The MP3car.com Store
Go Back   MP3Car.com > Mp3Car Technical > Software & Software Development
Thread Tools Display Modes
Old 07-14-2005, 01:55 AM   #1
wallaceacura's Avatar
Vehicle: 2001 Acura 3.2TL
My Photos: (0)
iGuidance and Frodoplayer display issues?
I've searched and haven't found anything quite like the problem I'm having. I'd keep searching but it's almost 2am and this 7" Lilliput is killing my eyes.
Only once out of every 10 times does iGuidance display properly in Frodo. I've tried to hide/unhide start/restart etc. and play with all of the settings. Still no luck. It's not unbearable, but I know it can be fixed. The screenshot shows the black bar between song title and the screen.
I've read about iGSkinner and the new SKinner program, but it seems a little too complex for me. Has anyone used it with Frodo? Is there a FAQ for settint it up?
Thanks in advance.
wallaceacura is offline   Reply With Quote
Sponsored Links
Old 07-14-2005, 01:57 AM   #2
My Photos: (0)
one more thing
I forgot...I'm using iG 2.0.1. Also, frodo doesn't check the nag screen for me anymore. It did early on, though? I think I wore the damn thing out?!!
Old 07-14-2005, 01:57 AM   #3
My Village Called
0l33l's CarPC Specs
0l33l's Avatar
Vehicle: 1995 Lexus SC300 1997 Mazda Miata
My Photos: (0)
iGSkinner and SKINbedder will not work with FP
BTW: I think that FP has to get rid of the nag screen, otherwise it won't embed properly. I had the same issues with iGS and Sb.
PowerVoice v1 | NaviVoice Source
GammaControl v2.4
SKINbedder v3
1995 Lexus SC300 <-- Weekend Car
1997 Mazda Miata <-- Daily Driver
0l33l is offline   Reply With Quote
Old 07-14-2005, 10:38 AM   #4
My Photos: (0)
Nag screen
Am I missing a setting to get it to remove the nag screen? I just finished reinstalling everything thinking I might have messed something up and same issue. Does it matter that I'm using an nLited system? Same problem with full install though.
What is SB?
Old 07-14-2005, 12:33 PM   #5
My Village Called
0l33l's CarPC Specs
0l33l's Avatar
My Photos: (0)
I'm pretty sure that FP needs to get rid of the nag screen to embed correctly. Something is wrong with your system or settings. Check your settings again.
Sb = SKINbedder.
GammaControl v2.4
SKINbedder v3
Old 07-14-2005, 02:14 PM   #6
Zebelkhan's Avatar
Vehicle: 2004 Nissan Murano
My Photos: (12)
Ever since I went to IG 2.1, I have the same exact problems (both of them - Proper embedding and no nag) as wallaceacura has. It was working fine with Routis 2004 and IG 2.0.
Compaq Evo D510 e-PC - P4 2.0 - 512M RAM - 120G 3.5 HD - 7" Xenarc 700TSV - DSATX fitted nicely inside the PC case
Zebelkhan is offline   Reply With Quote
Old 07-14-2005, 04:10 PM   #7
My Photos: (0)
I'm using 2.0.1 if it helps. Is that just different enough from 2.0?
What settings should I be looking for? I've poured over the .ini file trying to find something that I've missed. Anyone else overcome this problem?
Old 07-15-2005, 02:58 AM   #8
My Village Called
0l33l's CarPC Specs
0l33l's Avatar
My Photos: (0)
Hmmm.... here's what I'd do. There's a registry entry that disables the NAG screen. You need a progam that writes that entree and launches iG... and then does not terminate.
GammaControl v2.4
SKINbedder v3
Old 07-15-2005, 06:54 AM   #9
Neither darque nor pervert
DarquePervert's CarPC Specs
DarquePervert's Avatar
Vehicle: 2003 Toyota Tacoma X-Cab
My Photos: (26)
Hmmmm.
I wonder if any of the suers here has written such a program. Boris, do you know if anyone has?
SEARCH: It's how information gets found!
How To Ask Questions The Smart Way
My Worklog
Old 07-15-2005, 11:39 AM   #10
My Village Called
0l33l's CarPC Specs
0l33l's Avatar
My Photos: (0)
Quote: Originally Posted by DarquePervert
Hmmmm.
No. And that's why people have been switching from FP. He decided to hardcode the classname
GammaControl v2.4
SKINbedder v3
Sponsored Links
Old 07-15-2005, 04:46 PM   #11
My Photos: (0)
I thought this registry hack was only for iG 2.1. I'm using 2.0.1.
I just uninstalled FP and installed RoadRunner. Setup the external GPS to launch iGLaunch and it works perfect. No nag screen, no borders, it's GREAT! Looks more OEM now.
I wish I could have setup SKINbedder. That might have helped...
Old 07-16-2005, 01:09 AM   #12
My Village Called
0l33l's CarPC Specs
0l33l's Avatar
My Photos: (0)
I've only played with the reg hack on v2.1. It seemed to work
Yay! iGSKinner
So.. what problems are you having with SKINbedder
Post in the proper thread
GammaControl v2.4
SKINbedder v3
Sponsored Links
vB code is On
Trackbacks are Off
Making the Menus bigger in Iguidance for FrodoPlayer!! PDiddy FrodoPlayer 2 05-03-2005 02:54 PM
iGuidance Embedded voidunknown FrodoPlayer 18 01-09-2005 04:19 PM
VOLUME_MIC LINE_can't get frodoplayer to use the mic line for volume control. GizmoQ FP Bug Reports 0 11-27-2004 05:47 PM
Iguidance not embedding ? NRGZ28 FrodoPlayer 5 11-23-2004 03:56 PM
iGuidance launcher app Envitro99 FrodoPlayer 1 11-23-2004 03:53 PM
Sponsored Links
SEO by vBSEO 3.1.0
Ad Management by RedTyger
