The MP3car.com Store
Go Back   MP3Car.com > Mp3Car Technical > Software & Software Development
Thread Tools Display Modes
Old 08-23-2000, 10:11 PM   #1
My Photos: (0)
Post Running Winamp On Startup
How do I run Winamp and not Explorer on startup? There is a way. I've seen it before but I forgot how.
d0mni is offline   Reply With Quote
Sponsored Links
Old 08-23-2000, 11:04 PM   #2
My Photos: (0)
Post
Change your shell to winamp in system.ini
Axkicker is offline   Reply With Quote
Old 08-24-2000, 06:32 AM   #3
My Photos: (0)
Post
Thanks. Do you know how you make it start up with a playlist?
Old 08-24-2000, 02:48 PM   #4
My Photos: (0)
Post
You can put the m3u file for your playlist (or a shortcut to the m3u file) in your startup folder; however, I don't know if this will work if you're running Winamp as your shell. I have read on this site that some people obtained significant boot time reductions by running Winamp as the shell. I tried it and noticed no significant reduction. Plus it's a bit inconvenient; having explorer around is kind of nice when you want to do things. I would definitely get and run 98Lite, though. There's a lot about it in previous posts.
Kevin is offline   Reply With Quote
Old 08-24-2000, 05:52 PM   #5
Registered User
My Photos: (0)
Post
If you're running Winamp as shell you can always push Ctrl+Esc to get the run command, type explore and load explorer when you need it.
Trav
1983 BMW 733i
Cyrix 166 32MB with MPXPLAY And no display. Player sits on the back seat with a keypad in front. Someday I'll mount this thing for good...
Gathering parts for carplayer v2.0!
Falcon62Travis is offline   Reply With Quote
Old 08-27-2000, 06:35 AM   #6
Bj
Vehicle: Toyota Hilux 1989
My Photos: (0)
Post
To run a playlist at startup, just add it to
the system.ini file like so.....
shell=c:\winamp\winamp.exe myplaylist.m3u
Enjoy
[This message has been edited by Bj (edited 08-27-2000).]
BjBlaster! Car MP3 & Carputer!
bjblaster.com
"The solution to one problem is only the begining of another"
Bj is offline   Reply With Quote
Old 09-02-2000, 03:10 PM   #7
My Photos: (0)
Post
Ok, you have winamp as shell...
now is it possible to load another application e.g. remote control software?
Thanx
Italia>
ItaliaAW is offline   Reply With Quote
Old 09-03-2000, 10:03 AM   #8
Vehicle: '97 Mustang Cobra
My Photos: (0)
Post
ItaliaAW: yes, i think under win.ini. Add it to load=c:\remotecontrol\remote.exe
or what ever the exe is. Also there is a place in registry you can add the startup items. I don't remmember where it is. I am sure someone in here knows or you can search through MS homepage.
abcd-1
abcd-1
cenwesi is offline   Reply With Quote
Old 09-03-2000, 03:37 PM   #9
Registered User
My Photos: (0)
Post
To do this with he registry you open up regedit, goto HKEY_LOCAL_MACHINE\Software\Microsoft\Windows\Curr ent Version\Runservices
Add the string there. There are other similar folders there like 'runonce' that if you use them your program will run the next time you reboot but never again on startup (Hence the name)
Anyway, to add the string Click edit, New, String Value, Name the string whatever and open the new string.
Then put the path in (Such as C:\mpxplay\mpxplay.exe) and reboot your computer to see if it worked.
If you are new to the registry (Or not) I would suggest backing up the registry before changing anything. It's alot nicer to just restore the Registry than it is to rebuilt your box!
1983 BMW 733i
Sponsored Links
vB code is On
Trackbacks are Off
Sponsored Links
SEO by vBSEO 3.1.0
Ad Management by RedTyger
