Go Back   MP3Car.com > Mp3Car Technical > Software & Software Development
Closed Thread
Old 08-09-2005, 02:25 AM   #1
PURDooM's Avatar
PURDooM is on a distinguished road
iGMod project
Well, I decided that I might as well make a thread about what I have been putting my freetime into latley...
I am making a program which I hope will end up rolling all the hacks for iGuidance on the forums into one master program, and will redesign the interface for IG to be more car touchscreen friendly. So far, it does effectively what igSkinner did (with more stability and less configuration I think), and its intercepting the IG menus and replacing it with its own.
Heres some screenies:
(Note spelling isnt my strong point, I fixed vehicle )
When I am impressed enough with the redesigned menus, ill put out an alpha. Eventually I will have an installer that will do the double sound mod, possibly some resource editing, and some memory hacks discussed here and there, as well as a bunch of things I thought up myself that I think IG could use.
Anyways, just thought I would get the word out.
Edit: And to not blot out Ol33l s good program, one of the planned features is integration with SkinBedder as well, because that program just keeps getting better and better
Current projects: iGmod reloaded (Latest release) (put on hiatus indefinatly)
Unlimited Internet and gps tracking for $6 a month with boost mobile!
Carputer 2: www.lmaocar.com
PURDooM is offline
Old 08-09-2005, 02:48 AM   #2
Raw Wave
lostreception's Avatar
lostreception has much to be proud oflostreception has much to be proud oflostreception has much to be proud oflostreception has much to be proud oflostreception has much to be proud oflostreception has much to be proud oflostreception has much to be proud oflostreception has much to be proud oflostreception has much to be proud of
if you need a beta tester im definatley game ... are you planning on hackin into the speed to make that larger
and to possibly make the distance to the next turn show up larger
these are 2 areas of ig that i feel donot meet the touch screen freindliness category
looks good so far im anxiosly awaiting a good solution for a more oem gps system which has caused a bit of a stumbling block for my project
.______
| '_ |__\___
[(o)|___(o)] XB
._________
| I__I I_I|_\__I
[(o)______(o)]b VanPimpin'
LostReceptions Apps D/L Here
GPSGasoline- Rewriting
CarPCNetwork
lostreception is offline
Old 08-09-2005, 02:55 AM   #3
PURDooM's Avatar
I need to break into the memory to read the speed so I can make a sound for "returned to safe speed". It shouldn't be difficult to make a new speed indicator/turn indicator shortly thereafter. Assuming I find an effective way to make VB6 directly read the memory of other programs.
PURDooM is offline
Old 08-09-2005, 03:14 AM   #4
Raw Wave
now if by that you mean that options for routing etc will be disabled above a certain speed. i agree with that but also disagree. common sense would be dont touch your gps when your going 80. (im dumb ill admit i have touched it from time to time) but thats why im not even installing my next version without voice control of some sort. while a returned to safe speed function may save a few lives (literally) voice control as of now still uses touch screen functions and there no way to differentiate.
and if i had a passenger there with me. they could check the map.
none the less i still think that function is definatly worth developing
IF thats what you meant by it at all
.______
| '_ |__\___
[(o)|___(o)] XB
._________
| I__I I_I|_\__I
CarPCNetwork
Old 08-09-2005, 03:25 AM   #5
PURDooM's Avatar
Actually, I meant the speed alert feature. Its quite accurate in my area with what the speed limits are, so I want a ding of some sort for when I was speeding to slow down.
I was thinking about the disable interface at high speed thing (I plan on building my sister a carputer, and would hate if it caused her to get into an accident) but ultimatly thats an undesirable feature.
PURDooM is offline
Old 08-09-2005, 10:23 AM   #6
schillrw's Avatar
schillrw is on a distinguished road
I would also like to beta test this for you if you need any help. IG definitely needs some help and this looks like a great addition. Email me ryanschilling@gmail.com if you need help. I look forward to seeing the finished product.
