Class Form1 Inherits System.Windows.Forms.Form Private fu As Form1 Private WithEvents fs As Form2 Public Shared nick As String Public Shared server As String Private path As String Private sr As StreamReader Private sw As StreamWriter Private socket As New System.Net.Sockets.TcpClient Private connected As Boolean = False Private ss As System.Net.Sockets.NetworkStream Private encrypt As New encryption Private thread As System.Threading.Thread Private rtba(1) As RichTextBox Private lv As Integer #Region " Windows Form Designer generated code " #End Region Private Sub Form1_Load(ByVal sender As System.Object, ByVal e As System.EventArgs) Handles MyBase.Load rtba(0) = New RichTextBox TabPage1.Text = "Main" TabControl1.Enabled = False MenuItem6.Enabled = False MenuItem7.Enabled = False path = "pr.dat" fs = New Form2 StatusBar1.Dock = DockStyle.Bottom StatusBar1.Text = "Disconnected" Try If Not File.Exists(path) Then : goSettings() Else sr = New StreamReader(path) nick = sr.ReadLine() server = sr.ReadLine() sr.Close() End If Catch ev As Exception MsgBox("You cannot run this program from a network share") End End Try End Sub Private Sub processinput(ByVal x As String) If x.StartsWith("do>") Then 'process the function ElseIf x.StartsWith("pm>") Then 'send to right index Else : rtba(0).AppendText(x) End If End Sub Private Sub TabControl1_SelectedIndexChanged(ByVal sender As System.Object, ByVal e As System.EventArgs) Handles tabcontrol1.SelectedIndexChanged mainchatbox = rtba(TabControl1.SelectedIndex()) If Not TabControl1.SelectedIndex = 0 Then MenuItem6.Enabled = True MenuItem7.Enabled = True Else MenuItem6.Enabled = False MenuItem7.Enabled = False End If End Sub Private Sub ListBox1_DoubleClick(ByVal sender As System.Object, ByVal e As System.EventArgs) Handles ListBox1.DoubleClick TabControl1.Enabled = True If Not ListBox1.SelectedIndex = -1 Then TabControl1.Controls.Add(New TabPage(ListBox1.SelectedIndex.ToString())) ReDim rtba(rtba.Length() + 1) rtba(TabControl1.SelectedIndex()) = New RichTextBox End Sub Private Sub MenuItem6_Click(ByVal sender As System.Object, ByVal e As System.EventArgs) Handles MenuItem6.Click TabControl1.Controls.RemoveAt(TabControl1.SelectedIndex) For lv = TabControl1.SelectedIndex To TabControl1.TabCount - 1 rtba(lv) = rtba(lv + 1) Next ReDim rtba(rtba.Length() - 1) End Sub Private Sub MenuItem4_Click(ByVal sender As System.Object, ByVal e As System.EventArgs) Handles MenuItem4.Click save() End End Sub Private Sub MenuItem2_Click(ByVal sender As System.Object, ByVal e As System.EventArgs) Handles MenuItem2.Click goSettings() End Sub Private Sub MenuItem3_Click(ByVal sender As System.Object, ByVal e As System.EventArgs) Handles MenuItem3.Click If Not connected Then Try socket.Connect(server, 6667) StatusBar1.Text = "Connected" Button1.Enabled = True MenuItem3.Text = "Disconnect" ss = socket.GetStream thread = New Threading.Thread(AddressOf checkstream) Catch ev As Exception MsgBox("Could not connect to server.", MsgBoxStyle.Exclamation, "Connection Error") End Try Else socket.Close() StatusBar1.Text = "Disconnected" Button1.Enabled = False MenuItem3.Text = "Connect" ss.Close() End If End Sub Shared Sub changeNickWhileConnected(ByVal x As String) 'send new nick to server nick = x End Sub Public Sub f2c() Handles fs.ev Me.Enabled = True save() End Sub Private Sub Button1_Click(ByVal sender As System.Object, ByVal e As System.EventArgs) Handles Button1.Click sw.WriteLine(textEnter.Text) textEnter.Text = "" End Sub Private Sub checkstream() If Not sr.Peek = -1 Then : processinput(sr.ReadLine) End If End Sub Private Sub save() sw = New StreamWriter(path) sw.WriteLine(nick) sw.WriteLine(server) sw.Flush() sw.Close() End Sub Public Sub goSettings() fs.TextBox1.Text = nick fs.TextBox2.Text = server If connected Then fs.TextBox2.Enabled = False End If Me.Enabled = False fs.Visible = True End Sub End Class
For some reason, the tab index changed method runs before form_load, and its ******* everything up.
Quick! To the Popemobile!
BiohazrD is offline   Reply With Quote
Sponsored Links
Old 02-04-2005, 12:39 PM   #2
IntellaWorks's Avatar
Vehicle: 2005 Toyota Tacoma
My Photos: (0)
Step through with the debugger go through line for line...
Take a quick break b4 you do it though sometimes walking away for a bit helps...
Good luck
Progress [I will seriously never be done!]
Via EPIA MII
512MB RAM
OEM GPS (embedded)
nLite WinXP pro on
1GB Extreme III CF card
Carnetix 1260 startup/ DC-DC regulator
Software: Still, re-Writing my existing front end in .Net
IntellaWorks is offline   Reply With Quote
Old 02-04-2005, 01:10 PM   #3
cheap custom title
JC-S60's CarPC Specs
JC-S60's Avatar
Vehicle: Volvo V70 | Mitsubishi Canter | BMW R1200GS Adventure | Yamaha YZF600R | Honda CB650
My Photos: (0)
or the ugly fix: doevents
JC-S60 is offline   Reply With Quote
Sponsored Links
vB code is On
Trackbacks are Off
Visual Basic Question???? chuckctv Software & Software Development 9 12-28-2004 11:25 AM
FREE Visual Basic .NET SE & ASP.NET Development Book hevnsnt Software & Software Development 3 10-06-2004 10:22 AM
Radio visual basic BT878 NEO Software & Software Development 0 10-31-2003 04:28 PM
Adding Gamepad input in Visual Basic UBCSJonw Software & Software Development 1 09-10-2003 08:00 PM
i need a visual basic OCX for an generic infrared receiver babas151 Software & Software Development 9 04-20-2002 02:10 AM
Sponsored Links
SEO by vBSEO 3.1.0
Ad Management by RedTyger
