The MP3car.com Store
Go Back   MP3Car.com > Mp3Car Technical > Software & Software Development
Thread Tools Display Modes
Old 04-04-2005, 01:19 AM   #1
My Village Called
0l33l's CarPC Specs
0l33l's Avatar
Vehicle: 1995 Lexus SC300 1997 Mazda Miata
My Photos: (0)
iGLaunch v2 - Routis/iGuidance Nag Remover + More
Configurable Routs/iGuidance Nag Screen remover. This works with centrafuse. No multiple instances of iGuidance or Routis. This also resumes the GPS if the computer resumes from hibernation. Comments, suggestions, etc welcome
Code:
Version History [v2] *New Features* -------------- -Reconnect GPS on resume Will click on the COMM port after coming out or Resume *How To* ----------------- -iGLauncher.ini FILENAME - Self-explanatory DIRECTORY - Self-explanatory PARAMETERS - Self-explanatory COMMPORT - The COMM port that the GPS is on for Resume RECONNECTGPS - TRUE or FALSE
Download v2
PowerVoice v1 | NaviVoice Source
GammaControl v2.4
SKINbedder v3
1995 Lexus SC300 <-- Weekend Car
1997 Mazda Miata <-- Daily Driver
0l33l is offline   Reply With Quote
Sponsored Links
Old 04-04-2005, 09:43 AM   #2
gizak's Avatar
Vehicle: 2002/Nissan/Sentra
My Photos: (0)
Gonna try this out as soon as I get back to the car!
-GiZak-
Carputer Project: 98% Complete!! *tweakin'*
Xenarc 7TSV | Opus 150 | Biostar M7NCG400 | Athlon Mobile2200 | Seagate 160Gb | Kingston 2x256mb | BT Holux GR-231 GPS | LiteOn CD-R/DVD| Keyhole Rev. Cam | Zippy Mini-glow Keyboard
gizak is offline   Reply With Quote
Old 04-04-2005, 06:05 PM   #3
My Village Called
0l33l's CarPC Specs
0l33l's Avatar
My Photos: (0)
It works out great on paper, just hope it works in the car
Also, I'm not sure if you have to have the GPS app be visible before hibernation.
GammaControl v2.4
SKINbedder v3
Old 04-06-2005, 01:53 AM   #4
My Village Called
0l33l's CarPC Specs
0l33l's Avatar
My Photos: (0)
Anyone get it working?
GammaControl v2.4
SKINbedder v3
Old 04-06-2005, 08:23 AM   #5
-zip-'s CarPC Specs
-zip-'s Avatar
Vehicle: 2000 Protege
My Photos: (1)
Port it over to Frodo and I will
Carputer
Installed Since April 2, 2005
Intel D201GLY|Fusion Brain|Audigy2 NX||ODBPros ODBII|Engenius362ext |Motorized lilli|GPS Rikaline 6010|Opus 150|Powermate|Ergonomic Touchpad|
Sound Stage
Eclipse CD8455|MTX TA3404+421D|Infinity Comps|ID 12" Sub
-zip- is offline   Reply With Quote
Old 04-06-2005, 10:15 AM   #6
gizak's Avatar
My Photos: (0)
I gave this a shot since the other solution was in fact opening multiple instances of iguidance when used in CF. I thought this was working fine at first, but realized later that it wasn't. Maybe I'm doing something wrong... Also, I'm not a coder, so wasn't sure what to put in the parameters field (i guess it isn't self-explanatary to noobs lol). Also, I don't think it matters, but I'm using a BT GPS unit.
-GiZak-
Old 04-06-2005, 12:21 PM   #7
My Village Called
0l33l's CarPC Specs
0l33l's Avatar
My Photos: (0)
What do you mean? You can use with with FP. Just change the filename to my program.
Don't put anything in the PARAMETERS field. Also after installing it and configuring it to workin CF, restart CF. Don't forget to set the window caption to "iGuidance".
GammaControl v2.4
SKINbedder v3
Old 04-06-2005, 04:50 PM   #8
gizak's Avatar
My Photos: (0)
Yea, I left PARAMETERS blank, and I assume you mean to put the window caption in CF to "iGuidance" , which I did. It was really weird, I'll tinker around with it some more, cause I could have sworn it was working when I first used it, but anytime thereafter, the nag screen popped and stayed.
-GiZak-
Old 04-06-2005, 07:35 PM   #9
My Village Called
0l33l's CarPC Specs
0l33l's Avatar
My Photos: (0)
Restart CF. Also check if either applications is running. Just do a full shutdown
GammaControl v2.4
SKINbedder v3
Old 04-07-2005, 10:24 PM   #10
carpcnoobie's Avatar
My Photos: (0)
How does this work with RR?
Progress Meter:
[|||||!||||'] 95% complete
It's in... it's finally installed!!!! But never finished!
"It works! It works! I've finally invented something that works!" -- Doctor Emmit Brown
carpcnoobie is offline   Reply With Quote
Sponsored Links
Old 04-08-2005, 01:08 AM   #11
silencery's Avatar
Vehicle: 2001 Toyota MR-S
My Photos: (0)
doesn't work for me I think the m10000 might be too slow... it seems to be sending the click before iGuidance has a chance to finish caching.
EDIT oh yeah, is the hibernate function supposed to work for resume from suspend as well? Cuz that doesn't work either.. hehe
Stealth OEM spyder
1204 dot net!
silencery is offline   Reply With Quote
Old 04-08-2005, 08:24 AM   #12
My Photos: (0)
I seem to be having the same problem. Not quite waiting long enough for slower systems.
Also, coming out of hibernation sometimes I could get it to work, other times (for some reason) it changed the com port on Routis to 1.
Progress Meter:
Old 04-08-2005, 10:20 AM   #13
gizak's Avatar
My Photos: (0)
Well, it was working for a while, and now it's not working again! It's pretty strange. FYI, I do a full reboot each time, not a hibernate. It seems as it works fine anytime I use CF + Iguidance after the first time of clicking through the nag, so as long as my OS is up and running there's no prob. -but since I do a full reboot each time, I still have the nag screen pop up and stay randomly.
-GiZak-
Old 04-08-2005, 11:28 AM   #14
My Village Called
0l33l's CarPC Specs
0l33l's Avatar
My Photos: (0)
It should. Hopefully it does. But sonce people running CF are having problems with it then I guess not
Hmm.. i wonder why it is sending the click before it gets a chance to load. I specifically wait for the nag screen to open before sending commands. Weird.
I trap the resume command. So it should work.
Yeh, it sounds like its not waiting long enough. Great
Do you have CF to start up right on startup?
GammaControl v2.4
SKINbedder v3
Old 04-08-2005, 11:35 AM   #15
gizak's Avatar
My Photos: (0)
^Yes I do.
I also tried adding iguidance to startup as well so that it would open and remove nag screen (this works fine!) before clicking on "GPS" in CF in hopes it would resolve it, but I think it only caused a multiple instance of CF to open.
-GiZak-
Sponsored Links
vB code is On
Trackbacks are Off
iGLaunch - Routis/iGuidance Nag Remover 0l33l Software & Software Development 7 04-04-2005 01:20 AM
Sponsored Links
SEO by vBSEO 3.1.0
Ad Management by RedTyger