2004 F150 Lariat SuperCrew 4X4
Lilliput 7" Mounted In Dash
Via M10000
256MB PC3200 DDR
60gb Maxtor 7200RPM
Sony 16X DVD Drive
schillrw is offline
Old 08-09-2005, 10:57 AM   #7
camsgs3 is on a distinguished road
looks great, do you have a OSK working yet
camsgs3 is offline
Old 08-09-2005, 11:45 AM   #8
PURDooM's Avatar
I have a OSK made for my phonebook application but am still working on a creative way to read the memory or the display for the list that is generated when you type onto the OSK.
Heres a screenshot of my current osk: http://img114.imageshack.us/img114/7256/oskalpha3ja.jpg Note that I plan on redesigning the look to be more uniform with the other menus and to include that previewed selected text from IG.
PURDooM is offline
Old 08-09-2005, 01:00 PM   #9
UM_Fan's Avatar
UM_Fan is on a distinguished road
PURDooM: As an Ig user, this would be great. Having all the "hacks" in one "easy" to install/config file. Some of the Ig mods are a bit confusing at first (due to my non programing background) and where a big help.
A big concern for me atleast is the OSK & distance to the next turn bigger...That by itself would make Ig a great Nav program....
Thanks for all those countless hours you've put in so far and the ones your going to put....
Crazy Miami Drivers
R.I.P. My first ever NEW Car
Old installation
New Install!!!
|-------------------100%|Cables ran
|----------------85%----|Software RR
|--------------80%------|Complete
[/SIZE]
UM_Fan is offline
Old 08-10-2005, 10:57 PM   #10
PURDooM's Avatar
OSK Completed, sitting and poking hex values in the EXE for a few hours didn't let me find what set the font size in the previewwindow to get larger. But heres the new working OSK:
The previewwindow is a proprietary control class called AfxWnd42s which is also used to render the favorites list and the recent destinations list. Does anyone know how to access the memory corosponding to a class object from an external program? If I can't get to that memory I am going to have to go with a ghetto automated zooming system to show favorites.
PURDooM is offline
Old 08-10-2005, 11:19 PM   #11
Raw Wave
Beautiful work
.______
| '_ |__\___
[(o)|___(o)] XB
._________
| I__I I_I|_\__I
CarPCNetwork
Old 08-10-2005, 11:26 PM   #12
My man uses Levitra.
Peoples's Avatar
Peoples is on a distinguished road
i'm using an app called tsearch now, it seems to be pretty good for finding values, takes a little getting used to, and you really have to know what your looking for
PC Components:
My work log
Peoples is offline
Old 08-11-2005, 12:37 AM   #13
pimpmode's Avatar
pimpmode is on a distinguished road
that looks really promising...great job man
97 Pontiac Grand Prix GTP
P4 2.4
Freetech MoBo
DSATX 220W
512 MB ram
200 GB Maxtor harddrive
Road Runner
Iguidance 2.1
EZSync 1.94
pimpmode is offline
Old 08-11-2005, 01:05 AM   #14
MoFo's Avatar
MoFo is on a distinguished road
cool osk
MoFo is offline
Old 08-11-2005, 01:13 AM   #15
Raw Wave
justintime's Avatar
justintime is on a distinguished road
Wow, a dream come true! I'm going to 'watch' this thread. I hope you have something we can test soon. I absolutely love iGuidance, but the not-so-OEM look really is a turn off.
With something like this, we just might make it look factory. Awesome work, man!!!
2002 Honda CR-V
Spent so far: $1105.90
...or even Listen to my music
justintime is offline
Closed Thread
PROJECT ST34LTH : Project Car Purchased w/PICS ST34LTH General Hardware Discussion 69 09-01-2008 10:09 AM
A Start Community Project BenjaminS MacCar 9 03-25-2005 06:46 PM
New Project: Contrast Mediaplayer pplante Software & Software Development 26 07-07-2004 12:06 PM
Carputer as a comp sci final year project? MikeHunt79 General MP3Car Discussion 5 06-23-2004 10:19 AM
RLion Project Webpage Reactor General MP3Car Discussion 0 02-18-2004 06:43 AM
