Go Back   MP3Car.com > Mp3Car Technical > Software & Software Development
Old 06-23-2005, 07:46 PM   #1
Turning a 17" monitor into a 7" one
I currently have my carputer in my house while i set set up the skin for iGuidance and i want to check to see how the skin will look on a 7" monitor. I want to make lots of changes so constantly going back and fourth to my car would be a reall pain. Is there any software or option in windows that will allow me to use my 17" monitor as though it were a 7" one. Maybe something were I input the physical size of my lilliput monitor and that is the only potion of the 17" screen it displays on.
Thanks for the help!
dudical266 is offline   Reply With Quote
Old 06-23-2005, 10:41 PM   #2
My Village Called
0l33l's Avatar
VNC into your carpc maybe
PowerVoice v1 | NaviVoice Source
GammaControl v2.4
SKINbedder v3
1995 Lexus SC300 <-- Weekend Car
1997 Mazda Miata <-- Daily Driver
0l33l is offline   Reply With Quote
Old 06-23-2005, 10:42 PM   #3
Para Laura
thanatos106's Avatar
Or pcanywhere
thanatos106 is offline   Reply With Quote
Old 06-23-2005, 10:52 PM   #4
My Village Called
0l33l's Avatar
Quote: Originally Posted by thanatos106
Or pcanywhere
PCanywhere is a type of VNC
Notice I didn't say which VNC to use
GammaControl v2.4
SKINbedder v3
Old 06-23-2005, 11:08 PM   #5
Para Laura
that is why I'm giving him the name of one..... so he can look better in limeware (just kiding)
And to you:
Old 06-23-2005, 11:11 PM   #6
My Village Called
0l33l's Avatar
And to you:
Free ones are ultravnc and some other one. Search the forums for ultravnc
GammaControl v2.4
SKINbedder v3
Old 06-23-2005, 11:16 PM   #7
Para Laura
that **** is to hard to setup...
with PCanyware you just active the host enter the IP adress in the remote and that it (you can chat with the host..... and bla bla bla
Old 06-23-2005, 11:23 PM   #8
My Village Called
0l33l's Avatar
Resource hog?
Anyways, we answered that guy's question probably
Or he can just change the resolution on his monitor.
GammaControl v2.4
SKINbedder v3
Old 06-24-2005, 07:50 AM   #9
I have used Real VNC in the past, I think i will use it for this... That is a clever Idea...thanks
Also changing the res wont get me the proper aspect ratio as my 7" is a widescreen
Old 06-24-2005, 08:21 AM   #10
set the resolution you want and switch off stretching / hw expansion ?
Maximus is offline   Reply With Quote
Old 06-25-2005, 04:27 AM   #11
Banned
RPM_VR4's Avatar
XP's built-in Remote Desktop is way cooler then VNC.
RPM_VR4 is offline   Reply With Quote
Old 06-25-2005, 05:31 AM   #12
RS3RS's Avatar
What res. do you run the carputer monitor at? Just run your 17" at the same resolution that the lilliput runs at and be done with it. I run my Lilliput at 800x600, so for me all I would have to do is force my monitor to run at 800x600. You can do that at any resolution, let us know if you need help forcing it to display at the resolution you need it to.
RS3RS is offline   Reply With Quote
Old 06-25-2005, 10:22 AM   #13
Vchat20's Avatar
Your everyday carpc geek and tech guru at your service. *bow*
Vchat20 is offline   Reply With Quote
Old 06-25-2005, 10:34 AM   #14
Or better yet, install a frontend on your PC, such as Frodo or RoadRunner. Open it up and it will display on your desktop in a fairly close resolution to what your lilliput looks like. Open iGuidance and resize the window to the same as Frodo or RoadRunner. All you need to do is resize the iGuidance window to 800x480 (I think).
Jstarko0329 is offline   Reply With Quote
Old 06-25-2005, 01:17 PM   #15
Super Moderator
xBrady's Avatar
Real VNC is the best VNC alive. Oh did I mention that it is easy to set up and it's free?
Installed.
-GPSSecure- - GPS Tracking
xBrady is offline   Reply With Quote
CarTFT's MM400 7" and LinITX 7" same thing? loscooby LCD/Display 8 05-13-2005 12:40 PM
Problems turning my carputer on nappyjim Power Supplies 4 05-04-2005 09:21 PM
FS: DWW-7VGA 7" Touch Screen VGA LCD * Based on the Xenarc/Gain 7" VGA LCD faichiu Classified Archive 6 10-20-2004 02:30 AM
In-Dash 7" MOTOR TFT or Lilliput 7" Touch Screen JonX69 LCD/Display 2 03-06-2004 01:22 PM
FS: TM-70L 7" LCD & 7" Touch Screen Kit digitalww Classified Archive 0 01-29-2003 01:45 PM
