Go Back   MP3Car.com > Mp3Car Technical > Software & Software Development
Old 01-04-2006, 12:23 AM   #121
b8bboi is on a distinguished road
Prefect, another feature request please. Can you have an option to start the program but with the web cam not being active (kinda like when "preview" is not selected while recording). The reason is if the camera is active and showing image, it'll eat up about 40% of my CPU cycle.
Here's how it would work perfectly for me. Capture! starts. No web cam image is being shown. If I need, I'll click record (or Start). Capture! will start recording.
b8bboi is offline   Reply With Quote
Old 01-04-2006, 12:33 AM   #122
Civic03's Avatar
Civic03 is on a distinguished road
This worked great for me but it's hard to configure since I can't understand what it wants!!!
PROGRESS 95%[//////////]Complete - Software configurations
Current Task: Just adding on...
Needed:wireless keyboard/mouse
My Carputer Blog
Car System Site
Civic03 is offline   Reply With Quote
Old 01-04-2006, 06:52 AM   #123
Prefect's Avatar
Prefect is on a distinguished road
@Civic03: what do you mean?? Just the config.ini? You don't have to edit the config.ini by yourself. Most of the values can be set directly from within the tool. In the config.ini you should set the saveto-drive and -path.
@All: could someone translate the config.ini?
@tj!2k4: I did not change anything. 8-) Try to acces your cam with c:\windows\vidcap32.exe or any other app that is able to use WDM capture devices. Some posts ago i postet the original capture test app. Maybe you can check with that tool!
@b8bboi: Good idea. I try to add that when i have time for it!
Prefect is offline   Reply With Quote
Old 01-04-2006, 07:06 AM   #124
Civic03's Avatar
Thanks, I'll use the menu itself. saveto-drive and path; what are those values? I see //menu path etc. I think it stored it under winamp by default.
My Carputer Blog
Car System Site
Old 01-04-2006, 07:36 AM   #125
Prefect's Avatar
SaveToDrive=C:
SaveToPath=\\media\\recordings
VideoFileName=CarPC
gives files like "C:\media\recordings\CarPC 02-12-05 16.48.40.avi"
AutostartCapture=0
Set to "1" starts capturing immediatly after the app is started without any user interaction.
StopAfterMB=500
After the video files exceeds 500 MB recording stops and starts again with a new file if StartOver=1 is set.
WindowStateOnLoad = normal --> normal Window
WindowStateOnLoad = maximized --> maximized Window without borders
WindowStateOnLoad = CES --> no borders, maximized but with some space on the top of the screen for carpc-software taskbars.
CapturePreview = 1
1=video is shown while recording, 0=background image is displayed (saves cpu power)
Old 01-04-2006, 08:32 AM   #126
Civic03's Avatar
Perfect; THANK YOU for the explanation. I'll have to copy these down.
My Carputer Blog
Car System Site
Old 01-04-2006, 04:22 PM   #127
Erorus's Avatar
Erorus is on a distinguished road
Quote:
Any chance for text overlay on the video? For example, once every second it'll pull the contents of a text file and overlay them on the video frame in the top corner (or anywhere you want).
If so, I might modify my OBD reader app to output vehicle speed to a text file, so when you're watching the video you know how fast you're going. Just a thought, don't bother if it's a lot of trouble.
Never mind, let me make sure it runs well on my carpc first before you go adding things.
Erorus is offline   Reply With Quote
Old 01-11-2006, 10:05 PM   #128
Prefect's Avatar
Smile
@b8bboi: here you are: Capture!.zip
@All: New Version!
I changed quite a lot so please delete everything in your old capture-folder! Just take over the values from the config.ini (not the file itself, there are new entries in the file)
- Added b8bboi's request: PreviewActive = 0 deactivates the preview video image. You can check the video display if you activate the menu entry "Options --> Preview".
- Made the value for minimum free disk space available in the config.ini. MinFreeSpace=50 sets a limit of 50MB, so Capture! will stop recording if diskspace drops below 50MB.
- Cleaned up a lot of things and made capturing a lot faster!
- Calculating the free disk space every second was very cpu intensive. So this is now done only every 10 seconds.
- Bugfixed the "Options --> Preview" menuentry.
- Free disk space is shown in the status bar after startup.
- Added a program icon image.
- Changed program name from CaptureTest.exe to Capture!.exe
I also added a cpu-load display. But this used so much cpu that it always displayed 100%
Let me now if something does not work!
Greetz, Chris
Old 01-11-2006, 11:40 PM   #129
Great. Can't wait to try this out.
Old 01-17-2006, 04:46 PM   #130
Ashthos is on a distinguished road
What codecs have people found works well with this? I'm not worried about the cpu running at 100% but the mp3s and GPS shouldn't really be affected either while recording. I will be having it recording all the time.
EPIA MII 12000, 512mb, etc etc
Ta
Ash
Ashthos is offline   Reply With Quote
Old 01-17-2006, 05:28 PM   #131
Prefect's Avatar
Hi Ashthos!
I have a slightly slower system, a MII1000. I run CES (CarPC Software with MP3 Playback, GPS-utilisation, Visualisation), GPSGate, ShowGPS, MapMonkey in navigation mode with speech and can capture at 320x240 with 30fps without any affects to mp3 playback or navigation.
I don't capture audio, video is captured using the old DivX 5.02 (or so..) and set to "fastest" in the settings of divx and about 4000kbit/s.
Chris
Old 01-17-2006, 05:44 PM   #132
Prefect, if I set PreviewActive=0 (and Capture! doesn't show cam image), how do I temporarily "turn it on"? It'd be great if there's another button to turn on and off the camera while in non-recording mode.
Old 01-17-2006, 07:09 PM   #133
Prefect's Avatar
@b8bboi: use "Options" --> "Preview" ;-) Should work, doesn't it?
Old 01-18-2006, 10:21 AM   #134
Oh I see it now. Thanks. I'd still rather have a big button for that, though.
Old 01-19-2006, 12:38 PM   #135
mashina is on a distinguished road
new version is cool!
really much faster and better version of capture!
mashina is offline   Reply With Quote
Recording (web)camera to carpc DaKyy General Hardware Discussion 12 09-05-2005 09:59 AM
iGuidance Recording Cheekz185 GPS 35 07-22-2005 07:56 PM
Routis click ok johnnyutah36 MediaCar 3 08-25-2004 11:22 PM
T-Mobile Internet cavramair Wireless Communications 9 07-24-2004 04:53 AM
Video camera for recording driving MBL MIKE Input Devices 4 04-26-2004 01:27 AM
