The MP3car.com Store
Go Back   MP3Car.com > Mp3Car Technical > Software & Software Development
Thread Tools Display Modes
Old 08-02-2000, 03:49 AM   #1
My Photos: (0)
Exclamation Win98 - No Video card
Is there a way to trick Win98 into not having a Video card ?
My mother board supports it, but when booting into 98 without the video card plugged in it beeps and waits until I press Enter.
Any help would be great....
youngy is offline   Reply With Quote
Sponsored Links
Old 08-02-2000, 08:18 AM   #2
My Photos: (0)
Post
what do you mean "my motherboard support it" ??
As far as i know, the graphic beeping sound is not from windows or os. it is from bios start up recoginition.
noproblem is offline   Reply With Quote
Old 08-02-2000, 09:50 AM   #3
My Photos: (0)
Post
Have you set your bios to not halt on errors? (if you have award bios)
^insane is offline   Reply With Quote
Old 08-02-2000, 10:56 AM   #4
Registered User
My Photos: (0)
Smile
Yes,it is possible to use Win98 without video card.The beep that you hear when entering Win98 without video card warning you that your video card is not connected.You can disable this message,but you have to do some things:
First,install some program that allows you to remotely control another PC,like PC-Anywhere from Symantec.If you search the web you can find its trial version.That way you can control your MP3 player from another PC,and when you entering Windows,you should see this type of message:"Warning!Windows can`t detect your video adapter.Press Ok to continue",and near this you will see an option that says "Don`t show me this warning in future".Just disable the warning,and you won`t hear the beep again.
Enjoint life!
Dima is offline   Reply With Quote
Old 08-02-2000, 08:15 PM   #5
My Photos: (0)
Cool
Cheers Dima,
Other reply's (yes my bios has been set to ignore all error's, it was just windows halting.)
I have PC anywhere, but don't feelike adding the network stuff and PC anywhere to my nice clean install, which boots in 20sec from power up. not bad for a Cyrix 150...
Do you remember what the form looks like.. so I can just press tab and enter to disable it. (or where every keys).
Thanx's
Old 08-02-2000, 08:17 PM   #6
My Photos: (0)
Unhappy
ooops, some typos in last message...
Old 08-03-2000, 01:13 AM   #7
Registered User
My Photos: (0)
Smile
No,I don't remeber how it looks like.But once you disable the warning message,windows won't bother you anymore,so you can uninstall PC-Anywhere from your player.You probably asking how I will remove it without seeing what I am removing,and the solution is to disconnect your HD from player,connect it to your home PC as slave and then just delete it,and reconnect it to your player.
By the way,you don't need to add a network card,PC-Anywhere can operate from parallel ports.
Enjoint life!
Old 08-07-2000, 02:53 AM   #8
My Photos: (0)
Talking
Cheers,
I used PC Anywhere to get rid of the message, hooked up a LAN card and controlled it, but the display was **** house and couldn't read anything. but got through it.
NOTE for other users:
You press OK to past the fist message. then it goes through the hardware installation wizard. just click next, next, next etc. and make sure you have you cabs/cd ready to go from the same spot as you installed.You can get through it this way...
After intalling LAN and PC Anywhere the uninstalling, boot time has increaded by 8-10 seconds...
Hope this helps someone...
Old 08-07-2000, 06:29 PM   #9
My Photos: (0)
Question
I have PC-anyware But am Not able to Connect to remote Computer after I remove The video Card,,Is there A trick to it OR I'm being Stupid again..?
Meoff_Rulz
Meoff is offline   Reply With Quote
Old 08-07-2000, 08:44 PM   #10
My Photos: (0)
Post
You don't need all that complicated crap. This is what I thought... win98 has a stupid message that warns you you don't have a video card. of course you cant SEE the message so whats the point? argh... well there should be a key combo that you can do blind. Probably tab, then space, will check the box to "don't show this warning". Then just press enter. I'm going to try this on my machine. If this isn't the right key sequence someone correct it.
AtomicMass is offline   Reply With Quote
Sponsored Links
Old 08-07-2000, 08:48 PM   #11
My Photos: (0)
Post
Old 08-07-2000, 08:51 PM   #12
My Photos: (0)
Post
I though the same, but the dialog box had OK only. there was no switch that said don't ask me again.
once you hit OK it goes into the hardware isntallation wizard.
Old 08-08-2000, 05:49 AM   #13
My Photos: (0)
Post
I dunno if this works though I have not had time to try it myself.
But set up 2 hardware profiles where you disable the Video Card in one of them and set that as default.
Might work...
// Markus
markus is offline   Reply With Quote
Sponsored Links
vB code is On
Trackbacks are Off
Sponsored Links
SEO by vBSEO 3.1.0
Ad Management by RedTyger
