The MP3car.com Store
Go Back   MP3Car.com > Mp3Car Technical > Software & Software Development
Thread Tools Display Modes
Old 04-14-2006, 06:26 PM   #1
tolisn's Avatar
Vehicle: Mazda6
My Photos: (0)
Running a VB program before WinXp shuts the computer off?????
When the power button on an XP based machine is pressed then winXP shuts down. Is there any way to auto run a VB program before win XP shuts down?
The road is long but we are getting there.
tolisn is offline   Reply With Quote
Sponsored Links
Old 04-14-2006, 07:24 PM   #2
My Village Called
0l33l's CarPC Specs
0l33l's Avatar
Vehicle: 1995 Lexus SC300 1997 Mazda Miata
My Photos: (0)
There's a program that can do that.
PowerVoice v1 | NaviVoice Source
GammaControl v2.4
SKINbedder v3
1995 Lexus SC300 <-- Weekend Car
1997 Mazda Miata <-- Daily Driver
0l33l is offline   Reply With Quote
Old 04-15-2006, 12:31 PM   #3
tolisn's Avatar
Vehicle: Mazda6
My Photos: (0)
I've searched. All I can find is programs that monitor the "Start-Shutdown" sequence. None of them monitor the power button shutdown sequence. Any more ideas or tips?
Old 04-15-2006, 08:30 PM   #4
Mobile Impact Creator
reddeath30's Avatar
Vehicle: 1991 Toyota Celica GT Coupe
My Photos: (0)
What are you trying to accomplish by running a program when XP shuts down?
Mobile Impact
Highly innovative car computer multimedia/entertainment system software.
http://mobileimpact.biz.tm
reddeath30 is offline   Reply With Quote
Old 04-16-2006, 06:00 AM   #5
tolisn's Avatar
Vehicle: Mazda6
My Photos: (0)
I,m trying to run a program that will send a command to a servo so that it can close a custom motorized screen. This should be done a soon as the power button is pressed. Before the pc is shut done it should run this program and when the program finishes it should then shut down gracefully.
Old 04-16-2006, 09:30 AM   #6
TheLandYacht's Avatar
Vehicle: 2005/Dodge/Sprinter
My Photos: (0)
Here ya go.
http://www.pcworld.com/howto/article...,115628,00.asp
TheLandYacht is offline   Reply With Quote
Old 04-16-2006, 09:31 AM   #7
reddeath30's Avatar
My Photos: (0)
Do you have this servo program yet?
Mobile Impact
Old 04-16-2006, 11:44 AM   #8
My Photos: (0)
Do you have your power button set to shutdown or suspend/hibernate? It is easy to intercept suspend/hibernate calls and deny them, run what you would like to and initiate your own shutdown when your process is done. For some reason they don't make shutdown that easy.
whodwho is offline   Reply With Quote
Old 04-16-2006, 11:59 AM   #9
tolisn's Avatar
Vehicle: Mazda6
My Photos: (0)
Hey guys thanks for all the feedback
@TheLandYacht. I tried this outr because it seems a simple solution. It did not work for me. I made a program in VB the would beep once you run it but did not succed in invoking it during shutdown
@reddeath: The final servo program is not ready yet. I will be using a phidget servo controller. Probably I will modify one of the examples found here (btw. I'm not a programmer so I'm taking this very slowly)
http://www.phidgetsusa.com/tutorials...Controller.asp.
My need is actually very simple. Run the program that will send a set value to the servo so it can retract my screen.
@whodwho: I have the power button set to shutdown the computer since my custom SD controller completely turns off the system (no power drain at all).
Old 04-16-2006, 12:09 PM   #10
My Photos: (0)
Ok so I got passed the shutdown issue mentioned above. I can give you something to try in a couple
FYI, don't know if you know about the hibernate function, it takes an image of what is in memory and writes it to a file and no power needed. it boots much quicker and back where you left off. I have multible laptop drives that I use for different purposes and I use the hibernate and can switch to a different drive and boot where I left off last on each of them.
Sponsored Links
Old 04-16-2006, 12:13 PM   #11
My Photos: (0)
The solution you are looking for will be found in the Windows XP Policy Settings:
Go To Run: Type in MMC, hit enter
Console 1 appears, select file, add/remove snap in
Click Add, then select Group Policy Object Editor, add finish etc...
Under Console Root goto: Local Computer Policy -> Computer Configuration -> Windows Settings -> Scripts -> Shutdown
This is where you will add your VB script.
As long as Windows recieves the command to initiate a shut down, it will always include scripts in this locaiton.
Hope this helps....
AZMOUSE is offline   Reply With Quote
Old 04-16-2006, 12:38 PM   #12
tolisn's Avatar
Vehicle: Mazda6
My Photos: (0)
Hope this helps....
This one looks like its functioning exactly as I need it. Thank you all
Old 04-17-2006, 04:59 PM   #13
nameeri's Avatar
Vehicle: 2003 Honda Civic
My Photos: (1)
Frodo also wrote this app. You can read about it here and get it
http://www.mp3car.com/vbulletin/showthread.php?t=53753
Civiputer: Dont have one anymore, but here is what is used to be!
nameeri is offline   Reply With Quote
Sponsored Links
vB code is On
Trackbacks are Off
power problems while car is running.. TimW General Hardware Discussion 28 03-18-2006 09:11 PM
Computer running constatly? Scruit Power Supplies 8 08-06-2003 02:49 AM
How long can an opus power the computer running without Durango running?? nolmscheid Power Supplies 9 11-01-2002 11:21 AM
My hardware/Software computer control system - Wish list/feedback - Easy power off DarkWolf General Hardware Discussion 22 08-13-2001 01:42 PM
controlling computer running winamp with pda anothamp3frk Classified Archive 6 01-23-2001 12:57 AM
Sponsored Links
SEO by vBSEO 3.1.0
Ad Management by RedTyger
