Go Back   MP3Car.com > Mp3Car Technical > Software & Software Development
Old 04-23-2005, 10:34 AM   #1
Phone Control Moderator
zorro's Avatar
VisualDesigner for creating other skins
Hi folks,
I've added some code to (PhoCo's) VisualDesigner to make it a bit more versatile.
By applying the command line parameter -Other=xxx users are now able to create a new design from scratch by adding controls (Buttons, Panels, Listboxes) and export that new design to any format needed.
The export constsist of two major functions:
1. All elements on the main form will be merged with the background and saved as two bitmaps (Jpeg or Png), one for the normal state and one for the clicked state.
2. A Export-Provider is called (using COM) and all elements contained on the form will be reported to the Export-Provider. The provider is responsible to create a customized INI file that can be used with any other application.
Since the design is not only exported but also saved in a VD format (XML), designers are able to reload the skin and apply changes whenever needed very quickly.
At this stage, there is only one sample Export-Provider which doesn't really do anything but shows how to use it.
Developers who are interessted in making Export-Providers for their apps, please let me know.
Designers can use is to create / edit skins for any app but they have to wait for Export-Providers to become available.
Here's a short instruction what you gotta do to get this VD version:
  • Download and install the latest version of PhoneControl.NET if you didn't already (VD is a part of it)
Skinning to go... VisualDesigner2!
zorro is offline   Reply With Quote
Old 04-23-2005, 01:58 PM   #2
My Village Called
0l33l's Avatar
Looks awesome! But can we also get a permanent clicked state? So say if we're having relays that are on, you don't want the button to turn to the original state. Then that would require 2 more images
This would be a great way to create "universal" skins
PowerVoice v1 | NaviVoice Source
GammaControl v2.4
SKINbedder v3
1995 Lexus SC300 <-- Weekend Car
1997 Mazda Miata <-- Daily Driver
0l33l is offline   Reply With Quote
Old 04-23-2005, 02:05 PM   #3
zorro's Avatar
What is the difference between a clicked state and a permanent clicked state (seen from the graphics side)?
Old 04-23-2005, 02:08 PM   #4
My Village Called
0l33l's Avatar
Well, say that you have an "LED" on one of the buttons to know if a relay is on.
GammaControl v2.4
SKINbedder v3
Old 04-23-2005, 03:24 PM   #5
zorro's Avatar
Well... think about... I'm sure you'll find the answer.
Old 04-23-2005, 03:43 PM   #6
My Village Called
0l33l's Avatar
Hopefully
This project would really help me. My skin designer suxed.
BTW: Exporting to INI won't be required.. right?
GammaControl v2.4
SKINbedder v3
Old 04-23-2005, 04:33 PM   #7
zorro's Avatar
No, this is just a suggestion. Whatever the Export-Provider does, this is up to you.
Old 04-23-2005, 04:38 PM   #8
My Village Called
0l33l's Avatar
Great! Can't wait to test it
My email
GammaControl v2.4
SKINbedder v3
Old 04-23-2005, 05:33 PM   #9
kiltjim's Avatar
Seems pretty cool. So, if I understand correctly, you can use this to export skins to any other program, and then simply use the exported file in another program? I would love to try it out, I've been looking at some way to do this, as opposed to using a skinner made to work with one program, and then going back to edit the whole file to work for mine.
My email.
2000 Subaru OBS
Dell P3 @ 900 Mhz
7" Lilliput TS w/DigitalWW in-dash mount
80GB External HD
I am Zero Bitrate....
kiltjim is offline   Reply With Quote
Old 04-23-2005, 07:01 PM   #10
My Village Called
0l33l's Avatar
Some suggestions:
Have create buttons/listboxes/etc on a toolbar.
I didn't really find a setting for a "selected" image. Some designers use just 2 images, and create "hotspots" on the forums. I'm guessing that a panel can act as a hotspot.
