Go Back   MP3Car.com > Mp3Car Technical > Software & Software Development
Old 08-18-2005, 07:56 PM   #1
I got the rhythm.
Danceheaven's Avatar
Danceheaven is on a distinguished road
AIMEE Climate Control POLL
As you all may know the every impending release of AIMEE is only a matter of light years away....
Myself and Garry have been looking at possible features for future advances and
improvments in later versions,
one of those proposed features is a AIMEE controlled climate control system
What we need is some feedback to see who would be interested in such a system
Also to cater for everyone we need to know how your current Air Con / Climate Control
system currently works
As you know all manafactures do it there own way
So We need some feedback for the following options / configerations
Note:Tthe final product will come with full wiring and instructions to install
However some people will need external servos and mechanisms to control any mechanical parts of there stock system
Please Complete as appropiate
Any Comments or things we may need to know, please put in closed brackets at the end of the relevant line
Example:~
Vehicle = Mitsubishi FTO
Year 1995
Air Con = Yes
Climate Control = Yes
AIR CON
Air Con Button = Yes
Climate control Button (Sometimes shown as AUTO) = Yes
RECIRCULATE
Recirculate button = Yes (Recirculates cabin air rather than use road air)
FAN SPEED SETTING
Up and Down Buttons = Yes
8 positions
Rotary Switch with hard limit = No
Rotary Switch with no hard limit = No
Mechanical Slider = No
Electronic Slider = No
Note: Please complete number of positions for Fan adjustment
TEMPERATURE CONTROL
Temperature Range in degrees C = 17-30 in 0.5 Steps
Up and Down Buttons = No
Rotary Switch with no hard limit = Yes
30 positions
Note: Please complete number of positions for temp adjustment
VENT POSITON CONTROL
Number of positons = 5
Number of Vent buttons = 1 (I.e a Mode button that cycles through vent locations)
FRONT WINDSCREEN DEMISTER
As one of the Vent Postions = No
Button = Yes
Timeout = No
REAR WINDSCREEN DEMISTER
Button = Yes
Timeout = No
If there is anything i have missed please let me know so i can update my post
Cheers Guys
Co Develper of A.I.M.E.E Automotive Intelligent Multimedia Entertainment Engine
www.aimee.cc
Danceheaven is offline   Reply With Quote
Old 08-18-2005, 08:33 PM   #2
ProphetX is on a distinguished road
what kind of cable would need to be used to utilize this feature?
ProphetX is offline   Reply With Quote
Old 08-18-2005, 09:47 PM   #3
I see dead kittens
Quattro's Avatar
Quattro has a brilliant futureQuattro has a brilliant futureQuattro has a brilliant futureQuattro has a brilliant futureQuattro has a brilliant futureQuattro has a brilliant futureQuattro has a brilliant futureQuattro has a brilliant futureQuattro has a brilliant futureQuattro has a brilliant futureQuattro has a brilliant future
I would suspect that USB would work but I think that firewire would be much faster and give you better response in changing the temperature and fan speed.
[/OFF TOPIC]
Installed
Asus A7N8X-VM - AMD Mobile Athlon 2400
512 Ram - 60GB HD - Opus 150w
Lilliput 7" - Rikaline 6010
[00000000000001100010-] 98% Completed
Check Out My Install!!!
