Go Back   MP3Car.com > Mp3Car Technical > Software & Software Development
Old 08-30-2007, 09:49 PM   #256
NiSlo's Avatar
NiSlo is an unknown quantity at this point
Wow, this frontend is quick!
I'm not to keen on the standard skin, but the functionality is great!
Is destinator supported? I notcied in the .ini that it's doesn't seem to be at the moment.
I installed my carpc into my pet Kangaroo, mate.
NiSlo is offline   Reply With Quote
Old 08-30-2007, 10:10 PM   #257
enitalp is on a distinguished road
Quote: Originally Posted by blk02si View Post
You are the man!! I cannot wait to see this in action. I'm release a V4 RR skin pretty soon but it has a ton of changes to the code. V3 running on enicar controlling mplayer is my dream. If you could let me know some of the differences I could help with this as I would be more than happy to skin your app if I know what does what. Are you working to get the GDI and background loader working too?
Here is a the actual version on enicar. Still have to work on it.
enitalp is offline   Reply With Quote
Old 08-30-2007, 10:11 PM   #258
I have destinator 6, destinator 7, NRoute support in my task list. peharps in one or two weeks.
Old 09-01-2007, 04:51 PM   #259
Progressing. Still a lot to do on this skin. But at least the drawing is almost done. Transparency of button is fixed.
Old 09-02-2007, 07:09 PM   #260
Hey people.
Some of you are playing with versions i've put public. Actualy I still have a few modification to fit my needs. But if we are 3 to use it i may not doing some functionality like supporting all the gps software on earth if the 3 of us are using iguidance, etc...
So i may need some input or not of people using/willing to use enicar on missing functionalities, lack of compatibility with their daily skin etc...
Thanks.
Old 09-02-2007, 07:44 PM   #261
will_santana's Avatar
will_santana is an unknown quantity at this point
why isn't this on the frontends section
I've never seem this before. as far as i've been reading, the project is great!
[]s
Tigra Clube Brasil
will_santana is offline   Reply With Quote
Old 09-02-2007, 08:02 PM   #262
Confusion Master
Enforcer's Avatar
Enforcer has a brilliant futureEnforcer has a brilliant futureEnforcer has a brilliant futureEnforcer has a brilliant futureEnforcer has a brilliant futureEnforcer has a brilliant futureEnforcer has a brilliant futureEnforcer has a brilliant futureEnforcer has a brilliant futureEnforcer has a brilliant futureEnforcer has a brilliant future
[]s
Depends on when the Mods/Admins decide it is worthy of having it's own forum.
Enforcer is online now   Reply With Quote
Old 09-02-2007, 10:51 PM   #263
High Voltage
blk02si's Avatar
blk02si will become famous soon enough
Looking good enitalp, this project deserves its own forum under the frontends!
I feel honored that you decided to use my skin for further enicar development, now I'm assured compatibility with my setup!
We are on the same page here from a development standpoint, slim, fast, and solid. If you need any type of skinning help on this project let me know, shock v4 is not far off and the code base is much more organized and (theoretically) faster than v3. If enicar will run shock v3 than it should run v4 without any changes.
Again keep up the great work, im going to work on some documentation so I can get v4 out there.
blk02si is offline   Reply With Quote
Old 09-02-2007, 11:40 PM   #264
Perhaps i'm using your skin because it looks likes something i own
For you skin, i think i will install a version of RR on my work PC to check some stuff. I don't see why i have problem. I've managed to load all the element, makes the navigation fully working but i have some clipping issue with some slider, text that are cut, and i have to figure out how to execute the setvar. And also i have to understand the use of the exit and stack of page. Definitivly i didn't understand anything to that thing. Nothing logical. Ho and a probleme with IG and the background picture that overlap IG.
The only change i would have to made in your skin is the startup of IG by a button command.
Old 09-03-2007, 12:19 AM   #265
NiSlo's Avatar
I'd be really keen to see Destinator supported
I typically use Centrafuse due to it's easy installation and was turned off RR by it's seemingly over complicated setup, plus I HATE having to install winamp to use it.
Centrafuse just seems a little too sluggish although it is quite well refined. This one looks promising!
Old 09-03-2007, 10:10 AM   #266
High Voltage
blk02si's Avatar
Whats goin on NiSlo, are you still running my xpe distro? Im with you on the scrapping winamp for mplayer.
enitalp, I would suggest reading the skin commands.txt file included with the roadrunner distribution. I have attached it for your reference. This will explain the syntax and function of the code you find in the .skin files.
The reason your text is getting clipped is because you need the ISOPEUR font, its a condensed font. Or we will need to modify the skin code to have a larger display area for the new font.
Old 09-03-2007, 10:14 AM   #267
Thanks, this is my bed book already. I think i will send some correction i found so many stuff in skins that are not in this doc.
Old 09-03-2007, 10:28 AM   #268
High Voltage
blk02si's Avatar
That doc does need some updating! guess I should have figured you already read that a few times
In any event looking forward to using some C++ code.
BTW your mustang looks awesome, its got an aggressive intimidating look.
Old 09-03-2007, 10:42 AM   #269
Thanks a lot. That's true my front bumper is... there, ready to bite you. And with my slick tire on the track, what a beast.
You should check my new thread : http://www.mp3car.com/vbulletin/soft...r-v0-09-a.html
Old 09-03-2007, 06:55 PM   #270
REQUEST: Run Multiple RR instances Jarrod Road Runner 33 12-21-2008 08:54 AM
How do I use the Extension Plugin Interface ? guino RR FAQ 0 06-11-2006 06:49 PM
RR doesn't start Phoco on initial load.. DutchBurner Road Runner 16 11-04-2005 02:17 PM
RR Interchange - Update RR via a USB Media Stick Gobby Road Runner 60 10-04-2005 05:48 PM
status update.... 0l33l PowerVoice 17 05-05-2005 01:22 PM
