Go Back   MP3Car.com > Mp3Car Technical > Software & Software Development
Old 09-16-2005, 04:52 AM   #1
toxsickcity's Avatar
Resume time from hibernation with EPIA M/B's
hello carputa people
I have a laptop that I use as a everyday PC..
It's pretty speedy and the thing I love most of all is Resume from hibernation seriously takes only 3 seconds.. even with large apps open eg photoshop...
But my Epia MII 1.2ghz in the car is slow as ****.. even a quicker HDD is the carputa 15-20seconds.. resume for carputa would be a godsend if it was 4 seconds like the laptop!
anyone got any ideas of speeding up the epia.
Specs,
MII - 12000 / 256MBDDR266 / 80GB 7,200 3.5" onboard vga audigy 2zs
Pentium M 1.73ghz / 512MBDDR533 / 60GB 4,200 2.5" onboard Radeon X700 & built in Sound.
can anyone here who have same spec as my carputa post the resume from hibernation time for your system..
toxsickcity is offline   Reply With Quote
Old 09-16-2005, 07:43 AM   #2
I'm sorry, and you are....?
frodobaggins's Avatar
You can reduce the amount of ram.
FrodoPlayer.com
TeaBaggins.com
[H]4 Life
I'm a lesbian too.
I am for hire!
frodobaggins is offline   Reply With Quote
Old 09-16-2005, 10:14 AM   #3
I have tried using the msconfig ram limiter and tring all sort of configurations and the resume time is slow and around 10-12 seconds..
even with just 128mb of useable of ram..
I've also tried adding 512MB instead of 256.. same thing, slow when decompressing the hibernation file to ram..
I am sure it's either the cpu being bad a decoding... etc or bios disk i/o speed.
as windows as yet to load any drivers i am sure that it's to do with the quality of the chipset, I am sure the chipset Intel 925PM in my laptop.
but if anyone knows of another way, let me know..
And YES I have defrag, partitioned and many other thing have been tried to speedup the system..
Old 09-19-2005, 02:19 AM   #4
Power_nisse's Avatar
i would check the Harddive and the connections of it!
Make a speed test or some thing, DO you think the harddrive is fast when you have booted up? Its on the master jumper/cable.
Try disconnect the audigy 2zs, i have never tried that card its a real CPU consumer!
Ampie Case
M1-ATX 90w
EPIA ITX 1,3Ghz, Firewire
80 GIG SATA
512MB
7 TFT Touch Super
Pioner Slot in DVD-RW writer
108 Mbit Wireless Lan
100 M Bluetooth Range
//Power Nisse
My Betasite -> http://haagen.se
Power_nisse is offline   Reply With Quote
Old 09-21-2005, 11:14 PM   #5
NiN^_^NiN's Avatar
i have the same problem but mine is the 600mhz EPIA (MII 6000E) im using 256mb and it takes about 36 seconds or more to hibernate coming out of hibernation is around 20 secs but it takes so long even if i hibernate with nothing running at all.
I would like 15sec altho i probably won't be able to with this board.
Also im curious if you made the hibernation file read only could u in theory just turn the pc off then restart it up?
CarPC Status:
GPS: 99%
Hardware: 99%
Software: 92%
Case Install: 99.9%
Dash Install: 100%
Car Install: 72%
NiN^_^NiN is offline   Reply With Quote
Old 09-21-2005, 11:23 PM   #6
SFiorito's Avatar
no, what you want to do is called Hibernate Once, Resume Many (HORM) which is a feature supported with the Enhanced Write Filter (EWF). Check the do a search for those two keywords for more info...
SFiorito is offline   Reply With Quote
Old 09-22-2005, 12:32 AM   #7
Registered User
aoLhaTer's Avatar
10-12 seconds including the BIOS is not slow, that sounds about right
2004 G35 Coupe project
aoLhaTer is offline   Reply With Quote
Via Epia - can I use VGA and RCA video outs at same time? nxt125 General Hardware Discussion 5 09-17-2005 09:31 AM
Good time to buy carputer components? Linus General MP3Car Discussion 19 11-25-2004 08:57 PM
EPIA VIA M10000 Mini ITX in a 6x9 Speaker Box pic. 2 hour build time. LESLIEx317537 General Hardware Discussion 23 02-13-2004 12:24 PM
A few observations in OS and why I'm now using Windows 2003... Mastiff Software & Software Development 12 01-21-2004 09:11 AM
EPIA M9000 & TM701 Problem PTCruiser LCD/Display 10 03-28-2003 01:43 PM
