Go Back   MP3Car.com > Mp3Car Technical > Software & Software Development
Old 10-31-2005, 11:59 PM   #1
XxAndyxX's Avatar
XxAndyxX is on a distinguished road
Enhanced Volume Control
I started this project to match the line in control to my master volume, but as boredom at work kicked in, I've made this program into much more!
Let me explain a little bit how to work this program.
This is the Editor.exe program:
This is where you check what control you want to match to the master volume. Matching these controls to the master volume enables your volume to get extremely low, but also get the loudest your sound card will allow:
This is one of the best features of the program. It matches a percentage of the control checked to the master volume. When I use my XMPCR in the line in, it is significantly louder than when I play my regular music (which uses the wav control). So I set Line In to 75 and then it plays at 75 percent of regular volume, making the transition from MP3's to XM radio smooth!
One thing that I didn't like about my touch screen is how long it takes to turn up and down the volume. If you think about it, the difference when your volume goes from 2% - 4% is a lot more noticiable than when it goes from 90% - 92% (especially on high output systems). This part will increase and decrease the volume at an exponential rate.
This part of the program sets the volume percentage you want the exponential increasing and decreasing to start and stop at. Set it to 0 if you want it to do it from 0 to 100 percent. Set this to 100 if you do not want to utilize the exponential increase and decrease at all.
And finally, the program:
Hints on install:
Place a shortcut of MatchVol.exe into your startup folder, if you make changes with the Editor.exe you must restart your computer or end the current MatchVol.exe process using ctrl+alt+del and then restart the program.
Enjoy !
XxAndyxX is offline   Reply With Quote
Old 11-01-2005, 12:28 AM   #2
arebelspy's Avatar
arebelspy is on a distinguished road
You. are. the win.
This is great. I have the "line in" (xm) is is louder than mp3 problem. PLUS I have an internal mic (laptop setup) that gives off a high pitched squal if turned up. With this I can set the mic to 0%, and tie everything else to the main volume, with the % for the line in to make XMmp3 transition smooth as you stated.
THANK YOU!!
-arebelspy
See my trades here! My For Sale/Trade Thread. Email joe at eipse.com
Quote: Originally Posted by xdjxklusivex
i think every thread is now a whoreing thread
arebelspy is offline   Reply With Quote
Old 11-01-2005, 07:15 AM   #3
Maņana's Avatar
Maņana is on a distinguished road
You just made my day =)
My carputer
Old one
Maņana is offline   Reply With Quote
Old 11-01-2005, 02:10 PM   #4
Kamakazie2 is on a distinguished road
Would be at all a possibility to add in the Optical In for the Audigy users? This would totally fix my XM issue. Thanks for your research and work!
-Jack
2006 Chrysler 300C AWD
IBM T30 Thinkpad / RoadRunner
XMPCR/GPS/SIRIUS
(RIP) HDRadio project: http://www.mp3car.com/vbulletin/hardware-development/93791-someone-here-has-able-crack-hdradio-car.html
Kamakazie2 is offline   Reply With Quote
Old 11-06-2005, 02:28 PM   #5
The Last Good Gremlin
GizmoQ's Avatar
GizmoQ has a spectacular aura aboutGizmoQ has a spectacular aura about
I need to match the line out with master, too. Can this be added?
HARDWARE: Fujitsu Stylistic ST5031w/WiFi and dock, internal MP3Car 80G HD,, external 1TB HD, Sierra Wireless Aircard 550, DVD-RW, Silabs FM, WinTV USB, XM Commander w/Timetrax USB, Delorme GPS, Saitek X-52 joystick, BluSoleil Bluetooth, TPMS, FB, Elm327
GizmoQ is offline   Reply With Quote
Old 11-09-2005, 09:59 AM   #6
strohj's Avatar
strohj is on a distinguished road
this rocks!!!... perfect solution for my XM volume woes....
strohj is offline   Reply With Quote
Old 11-10-2005, 12:50 PM   #7
RiiS is on a distinguished road
Nice little prog. Thx alot for this
RiiS is offline   Reply With Quote
Old 03-02-2006, 02:43 PM   #8
Stank Cheese
n8scstm's Avatar
n8scstm is on a distinguished road
Do you think it's possible to get the prog to match wav and spdif in?
