Go Back   MP3Car.com > Mp3Car Technical > Software & Software Development
Old 05-14-2006, 01:42 PM   #1
d_sellers1's Avatar
d_sellers1 is on a distinguished road
LOG: Software installation and setup
One thing that I have not seem much about on MP3Car is all the software that ultimately gets installed on a CarPC. Well, I just started preparing the harddrive and been bench testing the unit so I began documenting what software I've installed and some of the more important settings that I've set.
Note: This is not intended to document the only or best way to set up a CarPC. This is simply a documentation of what I did in order to get the software configured the way that I like it.
New install:
Code:
Set Computer Name, Description, and Workgroup Installed .Net Framework 1.1 & 2 Installed ATI Display driver Installed Gigabyte GA-7N400 Pro v1.0 chipset & audio drivers Installed Buffalo WLI2-G54-USB driver and connected to wireless network Installed Daemon Tools 4.03
Old install:
Code:
Completed --------- Installed Mini XP (Stripped 125MB) Installed ASUS V3800 driver Set Computer Name, Description, and Workgroup Set Language to English (United States) Installed WinAmp 2.95 with Minimal installation Installed Media Player Classic Installed Firefox 1.0.3 Installed chipset drivers for Gigabyte GA-7N400 Pro v1.0 Installed Audio driver Installed driver for Buffalo WLI2-G54-USB wireless NIC and joined my network Installed Earthmate USB to serial driver Installed RoadRunner and zots.day skin (UPDATE: Removed zots.day in favor of Proximo’s CF skin) Installed AutoIt v3.1.1 (updated to 3.1.1.123) Installed DaemonTools 4.03 (for use with my iGuidance 2.1NA ISOs) Installed iGuidance 2.21 with modified iGuidance.exe Copied SkinBedder 2.5 that I already preconfigured during testing several months ago Patched iGuidance using iGBigButtons-BLUE-21NA and ResHacked borders & buttons Installed iGMon Installed DivX 6.2, Xvid 1.03, & m2v codecs Enabled hibernation Installed Bluetooth adapter and driver. Paired Motorola SLVR. Installed .Net Framework 1.1.something Installed .Net Framework 2.something Insalled PhoneControl.net (Unsuccessful; will research more) Set password for username (for compatibility) Used TweakUI on Memory Stick to set AutoLogon Used TweakUI on Memory Stick to uncheck Unread Mail Used TweakUI on Memory Stick to disable Bitmap Image, Rich Text document, Wordpad document, and AutoIt v3 script templates Used TweakUI on Memory Stick to not show Files Stored on This Computer in My Computer Used TweakUI on Memory Stick to hide My Bluetooth Places and Recycle Bin from Desktop Used TweakUI on Memory Stick to not show username on Start Menu, show toolbar notification icons, and warn when low on disk space Used TweakUI on Memory Stick to Prevent applications from stealing focus Unchecked Prompt for password when computer resume from standy in Display > Screen Saver > Power Options > Advanced Set power and sleep buttons to hibernate Unchecked Use the Welcome Screen under Control Panel > Users > Change how user log on this machine Set rr.exe as shell in HKEY_LOCAL_MACHINE \ SOFTWARE \ Microsoft \ Windows NT \ CurrentVersion \ Winlogon Added DisableStatusMessage DWORD Value of 1 to HKEY_LOCAL_MACHINE \ SOFTWARE \ Microsoft \ Windows \ CurrentVersion \ policies \ system \ Enabled Use Simple File Sharing Created Music, Video, and TEMP folders. Also shared with Write access. Installed Proximo’s CF skin per his instructions Installed TightVNC as a service for remote access (makes it easier to edit configuration files and to transfer media to the CarPC) Updated Flash Player (CPU Usage was too high) Load flash.ocx from www.rrdownloads.net/Flash.zip (CPU Usage was too high) Loaded Ford flash clock Installed Process Explorer from Sysinternals as a replacement to Task Manager Installed ffdshow to attempt to normalize the volume from videos (kinda works)
Code:
Hard drive stats: ---------------- I'm currently using a 250GB HDD with two partitions (1 for OS; 1 for media). System 22.2GB of 24.4GB FREE Storage 202GB of 208GB FREE MP3s: 220 songs DVD Rips: 5 movies Music Videos: 30 videos
This log will be updated as I go. If you see something that I still need to do then leave me a message.
Derek
Progress [||-------]
View my Worklog to see some of my progress.
Downgraded Progress - Starting with another car... 09/13/06
d_sellers1 is offline   Reply With Quote
Old 05-30-2006, 07:04 AM   #2
Redian's Avatar
Redian is on a distinguished road
one thing you might consider doing is changing firefox to a less memory hogging program like opera (6 windows for firefox is about 80MBs of ram, 6 windows for opera is onlky 22MBs of ram, see the difference) they have equal security and such so you wont lose anything, and the real kicker to using ipera is you can use mouse symbols (moving your mouse in a circle) and voice commands
2004 Impreza WRX CarPC Install
I am willing to host any legal downloads that may benefit the CarPC community - PM for info
"When you go 0-60 in 4.5 seconds, you don't need a made up character called fast. Thats what makes a Subaru, a Subaru."
DG4L
Redian is offline   Reply With Quote
Old 05-30-2006, 09:37 AM   #3
mrheat's Avatar
mrheat is on a distinguished road
Sticky!
mrheat is offline   Reply With Quote
Old 05-30-2006, 09:41 AM   #4
Neither darque nor pervert
DarquePervert's Avatar
DarquePervert is a glorious beacon of lightDarquePervert is a glorious beacon of lightDarquePervert is a glorious beacon of lightDarquePervert is a glorious beacon of lightDarquePervert is a glorious beacon of light
Quote: Originally Posted by mrheat
Sticky!
