08-17-2005, 02:01 AM
#31
I'm sorry, and you are....?
I'll finish this up in the morning, it is working quite well.
[H]4 Life
I'm a lesbian too.
I am for hire!
08-17-2005, 07:24 AM
#32
Raw Wave
Frodo:
Are you seriously coding this thing? (I'm stoked!)
If so, are you able to completely CANCEL the triggering event? That is the crucial part.
Shutdown I believe power soff completely. Restart on the other hand, will reboot (power back up) right after shutting down.
Actually, in Windows looks like these are called: Turn Off, and Restart. I can see both options when I do start->turn off computer.
08-17-2005, 03:11 PM
#33
Yes, I am coding this. Yes it will CANCEL the event.
Even though you can choose restart/shutdown, programs
don't know the difference. Same with standby/hibernate.
Now, if someone sends the "force" command along with a shutdown
etc command, the app won't cancel that event, as it's not possible,
but in 99% of the cases the way windows is shutdown, that won't happen.
[H]4 Life
I'm a lesbian too.
I am for hire!
08-17-2005, 03:25 PM
#34
Raw Wave
Quote: Originally Posted by frodobaggins
Yes, I am coding this. Yes it will CANCEL the event..
THANK YOU!
Not sure why this is relevant. What 'Program' needs to know the difference, aside from the interceptor utility itself?
I think if I understand correctly, we don't have a problem here. The 'shutdown' sequence that would be generated is typically going to be sent by the Opus, which is in fact the same as pressing the Shutdown button on a PC case.
I can see how someone could attempt a forced shutdown via the DOS command 'shutdown -f' but that would never occur via the Opus.
Let me know when you have something to test, I will spend time with it!
08-17-2005, 03:29 PM
#35
The interceptor is a program too !
So you only have 3 events.
1. Shutdown/Restart
2. Log Off
3. Hibernate/Standby
[H]4 Life
I'm a lesbian too.
I am for hire!
08-17-2005, 04:07 PM
#36
Raw Wave
That's what I thought you were refering to.
Quite honestly, I only really will ever need to intercept the hibernate event, so that's cool by me!
How hard would it be to add some code in there to launch apps/scripts also upon RESUMING from the events? Kind of like a whole other tab in the interface, with same configuration items, but relevant to the resume of the 'events'.
So for example, would be great to be able to run a script when I RESUME from a hibernation.
1. Shutdown/Restart
2. Log Off
08-17-2005, 06:46 PM
#37
That's not a problem, however, say you catch the hibernate/standby event, and cancel it. When you cancel it, windows thinks it has resumed, so the resume event fires as well. So you will have to choose one or the other.
[H]4 Life
I'm a lesbian too.
I am for hire!
08-17-2005, 06:50 PM
#38
Raw Wave
How about something more creative, like putting a timer/delay to launch those apps or scripts (instead of trying to detect the resume from hibernate event)
So, you would for example launch an app with a 10 second delay. This would be enough time for the hibernation to take place. Let's say, 2 seconds passed by, and now the pc is hibernated. When you resume from hibernate, another 8 seconds will pass, and the app/script would be launched.
I know, it's a workaround, but hey, need to think out of the box
08-17-2005, 06:57 PM
#39
I'll just have it skip the first resume message.
Then it will only fire on the real resume.
[H]4 Life
I'm a lesbian too.
I am for hire!
08-17-2005, 07:24 PM
#40
Raw Wave
Another alternative.
How about you find a way to differentiate between the 'normal' resumes from hibernate, and the ones you canceled via interceptor?
For example, before canceling the event with interceptor, write a 'True' to a variable.
After detecting a resume from hibernate, read the variable, if True then you do no launching, and set the variable to false. If it is false, then you launch the apps...
08-17-2005, 07:34 PM
#41
You realize you just described the same thing.
[H]4 Life
I'm a lesbian too.
I am for hire!
08-17-2005, 07:56 PM
#42
Release
Here. Source Included.
[H]4 Life
I'm a lesbian too.
I am for hire!
08-17-2005, 08:10 PM
#43
You can use/modify that to suit your needs, however I have a better idea
that I may work up later.
[H]4 Life
I'm a lesbian too.
I am for hire!
08-17-2005, 08:37 PM
#44
Raw Wave
Our posts crossed paths in cyberspace LOL.
Yeah, it is basically the same thing.
08-17-2005, 09:08 PM
#45
Raw Wave
Frodo,
First of all thanks so much for this!!!!
Ok, so I gave it a spin on my Capruter (bench setup for now), and it is definitely intercepting and cancelling the hibernate event.
However, it is not executing anything I set up in the fields. I even tried selecting your very own 1.bat script, and it is not writing to the text file as you'd expect. Tried several other apps, and nothing. I also tried with other events (shutdown for example) and no go.
I am running a Biostar with Athlon XP2400+, 512MB Ram, and Windows XP SP2.
Release
| Thread Tools |
| Display Modes |
Linear Mode
