Go Back   MP3Car.com > Mp3Car Technical > Software & Software Development
Old 08-27-2006, 08:46 AM   #91
nosoup4me's Avatar
nosoup4me is an unknown quantity at this point
So this puzzled me why I drove around with my IG3 working in ENICAR and my gps receiver on and all worked. I went out again to my car just now and sure enough IG3 crashed at the start of ENICAR but ENICAR continued to load. Normally I load IG3 at start before my skin so when I go to nav the screen doesnt flash; so yesterday during testing, after everything booted, I closed my RR and launched ENICAR and it worked. This morning I tested this theory, after I found IG3 crashed from the launching of ENICAR... Iclosed ENICAR... launched IG3... then again launched ENICAR and it worked. I drove around the block and it tracked great.
nosoup4me is offline   Reply With Quote
Old 08-27-2006, 09:10 AM   #92
enitalp is on a distinguished road
Yeah this is surely because of my way of launching IG. you can see that IG is hidden while loading, perhaps it does something that make it crash when it's totaly hidden. I have to check that.
To bad because i was very proud of my IG loading at start without seen it.
enitalp is offline   Reply With Quote
Old 08-27-2006, 09:20 AM   #93
nosoup4me's Avatar
Yes, the way it currently loads is the bomb! You are definetly on the right track. It does seem to be related to having an actual connection to a receiver if that helps narrow down the problem. Also, the fact it crashes as soon as you set a destination.
Old 08-28-2006, 09:36 PM   #94
I'm still searching for a solution to the IG crash. I don't find why. tried 100 solutions got 100 crash. So stupid.
PS you could try with the menu bar still on. Seems to not crash with. change your ini file. Or perhaps its because of my very bad reception in my home, who knows.
Old 08-28-2006, 10:40 PM   #95
tn6478's Avatar
tn6478 is an unknown quantity at this point
It will crash everytime regardless. The only way is to disable the GPS. IGuidance crash right before ENICAR LOADS up. Try the com ports. Could be a problem with it trying to pick up the sat signals and then it crash. Beside that the programs is great. just need a little more work. If anyone can make there work like Nero Home that would be nice also. I think streetdeck is base on that
tn6478 is offline   Reply With Quote
Old 08-29-2006, 07:23 AM   #96
nosoup4me's Avatar
when you launch IG3 and make sure it is running properly, then launch ENICAR you will get a com port error, but it runs ok after responding OK.
are you trying to set the com port during launch?
Old 08-29-2006, 07:42 AM   #97
No i did nothing with com port.
And i tried to put a delay at startup to make sure it's fully launched and i get the same result. I also tried to launch it later, when clicking on nav button, same result.
tried to not remove the toolbar, menu, etc.. same result.
etc....
Old 08-29-2006, 07:45 PM   #98
V0.04 is out.
not a planned version but iguidance crash needed to be fixed.
http://www.enitalp.com/EniCarV0.04.rar
This is an update from V0.03
What's new :
- ESC Button Command working
- MENU Button Command working
- Support for page not matching skin size
- Fix a crash in skin navigation
Now Bongo skin works pretty well and surely some other using the same style of using command.
- Indicator started.
- Loading Indicator End
- Fix IGuidance crash 1 day without any crash with gps module.
NB indicator are loaded, react to clic but does nothing, this is just because it's a work in progress and the IG crash needed to be fixed.
Old 08-30-2006, 04:02 AM   #99
Of Ice and Men
LagunaICE's Avatar
LagunaICE is on a distinguished road
Tell me what software you are you using (i will tell you who you are ) and i will have a look for embeding more software.
Hello brave one, following to this topic I would probably say most of Europeans use different D3 front-ends (FreeDrive, MapMonkey, Meedio D3 plugin) since Destinator maps are probably most complete at the moment and there is (buggy but still documented) SDK available. Since Freedrive went "open source" too and its author is one of the most helpful and community sharuing guy in this forum, I believe most europeans would appreciate if you could (with help of Cdrskull probalbly) release a version of EinCar that would be built on top of D3 SDK directly.
Would dou you say?
Pretty please...
LagunaICE is offline   Reply With Quote
Old 08-30-2006, 07:58 AM   #100
Ok. After Finishing a few things i will go with destinator integration.
Old 08-30-2006, 12:38 PM   #101
tn6478's Avatar
Video playback has a problem sometimes it just doesn't want to stay in its own screen layout. You have to hit another screen and click back for it to display correctly
Old 08-30-2006, 01:22 PM   #102
ok thanks. will look at that. surely due to my modification for bongo skin.
haven't play video since.
Old 08-30-2006, 08:11 PM   #103
Made some test with MC2.0 and i don't find any problem.
With witch skin did you have problem ?
Old 08-30-2006, 09:02 PM   #104
Today's Work
- Totaly rewrite the sound control code. Way much cleaner.
- Indicator Mute Done
- Fix a bug in bitmap display sometimes transparent.
- Label STATUS done
- Flash Label Transmission Done.
- Done some change in IG integration to be much safe.
- Album Art Label Done (mp3 & video, find the first jpeg in the media dir, if more than one jpg is found try to give the one with 'front' in the name)
If you have some idea to improve album art, say it. If you use a skin tell me so i could work more on compatibility with new skin.
Yeah it's EniCar and not RR, hard to tell the difference.
Old 08-30-2006, 10:39 PM   #105
mikevsgeek's Avatar
mikevsgeek is on a distinguished road
how do you sent up the weather page? i was unable to find an ini file anywhere...
mikevsgeek is offline   Reply With Quote
REQUEST: Run Multiple RR instances Jarrod Road Runner 33 12-21-2008 08:54 AM
How do I use the Extension Plugin Interface ? guino RR FAQ 0 06-11-2006 06:49 PM
RR doesn't start Phoco on initial load.. DutchBurner Road Runner 16 11-04-2005 02:17 PM
RR Interchange - Update RR via a USB Media Stick Gobby Road Runner 60 10-04-2005 05:48 PM
status update.... 0l33l PowerVoice 17 05-05-2005 01:22 PM
