Go Back   MP3Car.com > Mp3Car Technical > Software & Software Development
Old 04-22-2000, 12:15 AM   #1
Phacade GSX
Question How to disable Win98 safe mode menu?
Does anyone know how to disable the menu that pops up when Win98 doesn't get a chance to fully load? If the power is cutoff while the OS is loading, you get the menu that says something like "Windows did not fully load on the previous boot, it is recommended that you start in safe mode". By default, Safe mode is selected.
Is there a way to disable this menu so that Windows will boot into normal mode no matter what? I've already checked TweakUI but there doesn't seem to be a way to disable this from there.
Thanks,
Marlin
Phacade GSX is offline   Reply With Quote
Advertisement Sponsored links
Old 04-27-2000, 08:37 AM   #2
markus
Cool
Sorry for not answering earlier but I have been on vacation ...
Here is what to do:
Edit the c:\msdos.sys and make sure you have the folowing settings:
BootMenu=0
BootWarn=0
AutoScan=0
It should do the trick.
// Markus
More information aboute the msdos.sys options....
The [Options] section can contain the following settings and must be
manually inserted:
AutoScan=<Number>
Default: 1
Purpose: Defines whether or not ScanDisk is run after a bad shutdown.
A setting of 0 does not run ScanDisk; 1 prompts before
running ScanDisk; 2 does not prompt before running
ScanDisk but prompts you before fixing errors if any
errors are found.
This setting is used only by OEM Service Release 2 and
Windows 98.
BootMenu=<Boolean>
Default: 0
Purpose: A setting of 1 enables the Startup menu. If this setting is 0,
then you must press the F8 key when "Starting Windows 95"
appears, (or press and hold the CTRL key when your Windows
98-based computer restarts) to invoke the Startup menu.
BootMenuDefault=<Number>
Default: 1 if the system is running correctly
3 if the system hung in the previous instance
Purpose: Use this setting to set the default menu item for startup.
BootMenuDelay=<Number>
Default: 30
Purpose: This setting is used to set the number of seconds your system
will pause on the Startup menu. If the number of seconds counts
down to 0 without intervention, the BootMenuDefault is activated.
NOTE: This option is not functional unless BootMenu=1 has been added to
the [Options] section of the Msdos.sys file.
BootWarn=<Boolean>
Default: 1
Purpose: A setting of 0 disables the safe mode boot warning message and
the Startup menu.
markus is offline   Reply With Quote
Old 04-28-2000, 12:34 AM   #3
Kevin
Question
Hi Markus,
I'm confused. I don't have either bootMenu or BootWarn in my MSDOS.sys but I still get the safe boot menu if Win 98 doesn't load properly.
Kevin is offline   Reply With Quote
Old 04-28-2000, 02:52 AM   #4
markus
Post
Hello Kevin!
If you don't have them just add those lines to the [Options] section. You won't mess anything up.
Bootwarn=0 should make windows to never give a warning that Windows didn't boot as it should last time.
Just tell me if you don't get it working and I'll show you a sample.
[This message has been edited by markus (edited 04-28-2000).]
Old 04-30-2000, 10:57 AM   #5
Kevin
Talking
Worked great, Markus. Thanks a million!
Kevin
Old 04-30-2000, 12:43 PM   #6
markus
Post
Great =)
I hope it works for Phacade GSX too...
