Go Back   MP3Car.com > Mp3Car Technical > Software & Software Development
Old 03-09-2006, 03:29 PM   #16
teo256's Avatar
teo256 is on a distinguished road
Quote: Originally Posted by jcdillin
it should create a new serial port when you pair the phone with the computer
how to do that? In the bluetooth control panel i have 2 place where do that:
- local service
- client apps
where??
i see that the wizard use the port COM5 that is the one of the bluetooth modem...
This is the log:
10/03/2006 0.27.50 MediaPlayer: WMPLAYER
10/03/2006 0.27.51 Version: 1.6.0 Beta
10/03/2006 0.27.51 Trial. Expires: 07/04/2006
10/03/2006 0.27.52 Keymap "Sample Key-Map for SE T610 simulating a mobile phone like keypad" loaded, 25 mappings found.
10/03/2006 0.27.52 SMS templates loaded, 5 templates found.
10/03/2006 0.27.52 Opening COM5
In the splash screen of Phoco (when it starts) i can read:
- Initializing phone
then...
- Reset phone
and immediatly the pc reboot !!!!
I've read something about to not use the serial port service, but to use the dial-conn.....someone can explain me better???
SOME LAST ADDS:
I tried to use windows bt drivers and phoco run good, but not the audio (this is because windows bt drivers don't support audio gateway). When i reinstalled widcomm bt drivers....phoco don't want to run...as sayd above, it causes the crash of the system....
PLEASE HELP!!!!!
P.S.: When i try the wizard config, at the step for searching com ports, i receive this error
See the end of this message for details on invoking
just-in-time (JIT) debugging instead of this dialog box.
************** Exception Text **************
System.ObjectDisposedException: Cannot access a closed registry key.
Object name: "HKEY_CURRENT_USER\Software\Widcomm\BTConfig\Servi ces".
at Microsoft.Win32.RegistryKey.ValidateState(Boolean needWrite)
at Microsoft.Win32.RegistryKey.OpenSubKey(String name)
at PhoneCtlWizard.Form1.FindLocalSerialPort()
at PhoneCtlWizard.Form1.btnScanPort_Click(Object sender, EventArgs e)
at System.Windows.Forms.Control.OnClick(EventArgs e)
at System.Windows.Forms.Button.OnClick(EventArgs e)
at System.Windows.Forms.Button.WndProc(Message& m)
at System.Windows.Forms.ControlNativeWindow.OnMessage (Message& m)
at System.Windows.Forms.ControlNativeWindow.WndProc(M essage& m)
at System.Windows.Forms.NativeWindow.Callback(IntPtr hWnd, Int32 msg, IntPtr wparam, IntPtr lparam)
************** Loaded Assemblies **************
mscorlib
Assembly Version: 1.0.5000.0
Win32 Version: 1.1.4322.2032
CodeBase: file:///c:/windows/microsoft.net/framework/v1.1.4322/mscorlib.dll
PhoneCtlWizard
Assembly Version: 1.5.0.23033
Win32 Version: 1.5.0.23033
CodeBase: file:///C:/Programmi/PhoneControl.NET/PhoneCtlWizard.exe
CodeBase: file:///c:/windows/assembly/gac/system.windows.forms/1.0.5000.0__b77a5c561934e089/system.windows.forms.dll
System
CodeBase: file:///c:/windows/assembly/gac/system/1.0.5000.0__b77a5c561934e089/system.dll
System.Xml
CodeBase: file:///c:/windows/assembly/gac/system.xml/1.0.5000.0__b77a5c561934e089/system.xml.dll
System.Data
CodeBase: file:///c:/windows/assembly/gac/system.data/1.0.5000.0__b77a5c561934e089/system.data.dll
System.Drawing
CodeBase: file:///c:/windows/assembly/gac/system.drawing/1.0.5000.0__b03f5f7f11d50a3a/system.drawing.dll
Infragistics.Win.UltraWinTabControl.v3.1
Assembly Version: 3.1.20041.15
Win32 Version: 3.1.20041.15
CodeBase: file:///C:/Programmi/PhoneControl.NET/Infragistics.Win.UltraWinTabControl.v3.1.DLL
Infragistics.Shared.v3.1
CodeBase: file:///C:/Programmi/PhoneControl.NET/Infragistics.Shared.v3.1.DLL
Infragistics.Win.v3.1
CodeBase: file:///C:/Programmi/PhoneControl.NET/Infragistics.Win.v3.1.DLL
Infragistics.Win.Misc.v3.1
CodeBase: file:///C:/Programmi/PhoneControl.NET/Infragistics.Win.Misc.v3.1.DLL
zBTHelper
Assembly Version: 1.0.2190.21340
Win32 Version: 1.0.2190.21340
CodeBase: file:///C:/Programmi/PhoneControl.NET/zBTHelper.DLL
OpenNETCF.Desktop.Communication
Assembly Version: 2.8.2181.32655
Win32 Version: 2.8.2181.32655
CodeBase: file:///C:/Programmi/PhoneControl.NET/OpenNETCF.Desktop.Communication.DLL
OpenNETCF.Net.Bluetooth
Assembly Version: 1.4.50709.0
Win32 Version: 1.4.50709.0
CodeBase: file:///C:/Programmi/PhoneControl.NET/OpenNETCF.Net.Bluetooth.DLL
Interop.BTSTACKSERVERLib
Assembly Version: 1.0.0.0
Win32 Version: 1.0.0.0
CodeBase: file:///C:/Programmi/PhoneControl.NET/Interop.BTSTACKSERVERLib.DLL
************** JIT Debugging **************
To enable just in time (JIT) debugging, the config file for this
application or machine (machine.config) must have the
jitDebugging value set in the system.windows.forms section.