The scale mode also doesn't work, just as you said:
Code:
See the end of this message for details on invoking just-in-time (JIT) debugging instead of this dialog box. ************** Exception Text ************** System.ArgumentException: Invalid parameter used. at System.Drawing.Bitmap..ctor(Int32 width, Int32 height, PixelFormat format) at System.Drawing.Bitmap..ctor(Int32 width, Int32 height) at System.Drawing.Bitmap..ctor(Image original, Int32 width, Int32 height) at System.Drawing.Bitmap..ctor(Image original, Size newSize) at PhoneCtlDesigner.frmMain.pnlWindow_Resize(Object sender, EventArgs e) at System.Windows.Forms.Control.OnResize(EventArgs e) at System.Windows.Forms.Panel.OnResize(EventArgs eventargs) at System.Windows.Forms.Control.OnSizeChanged(EventArgs e) at System.Windows.Forms.Control.UpdateBounds(Int32 x, Int32 y, Int32 width, Int32 height, Int32 clientWidth, Int32 clientHeight) at System.Windows.Forms.Control.UpdateBounds() at System.Windows.Forms.Control.WmMove(Message& m) at System.Windows.Forms.Control.WndProc(Message& m) at System.Windows.Forms.ScrollableControl.WndProc(Message& m) at System.Windows.Forms.ControlNativeWindow.OnMessage(Message& m) at System.Windows.Forms.ControlNativeWindow.WndProc(Message& m) at System.Windows.Forms.NativeWindow.Callback(IntPtr hWnd, Int32 msg, IntPtr wparam, IntPtr lparam) ************** Loaded Assemblies ************** mscorlib Assembly Version: 1.0.5000.0 Win32 Version: 1.1.4322.2032 CodeBase: file:///c:/windows/microsoft.net/framework/v1.1.4322/mscorlib.dll ---------------------------------------- PhoneCtlDesigner Assembly Version: 1.1.1939.40187 Win32 Version: 1.1.1939.40187 CodeBase: file:///C:/Program%20Files/PhoneControl.NET/PhoneCtlDesigner.exe ---------------------------------------- System.Windows.Forms Assembly Version: 1.0.5000.0 Win32 Version: 1.1.4322.2032 CodeBase: file:///c:/windows/assembly/gac/system.windows.forms/1.0.5000.0__b77a5c561934e089/system.windows.forms.dll ---------------------------------------- System Assembly Version: 1.0.5000.0 Win32 Version: 1.1.4322.2032 CodeBase: file:///c:/windows/assembly/gac/system/1.0.5000.0__b77a5c561934e089/system.dll ---------------------------------------- System.Drawing Assembly Version: 1.0.5000.0 Win32 Version: 1.1.4322.2032 CodeBase: file:///c:/windows/assembly/gac/system.drawing/1.0.5000.0__b03f5f7f11d50a3a/system.drawing.dll ---------------------------------------- Infragistics.Win.UltraWinToolbars.v3.1 Assembly Version: 3.1.20041.15 Win32 Version: 3.1.20041.15 CodeBase: file:///C:/Program%20Files/PhoneControl.NET/Infragistics.Win.UltraWinToolbars.v3.1.DLL ---------------------------------------- Infragistics.Shared.v3.1 Assembly Version: 3.1.20041.15 Win32 Version: 3.1.20041.15 CodeBase: file:///C:/Program%20Files/PhoneControl.NET/Infragistics.Shared.v3.1.DLL ---------------------------------------- Infragistics.Win.v3.1 Assembly Version: 3.1.20041.15 Win32 Version: 3.1.20041.15 CodeBase: file:///C:/Program%20Files/PhoneControl.NET/Infragistics.Win.v3.1.DLL ---------------------------------------- Infragistics.Win.UltraWinDock.v3.1 Assembly Version: 3.1.20041.15 Win32 Version: 3.1.20041.15 CodeBase: file:///C:/Program%20Files/PhoneControl.NET/Infragistics.Win.UltraWinDock.v3.1.DLL ---------------------------------------- Accessibility Assembly Version: 1.0.5000.0 Win32 Version: 1.1.4322.573 CodeBase: file:///c:/windows/assembly/gac/accessibility/1.0.5000.0__b03f5f7f11d50a3a/accessibility.dll ---------------------------------------- System.Design Assembly Version: 1.0.5000.0 Win32 Version: 1.1.4322.2032 CodeBase: