The MP3car.com Store
Go Back   MP3Car.com > Mp3Car Technical > Software & Software Development
Thread Tools Display Modes
Old 04-10-2006, 03:52 PM   #1
Vehicle: 2006 Subaru Impreza WRX STI
My Photos: (0)
XPort proble
I'm having a bit of a problem with XPort. It does not remember what COM port my GPS is attached to. I removed and reinstalled my CarPC last week, and when I hooked everything back up the COM port for the GPS changed (it's a USB device, and uses an internal USB->RS232 converter). When I run XPort, it defaults to no selected COM port. If I use the drop-down and select COM5 (the port the GPS is on, and the only port that shows up), everything works fine until the next time I reboot.
Ideas?
Dave
Rootus is offline   Reply With Quote
Sponsored Links
Old 04-12-2006, 08:40 PM   #2
My Photos: (0)
Okay, so nobody has any idea why xport is failing. So I'll switch gears and ask a different question -- anybody know of a good alternative to xport that has the same functionality?
Thanks,
Dave
Old 04-12-2006, 08:48 PM   #3
My Photos: (0)
try moving XPort to a different folder. That'll force it to start fresh.
b8bboi is offline   Reply With Quote
Old 04-12-2006, 10:56 PM   #4
kiltjim's Avatar
Vehicle: 2000 Subaru Impreza Outback Sport
My Photos: (0)
Are you sure that your GPS does not switch ports every time you reboot? I know this was an issue with USB->RS232 dongles. They redetect every time, and therefore get a new port number.
2000 Subaru OBS
Dell P3 @ 900 Mhz
7" Lilliput TS w/DigitalWW in-dash mount
80GB External HD
I am Zero Bitrate....
kiltjim is offline   Reply With Quote
Old 04-13-2006, 02:01 PM   #5
My Photos: (0)
That worked for me. I renamed the folder, and then when it came up next, the "Enable Service" checkbox was enabled. So I unchecked it then, and re-checked it, and all is well with the world again.
Thanks for your help. I was getting kinda frustrated, I could not figure out where XPort was storing the persistent configuration.
Luckily it seems to be stable as long as I don't move it around. The problem occured because I took the CarPC out of my car to do some maintenance, and I did not record what USB port everything was connected to.
Dave
Sponsored Links
vB code is On
Trackbacks are Off
Question for Curiousity or someone who knows (xport related) Sonicxtacy02 Software & Software Development 4 04-02-2006 04:55 PM
Xport 3 problems Cheekz185 GPS 17 02-27-2006 10:15 PM
Xport - Thoroughly confused trying to get this to work! tbird2340 GPS 3 06-14-2005 07:27 AM
com port splitter, yeah i know XPORT, but no liquid_smoke GPS 6 12-10-2004 09:53 AM
Some warnings about Deluo Routis 2004, MapPoint 2004 & XPort dumpper GPS 13 07-15-2004 12:07 AM
Sponsored Links
SEO by vBSEO 3.1.0
Ad Management by RedTyger