The application must also be compiled with debugging
enabled.
For example:
<configuration>
<system.windows.forms jitDebugging="true" />
</configuration>
When JIT debugging is enabled, any unhandled exception
will be sent to the JIT debugger registered on the machine
rather than being handled by this dialog.
teo256 is offline   Reply With Quote
Old 03-12-2006, 01:16 PM   #17
GreenBeast is on a distinguished road
hey jcdillin i just loaded up mobile impact (the front end i use) and phonecontrol just started working, i now get sound through the computer speakers and the comp microphone
dunno if thas any help or just rubbing your nose in it but at least now you know it works hopefully you'll be able to get it working
My install... check it out!
www.mp3car.com/vbulletin/showthread.php?t=56599
GreenBeast is offline   Reply With Quote
Old 03-12-2006, 01:32 PM   #18
MySQL Error
jcdillin's Avatar
jcdillin is on a distinguished road
great info, i'll have to give it a shot
肚子笑痛了
S60 Install
jcdillin is offline   Reply With Quote
Old 03-12-2006, 02:05 PM   #19
coucouillu's Avatar
coucouillu is an unknown quantity at this point
I have Nokia 6680 too and find lots of diffculties to connect to PhoneControl in centrafuse 1.6.
Nothing seems to work.
I also have the bluescreen and reboot when phoco try to connect to the phone.
I use WIDCOMM + patches and a TRUST BT180 bluetooth USB dongle.
Hopping we will find a solution.
coucouillu is offline   Reply With Quote
Old 03-12-2006, 02:07 PM   #20
coucouillu's Avatar
Quote: Originally Posted by GreenBeast
i've got a 6680 ...bear in mind that i have the phone connecting to phoco and i can dial out and accept calls but i have yet to get the sound transferred onto my pc, that is the current issue i'm trying to sort out
could you share your experience of your configuration?
Thank you in advance.
Old 03-12-2006, 02:14 PM   #21
i don't really know the secret of it to be honest.
it was lot of trial and error
my BT dongle is the belkin F8T008 and i'm using widcomm version 5.x drivers
also the sound wasn't working until i tried it for the first time with Mobile Impact (front end)
have you run the wizard for phoco?
the best idea is to just get phoco and the phone working first rather than takling front end integration
Old 03-12-2006, 02:14 PM   #22
have a look at the phoco forum too
Old 03-12-2006, 03:23 PM   #23
coucouillu's Avatar
already done! but problem not fixed.
Need help.
Old 03-14-2006, 11:36 AM   #24
teo256's Avatar
I've just brought a new BT-Dongle: BELKIN F8T013 and now I use 4.x driver. But the problem is not solved!!! What can I do?
Software [|||||||||-]
My Own RR Skin [|||-------]
8" LCD TS 1024 x 768 - Epia M10000 - M2 ATX - 512 Mb - 40 Gb - Creative Sound Blaster Audigy 2 ZS Video Editor - Sitecom BT Dongle - GPS BT-77
RoadRunner - Destinator 6 - Waiting for RRMobile
Old 03-14-2006, 12:41 PM   #25
don't know
i set it up from scratch on another and this is what i did
put dongle in...windows recognises and installs crappy windows drivers
update drivers for 'Generic Bluetooth Radio' with WIDCOMM 5.x drivers
install WIDCOMM 5.x software
run through Phoco wizard
go to extended configurator>SymbianOS and change IsSymbian to FALSE
then run phoco
Old 03-14-2006, 12:48 PM   #26
teo256's Avatar
where do you have downloaded WIDCOMM 5.x drivers and software?
Old 03-14-2006, 02:06 PM   #27
i don't know, i have it but don't know how i can get it to you
Old 03-21-2006, 08:07 PM   #28
teo256's Avatar
I've solved all of my problems. Now run all perfectly. Only a last question: how can I "upload" the phonebook in the pc?? I read that 6680 do not supports the sincronization with PhoCo, but there is a way to copy the phonebook in PhoCo??
Old 03-22-2006, 03:20 AM   #29
yeah you need to use Nokia PC suite to get them off the phone and then either vCard converter or csv converter depending on which files come out
both of those programs are with PhoCo
i'm since put it all back in my car and lost the sound during call again, any tips?
Old 08-18-2006, 06:51 AM   #30
redbullah's Avatar
redbullah is on a distinguished road
i had the same issue
ibus error
GTA skin
redbullah is offline   Reply With Quote
