Quote: Originally Posted by Pokiarchy
How do I stop AIM from adding itself to the startup list every time i use it? Or can you guys tell me a better way to direct connect ftp. Its driving me nuts, arg.
AIM? FTP? WTF are you talking about?
I'm going to take a stab at your vague query, because I think I know what you're attempting to pull off.
You're transferring files using AIM (which sucks as a means of file transfer, as do all IM software). You don't want AIM to start up w/ the PC.
Click on Start
Click on Run
Type
REGEDIT and click
OK.
Navigate to
HKEY_CURRENT_USER\Software\Microsoft\Windows\Curre ntVersion\Run.
There will be a key named AIM. Delete that and AIM will no longer start with Windows.
As Boris suggested, running MSCONFIG to alter your startup paremters will achieve the same effect.
As far as doing FTP, you'd need to have an FTP daemon running on the comptuer wou want to conenct to from the car. There are many simple FTP Daemons around. ServU is a common one.
