The MP3car.com Store
Go Back   MP3Car.com > Mp3Car Technical > Software & Software Development
Thread Tools Display Modes
Old 04-26-2002, 05:27 AM   #1
My Photos: (0)
Unhappy Lcd Help Needed With Mpxftsr
I'm using mpxplay and frontend program mpxf and mpxftsr. All works fine but mpxftsr DON'T grap informations from MPXPlay. When mpxplay is started I can see only name of the track and total time but nothing more.
I have 4x20 LPTLCD.
Everything else is ready to fit my player to my car. But these informations.
If it's possiple to mail me taneki@hotmail.com I'd be thankful.
taneki
taneki is offline   Reply With Quote
Sponsored Links
Old 04-27-2002, 10:25 PM   #2
My Photos: (0)
I had the same problem when I first started using MPXFTSR... It turned out that the version of MPXPLAY was too recent, and had to get an older version that was compatible with MPXFTSR. (I believe it is 1.4.2 or below).
Good luck.
Guy Foster - author of FostRF
Car: 1997 Acura 3.0CL
Computer: Pentium 133/16 megs/6.6gigs/Vibra 16C/40x4 backlit LCD
Software: MS-DOS 6.22 -MPXPLAY - MPXF TSR - FOSTRF
Visit my Yamp3 player website (under construction) at: http://www3.sympatico.ca/guyfoster/yamp3
Guy Foster is offline   Reply With Quote
Old 04-29-2002, 02:44 AM   #3
My Photos: (0)
New problem!!
I changed to mpxplay version 1.42 and now I have new problem. Both mpxf and mpxftsr draw their logos on lcd but when mpxplay starts, it always freezes my computer. What is wrong!!!!!
I wouldn't want to give up using mpxf. HELP ME!!
taneki
Old 04-29-2002, 05:32 AM   #4
My Photos: (0)
Try running MPXF ONLY and see if it works... And then run MPXFTSR ONLY, and it see if it works (by manually going into MPXFPLAY). That'll give you a better idea of where you stand, and it's easier to troubleshoot... don't forget to have a look at your config.sys and autoexec.bat.... make sure you have emm386.exe and himem.sys, and that you aren't using smartdrive (I heard it can cause some probs).
Old 04-29-2002, 09:20 AM   #5
My Photos: (0)
MORE problems!!
I'm using now mpxf menu and mlt frontend together. Both work fine in windows but in dos mpxf draw its logo so ******* slow.
What settings Can i change to get lcd faster.
What bios settings are best to parallel port?
Seems like nothing work to me!!!!!!
taneki
Old 04-29-2002, 12:31 PM   #6
My Photos: (0)
Play around with your MPXFTSR.CFG... And read the documentation that comes with it, it'll answer all the questions that you've been asking so far.
Sponsored Links
vB code is On
Trackbacks are Off
Sponsored Links
SEO by vBSEO 3.1.0
Ad Management by RedTyger
