Go Back   MP3Car.com > Mp3Car Technical > Software & Software Development
Old 08-20-2005, 03:55 PM   #16
Raw Wave
RoyN's Avatar
RoyN is on a distinguished road
accensound you miss the point I think... although there are all those complex types of interactions between HVAC control unit and HVAC compressors, etc, the control units follow some sort of standard.... basically knobs/buttons/sliders, etc...
from what I understsand this project owuld be able to control the control unit, not replace it! so again, it will work on most units I gather...
doing it directly would be basically impossible... tka emy car for instance, the control unit speaks to a AirCon ECU, which only then commands the compressor... the protocol for airconecu->control unit comm is of course proprietary... but emulating a button press on the control unit is very much simple...
correct me if I'm worng Dancehaven, but this is how I think your gonna do it right?
Roy
2005 Range Rover 4.4
RoyN is offline   Reply With Quote
Old 08-20-2005, 04:09 PM   #17
I got the rhythm.
Danceheaven's Avatar
Danceheaven is on a distinguished road
SPOT ON
To a certain extent
To be totally hohnest based on what research we have already conducted
theres not that much to it!
Its a case of measureing and monitoring temp sensors and controlling various
outputs and motors based on the temp readings.
Theres no reason what you couldnt replace the entire system with this unit
Co Develper of A.I.M.E.E Automotive Intelligent Multimedia Entertainment Engine
www.aimee.cc
Danceheaven is offline   Reply With Quote
Old 08-20-2005, 04:18 PM   #18
Raw Wave
RoyN's Avatar
what I'm saying is that you wont need to interface to complex things like vacuum hoses, etc...
Roy
Old 08-21-2005, 06:19 AM   #19
I got the rhythm.
Essentially yes
If people need to be able to drive a motor directly or fit a servo to control a
mechanical slider then the module will also allow this
www.aimee.cc
Old 08-21-2005, 07:19 AM   #20
MySQL Error
Scouse Monkey's Avatar
Scouse Monkey has much to be proud ofScouse Monkey has much to be proud ofScouse Monkey has much to be proud ofScouse Monkey has much to be proud ofScouse Monkey has much to be proud ofScouse Monkey has much to be proud ofScouse Monkey has much to be proud ofScouse Monkey has much to be proud ofScouse Monkey has much to be proud ofScouse Monkey has much to be proud of
Vehicle = Peugeot 306 with Auto Aircon
Year 1997
Air Con = Yes
Climate Control = No (auto mode)
AIR CON
Air Con Button = Yes with LED indicator. Also auto on when windscreen selected for demisting
Climate control Button (Sometimes shown as AUTO) = Auto position on fan speed dial
RECIRCULATE
Recirculate button = Yes (Recirculates cabin air rather than use road air)
FAN SPEED SETTING
Up and Down Buttons = No
Rotary Switch with hard limit = Yes - many positions + auto setting using mechanical feel. Control interface via poteniometer on PCB
Dial angle: approx 120-150deg
Rotary Switch with no hard limit = No
Mechanical Slider = No
Electronic Slider = No
Note: Please complete number of positions for Fan adjustment
TEMPERATURE CONTROL
Temperature Range in degrees C = 21 deg setting only - others are colder or hotter
Rotary Switch with hard limit = yes
Angle: 270deg from max tempt to min temp with 21 deg at approx 150 deg.
Rotary Switch with no hard limit = no
Note: Please complete number of positions for temp adjustment
VENT POSITON CONTROL
Number of positons = 4 (screen, main vents + screen, floor, main vents) - potentiometer interface to pcb for activating A/C etc + mechanical rotary cam connected to 2 cables
Number of Vent buttons = 0
Angle: 270 deg.
FRONT WINDSCREEN DEMISTER
As one of the Vent Postions = Yes
Button = No
Timeout = No
REAR WINDSCREEN DEMISTER
Button = Yes
Timeout = Yes
Quote:
If there is anything i have missed please let me know so i can update my post
Rotation angle for dials
If you want more answers on anything I have posted you can find me at digital-car.co.uk
or skiing or diving or doing somthing else fun!
Scouse Monkey is offline   Reply With Quote
Climate control through pc SweetLikeChutny Hardware Development 9 04-06-2007 11:36 AM
FS - Custom Audi Lilliput & climate control surround Tha Hombre Classified Archive 8 01-15-2006 07:30 PM
climate control with carputer mac2k6 Hardware Development 14 11-03-2005 06:15 PM
Digital Climate Control Fatigue General MP3Car Discussion 3 02-14-2005 08:01 PM
climate control john_draws General Hardware Discussion 5 06-27-2004 11:31 PM