Quattro is offline   Reply With Quote
Old 08-18-2005, 10:10 PM   #4
Raw Wave
lostreception's Avatar
lostreception has much to be proud oflostreception has much to be proud oflostreception has much to be proud oflostreception has much to be proud oflostreception has much to be proud oflostreception has much to be proud oflostreception has much to be proud oflostreception has much to be proud oflostreception has much to be proud of
Cool
Vehicle = Chevy G20 Van
Year 1990
Air Con = Yes
Climate Control = No
AIR CON
Air Con Button = No
Climate control Button (Sometimes shown as AUTO) = No
RECIRCULATE
Recirculate button = No (Recirculates cabin air rather than use road air)
FAN SPEED SETTING
Mechanical Slider = Yes (4 positions ))
TEMPERATURE CONTROL
.______
| '_ |__\___
[(o)|___(o)] XB
._________
| I__I I_I|_\__I
[(o)______(o)]b VanPimpin'
LostReceptions Apps D/L Here
GPSGasoline- Rewriting
CarPCNetwork
lostreception is offline   Reply With Quote
Old 08-19-2005, 12:05 AM   #5
Raw Wave
RoyN's Avatar
RoyN is on a distinguished road
Vehicle = Range Rover
Year 1999
Air Con = Yes
AIR CON
Climate control Button (Sometimes shown as AUTO) = Yes (1 button)
RECIRCULATE
FAN SPEED SETTING
Rotary Switch with no hard limit = Yes (1 setting for both sides)
TEMPERATURE CONTROL
Temperature Range in degrees C = 16 - 30
Up and Down Buttons = yes (1 "rocker" switch (up/down) for each side passenger/driver)
Number of Vent buttons = 1 for each (single mode for both zones - 1 setting applies to all)
Button = Yes
Button = Yes
Roy
2005 Range Rover 4.4
RoyN is offline   Reply With Quote
Old 08-19-2005, 02:29 AM   #6
I got the rhythm.
Currently the prototype is RS232 controlled,
Hence a 9 way D Type Serial Cable
But you could also use a USB to RS232 Convertor to enabel USB access
Furture versions will be USB Controlled
The amount of data that is communicated is tiny so there will be no need for
Any high speed link (firewire / USB 2) etc
www.aimee.cc
Old 08-19-2005, 05:50 AM   #7
Raw Wave
RoyN's Avatar
Dancehaven let me go out and say this, even though you didnt ask...
My using of Aimee or any other frontend is not based on Climate control. Although "nice" to have an integrated package I fear how complicated it would be to hook the whole thing up... I also understand a lot of moving around would be done and that I would lose my original control (possibly forever if I needed to hack it up/solder/desolder)...
I know you said FUTURE VERSIONS, but I sure as hell hope the release isnt being delayed because of adding this sort of thing...
Roy
Old 08-19-2005, 09:38 AM   #8
vr6gtiguy is on a distinguished road
Vehicle = VW Jetta
Year 1991
Air Con = Yes
AIR CON
Air Con Button = NO
RECIRCULATE
Recirculate button = NO (Recirculates cabin air rather than use road air)
FAN SPEED SETTING
Rotary Switch with no hard limit = Yes 4 Positions including OFF
TEMPERATURE CONTROL
Number of positons = 4?
As one of the Vent Postions = Yes
Button = Yes
Timeout = Yes
vr6gtiguy is offline   Reply With Quote
Old 08-19-2005, 09:56 AM   #9
Raw Wave
Chris31 will become famous soon enough
Yo andrew...
Be careful what you say, I know exactly whats going on in this project
Chris31 is offline   Reply With Quote
Old 08-19-2005, 10:01 AM   #10
I got the rhythm.
Quote: Originally Posted by Chris31
Yo andrew...
Dont know what your talking about
www.aimee.cc
Old 08-19-2005, 10:11 AM   #11
I got the rhythm.
These are always very true points to consider
To be able to complete such an install its no lie that you will need to be very competent with a soldering iron and have a good understanding of basic electronics, i.e swicthes and motors
And rest assured AIMEE is not been held back while we implement this feature mainly because its already implemented
its the hardware that is still work in progress hence why im gathering information
www.aimee.cc
Old 08-19-2005, 01:01 PM   #12
accentsound's Avatar
accentsound is on a distinguished road
Has anyone actually looked at what is actually connected to the AC controls? Just to give you a heads up. Other than fan speed. Many vehicles use vacume lines, valves and cables to control Heat and AC. This is even true for many high end vehicles.