file:///c:/windows/assembly/gac/system.design/1.0.5000.0__b03f5f7f11d50a3a/system.design.dll ---------------------------------------- System.Runtime.Serialization.Formatters.Soap Assembly Version: 1.0.5000.0 Win32 Version: 1.1.4322.2032 CodeBase: file:///c:/windows/assembly/gac/system.runtime.serialization.formatters.soap/1.0.5000.0__b03f5f7f11d50a3a/system.runtime.serialization.formatters.soap.dll ---------------------------------------- System.Xml Assembly Version: 1.0.5000.0 Win32 Version: 1.1.4322.2032 CodeBase: file:///c:/windows/assembly/gac/system.xml/1.0.5000.0__b77a5c561934e089/system.xml.dll ---------------------------------------- zyg9noqk Assembly Version: 0.0.0.0 Win32 Version: 1.1.4322.2032 CodeBase: file:///c:/windows/assembly/gac/system/1.0.5000.0__b77a5c561934e089/system.dll ---------------------------------------- zControls Assembly Version: 1.0.1939.35709 Win32 Version: 1.0.1939.35709 CodeBase: file:///C:/Program%20Files/PhoneControl.NET/zControls.DLL ---------------------------------------- Microsoft.DirectX.DirectSound Assembly Version: 1.0.1901.0 Win32 Version: 5.3.0000001.1126 built by: DIRECTX CodeBase: file:///C:/Program%20Files/PhoneControl.NET/Microsoft.DirectX.DirectSound.DLL ---------------------------------------- System.Drawing.Design Assembly Version: 1.0.5000.0 Win32 Version: 1.1.4322.573 CodeBase: file:///c:/windows/assembly/gac/system.drawing.design/1.0.5000.0__b03f5f7f11d50a3a/system.drawing.design.dll ---------------------------------------- ************** JIT Debugging ************** To enable just in time (JIT) debugging, the config file for this application or machine (machine.config) must have the jitDebugging value set in the system.windows.forms section. The application must also be compiled with debugging enabled. For example: <configuration> <system.windows.forms jitDebugging="true" /> </configuration> When JIT debugging is enabled, any unhandled exception will be sent to the JIT debugger registered on the machine rather than being handled by this dialog.
GammaControl v2.4
SKINbedder v3
Old 04-23-2005, 09:26 PM   #11
Raw Wave
RoyN's Avatar
OK, just confirming, this will let me make the buttons inside the designer? Hmm.. I think you have been reading my other posts!
Guino..... Time to stop coding RR and code a export-provider for making skins for rR....
RoyN is offline   Reply With Quote
Old 04-24-2005, 12:24 AM   #12
zorro's Avatar
Kind of... you still have to make the graphics by yourself (or get them from elsewhere) because VD is no drawing tool.
But as you know from PhoCo, you can move them, size them, hide/show them apply a caption and other stuff.
With the right Export-Provider, you event don't have to put the coordinates into a .skin / .ini file anymore.
Old 04-24-2005, 12:38 AM   #13
Raw Wave
RoyN's Avatar
I cant run the editor... always get this error straight after running "Phonectldesigner.exe -Other=test" or even without the -other tag....
already regged the dll...
Old 04-24-2005, 12:41 AM   #14
zorro's Avatar
Did you copy it to PhoCo's installation dir?
Old 04-24-2005, 12:47 AM   #15
Raw Wave
RoyN's Avatar
ops... now its working! hhehehe
Skins, skins, skins and... skins (and NOTHING MORE) netsuo NeoCar Media Center 42 12-21-2005 07:12 AM
STUPID question, never had an MP3 before. I don't understand what the skins show clean customs FrodoPlayer 4 01-21-2005 08:21 PM
how to load skins? i feel like a retard for asking this question...... cdougyfresh FrodoPlayer 3 12-02-2004 01:02 AM
Sigh...wish skins worked. Carter FrodoPlayer 4 09-20-2004 02:32 PM
Skins for 8" Lilliput Deepgear MediaCar 11 08-08-2004 05:34 PM