2.4 celeron
150 watt OPUS
micro atx
xp pro
tv/radio tuner card
audigy
Dual monitor Radeon
802.11G Mimo
xm pcr
dvd
gps
8" Lilliput touch screen
IGuidance
dual optimas
battery isolator
15" screen
My Truck
n8scstm is offline   Reply With Quote
Old 03-02-2006, 03:33 PM   #9
JasonWW is on a distinguished road
I've already asked Andy about that as my SPDIF doesn't work with the program. Here's his response:
Quote:
XxAndyxX-The audio class I'm using to build the program is pretty old, came out in 97'. I'm hoping to find a newer class that supports SPDIF, but after a lot of searching I've come up empty. I'm going to start posting up on different programming forums to see if someone knows of a class that supports SPDIF and some of the newer audio features.
If anyone does find a program that supports the SPDIF, please tell us about it.
Jason
JasonWW is offline   Reply With Quote
Old 03-02-2006, 03:58 PM   #10
GreenBeast is on a distinguished road
so does this work 'through' another program like a front end?
so when i press the volume buttons on Mobile Impact it can exponentially raise and lower the volume?
My install... check it out!
www.mp3car.com/vbulletin/showthread.php?t=56599
GreenBeast is offline   Reply With Quote
Old 03-02-2006, 06:17 PM   #11
Stank Cheese
n8scstm's Avatar
I looked at the source code and that appears to be correct. The class module used doesnt support spdif. I searched for one that does and came up with nothing. There must be something out there though. I'll keep looking.
2.4 celeron
150 watt OPUS
micro atx
xp pro
tv/radio tuner card
audigy
Dual monitor Radeon
802.11G Mimo
xm pcr
dvd
gps
IGuidance
dual optimas
battery isolator
15" screen
My Truck
Old 03-02-2006, 06:48 PM   #12
Stank Cheese
n8scstm's Avatar
There seems to be a prog called volumetracker.exe that might help but all the links to its download are no longer working. Can anyone find this program so we can see if it will work?
2.4 celeron
150 watt OPUS
micro atx
xp pro
tv/radio tuner card
audigy
Dual monitor Radeon
802.11G Mimo
xm pcr
dvd
gps
IGuidance
dual optimas
battery isolator
15" screen
My Truck
Old 03-02-2006, 09:41 PM   #13
LESLIEx317537's Avatar
LESLIEx317537 is on a distinguished road
Let me see if I can come up with another method to control the windows Spdif input.
SP13000|M2-ATX|512MB DDR400|2.5" 7200RPM S-ATA|Trans-7"|Slim SL DVD-CDRW|KEH 5.1 DSP|SB L!ve Ext|Gyration PowerMate|BT|WiFi|GPS|WinXP|VoomPC
GPSing - Digital Speedo
Relocating headunit and extending faceplate
Button app to Alt-Tab between two programs
LESLIEx317537 is offline   Reply With Quote
Old 03-02-2006, 10:16 PM   #14
It works at the Windows level. It works on my home PC as I'm not using SPDIF. If you open the volume panel in Windows you will see that the Wave and Master are now linked. When one is raised the other will raise as well. So when you raise or lower the volume in RoadRunner or whatever, Master and Wave move together giving you more volume range as well as speed.
It's not really exponential either, it's just double the range and speed. There are some other options to increase the speed when the button is held, but I don't use them. Maybe that can make it seem exponential?
Old 03-03-2006, 03:20 AM   #15
thankyou!
XM Volume Control Kamakazie2 Media Engine 1 07-03-2005 12:12 PM
Volume control in Xenarc 700TSV BMW-7 LCD/Display 3 04-07-2005 12:08 AM
Volume Control Solution, a good one too clean customs Input Devices 34 01-26-2005 10:40 PM
Volume control buttons in external app mode Bobby Digital Media Engine 0 07-30-2004 01:24 PM
hardware volume control ODYSSEY General Hardware Discussion 18 04-20-2001 11:43 AM