So without knowing preciesly what is under the dashboard, the answers to the guestions asked above could be very misleading.
Then you have other issues like dual zone, single zone, does the car have memmory settings for driver passanger? Does the system control the compressor and heating valves directly or is that processed by HVAC control unit?
Face it guys to make this work on anything other than your own vehicles you will have to have test vehicles at your finger tips from different models, manufacturers and years.
Either that or it will have to be a generic relay control hack that basically engages and disengages a relay bank at the touch of a on screen button. And that is already available. In addition it will still have to be a custom install for about every vehicle.
How do I know this? Because for I worked on Rolls Royce, Jaguar, Mercedes, Rover, and other imports as a professional mechanic for a number of years.
accentsound is offline   Reply With Quote
Old 08-19-2005, 09:59 PM   #13
DaRacerz is on a distinguished road
Vehicle = Hyundai
Year 2001
Air Con = Yes {All Electronic, No Manual Strings/Vacs at Interface}
AIR CON
RECIRCULATE
FAN SPEED SETTING
4 positions
Rotary Switch with hard limit = yes
TEMPERATURE CONTROL
Rotary Switch with hard limit = Yes
Have to check count in the technical documents. Get back to me on this if needed
Button = Yes
Timeout = Yes
Mark
Website: http://www.geocities.com/daracerz83/
Car'Puter Project
- Xenarc 700TSV
- MSI RS482M-IL Mobo + AMD Turion MT-32 (25W)
- 1x 256MB Corsair XMMS DDR400
- M2-ATX
- Belkin 802.11G W-Nic
- Garmin 15H GPS
- WinXP SP2 (NLited)
DaRacerz is offline   Reply With Quote
Old 08-20-2005, 05:32 AM   #14
Confusion Master
Enforcer's Avatar
Enforcer has a brilliant futureEnforcer has a brilliant futureEnforcer has a brilliant futureEnforcer has a brilliant futureEnforcer has a brilliant futureEnforcer has a brilliant futureEnforcer has a brilliant futureEnforcer has a brilliant futureEnforcer has a brilliant futureEnforcer has a brilliant futureEnforcer has a brilliant future
Vehicle = BMW 328i
Year 1997
Air Con = Yes
AIR CON
RECIRCULATE
FAN SPEED SETTING
8 positions
TEMPERATURE CONTROL
Temperature Range in degrees C = 16-35 in 0.5 Steps
Up and Down Buttons = YES [Dual one for passenger and driver side]
30 positions
Number of positons = 3
Number of Vent buttons = 3 + AUTO (I.e a Mode button that cycles through vent locations)
Button = Yes
Timeout = No
Button = Yes
Timeout = Yes
Enforcer is offline   Reply With Quote
Old 08-20-2005, 07:41 AM   #15
I got the rhythm.
Very imformative post
But this ofcourse is what we have been researching for several months
Mastero has already created a standalone Climate control system using our
software. that is already in production and avaliable to buy
hes proven it to work on many vehicles and has based the design on that
fact
Obviously this isnt for everyone and only the super competent may consider
to undertake this install.
However the system will be super flexable to allow you to do this
www.aimee.cc
Climate control through pc SweetLikeChutny Hardware Development 9 04-06-2007 11:36 AM
FS - Custom Audi Lilliput & climate control surround Tha Hombre Classified Archive 8 01-15-2006 07:30 PM
climate control with carputer mac2k6 Hardware Development 14 11-03-2005 06:15 PM
Digital Climate Control Fatigue General MP3Car Discussion 3 02-14-2005 08:01 PM
climate control john_draws General Hardware Discussion 5 06-27-2004 11:31 PM
Content Relevant URLs by vBSEO 3.3.0
"VaultWiki" powered by VaultWiki v2.5.2.
Copyright © 2008 - 2009, Cracked Egg Studios.Ad Management by RedTyger