No, not a sticky.
Every user's software requirements are different.
For example, I've made very few tweaks to WinXP.
I run MBM5 to monitor temps. I'm running StreetDeck and the support software necessary for it, which isn't something everyone has access to.
You may or may not need Powerstrip to force a certain resolution.
Although I highly applaud the idea of keeping notes on what you've installed and how it's configured. It's something I'm going to add to my worklog.
LOOKING FOR THE FAQ? IT'S HERE.
You never found that link, did you? Why? It's hard to find in the NavBar across the top of the forums, amongst a lot of other crap.
TELL MP3CAR YOU WANT A LINK TO THE FAQ IN A MORE OBVIOUS, NOTICABLE LOCATION HERE.
Old 05-30-2006, 11:06 AM   #5
mrheat's Avatar
err i mean stick it to RoadRunner forum
Old 05-30-2006, 11:17 AM   #6
Confusion Master
Enforcer's Avatar
Enforcer has a brilliant futureEnforcer has a brilliant futureEnforcer has a brilliant futureEnforcer has a brilliant futureEnforcer has a brilliant futureEnforcer has a brilliant futureEnforcer has a brilliant futureEnforcer has a brilliant futureEnforcer has a brilliant futureEnforcer has a brilliant futureEnforcer has a brilliant future
or move it maybe
Enforcer is offline   Reply With Quote
Old 05-30-2006, 08:03 PM   #7
d_sellers1's Avatar
Thanks for the tip. I have noticed on my home computer the Firefox does eat a lot of memory at times (seen as much as 125megs with one tab). I will definitely check out Opera. I know it's received good reviews in the past.
Sticky!
Quote: Originally Posted by DarquePervert
No, not a sticky.
I do not intend for this thread to be a definitive how-to. What works for me may not work for someone else. You'll see me say that many times here on in the forum. I simply want to bring to everyone's attention the amount of software set up is involved. Everyone always thinks about the hardware but not much is talked about regarding the software aspect as a whole. Many people may not even realize that they have put in a fair amount of work until they actually sit down and make a record of it when starting from scratch. I will edit my first post to reflect this a bit better.
For me, I can use this as a guide in case my system ever crashes and I need to start over from scratch. (cross-fingers...)
Quote: Originally Posted by Enforcer
or move it maybe
I figured just the general software forum would work but I think that not many people look in here. They just go in to the front-end or support software forums. If a mod or admin wants to move it to somewhere better suited, then I've got no problems with that.
Derek
Old 06-04-2006, 08:46 PM   #8
d_sellers1's Avatar
I'm formatting the system. It's been running for almost three weeks now. I was running a version of Windows known as Mini-XP. The installation is only 125 megabytes. A lot of useless stuff has been taken out of it. This cuts down on the resources used and the amount of time it takes to start up.
Unfortunately, some of the stuff that has been taken out may be needed.
- I cannot access ATI's CATALYST to change display settings. It says it can only be done by an Admin even though I am the Admin and even created another account with Admin priviledges.
- I cannot access UltraMon's settings because it runs in the System Tray. The system tray has been removed. The only thing that runs down there is the time. No icons appear. The only way to access UltraMon is through its system tray icon. How ironic...
- I cannot seem to access the files on my Motorola SLVR via the Bluetooth connection. Everytime I tried, Explorer would crash and start over. (I tried to set Explorer back as my shell instead of RR to see if this would fix some of my problems. No luck.)
The downfall with doing this is now I'm going to have to go through and try to get rid of the unnecessary stuff. I started writing this post earlier this morning. Since then I've got Windows up and running along with most of the drivers. Windows is using about 215megs of RAM (230 with RR playing a music video). This won't do and will be changed.
Derek
Old 06-06-2006, 07:02 PM   #9
f1vlad's Avatar
f1vlad is on a distinguished road
That sucks that MiniXP didn't work for you. I was goign to try it for myself. I actually still will just out of curiosity. There's another thing called TinyXP. I wonder if these are the same things.
Personally, I've installed FEDORA CORE and Windows XP as a dual boot on my car PC, so far everything's great but Fedora Core takes a long time to boot up XP is much faster.
f1vlad.com/subaru/sparow
■■■■■■■■■■■■■■■■■■■■■ 80% progress ¤ (sold)
f1vlad is offline   Reply With Quote
Old 06-08-2006, 10:11 PM   #10
d_sellers1's Avatar
The MiniXP was great in the aspect that most of the garbage was gone, it was real small, and used very little system resources. Unfortunately, I am trying to set up a dual-screen system that will have access to my cell phone. Even running the install of XP, I am still running in to problems with the dual screen. Who knows. I may just go back to MiniXP if the screens don't work out like I hope. Right now I think the ATI drivers are garbage because it tends to mess up anytime I use the theater overlay mode. I have to reload the driver after running RR with that setting enabled (kinda defeats the purpose).
Derek
My 2006 Scion xB (portable) Carputer setup! w/pics! breaker021 Show off your project 26 01-05-2007 10:34 AM
Software Review: PhoneControl.NET zorro The Review Palace 8 11-20-2006 09:01 AM
Length of running/working installation cpjolicoeur General MP3Car Discussion 6 02-22-2006 01:42 PM
Audio Phase of my Installation Osiris Car Audio 14 04-11-2005 01:03 AM
installation problems morgan06 Media Engine 0 02-23-2005 09:42 AM
