08-31-2006, 07:50 PM
#121
Quote: Originally Posted by mikevsgeek
just something i noticed, while playing music in the music screen... if you scroll up or down, the middle item is always selected and scrolling, even if its not the song that is playing... shouldnt the song thats playing stay selected?
No. i kept the behavior of RR that permit to select another song, so if you press play this song is played. if you select another song without doing nothing, and the current mp3 is over when the next start the list will be change to display the current song.
08-31-2006, 07:54 PM
#122
Ok iguidance crash as soon as he try to access to gps (if you have one) since the begining, whatever i change. I tried with the past version to fix that but without success. I will try to make my gps receiver to work in my house because with no signal IG doesn't crash. And i have no signal so i don't crash.
No version until i fixe this very annoying bug.
08-31-2006, 08:14 PM
#123
double post
08-31-2006, 08:16 PM
#124
is there anything that i might be to do to help you fix this bug? like can you enable any iG debugging or something like that?
i never noticed that in RR... my bad on that one... i think my attention was drawn to it more since the MC2 skin has much larger playlist fonts than the rr skin i am using
08-31-2006, 08:23 PM
#125
No nothing someone can do. i running in my place with gps receiver and my 20 meters usb cable to find a spot where i can access to more than 2 sat. i need a third one for gps to work
08-31-2006, 10:39 PM
#126
Ok i was able finaly to get GPS to work. And after thousand of try, IG stop crashing.
For the coder who are listening, if you do that :
Launch IG
while(getwindowhandle(IG));
setparentwindow(IG,MYWINDOW);
other instruction
IG will crash while in other instruction. It seems that IG doesn't support to have a parent during his first second of life. (yeah like a children until 18 years old  )
So i put IG as my child the first time i draw it in navigation screen.
09-01-2006, 12:38 PM
#127
so when is the updated ENICAR fix be available
09-01-2006, 03:33 PM
#128
I finished the music/video mute when iguidance speak.
I want to finish the retrieve of gps data with xport for the mc2.0 skin, peharps this evening if my gps could catch another time the signal.
and i think i could release the 0.05 version.
09-01-2006, 04:48 PM
#129
are you referring to the menu/dest/2d-3d/zoom buttons? those are the only things in the gps screens...
im still trying to figure out why the scrolling on my car-puter is laggy and the load wont work, but it all works fine on my desktop computer... anyway I can turn on debug? do you know of any windows dependancies i might have removed by using nLite?
09-01-2006, 05:42 PM
#130
No i'm refering to the direction, speed information etcc used in the flash menu screen.
The scrolling ? are you refering to the filename scrolling in the playlist/filelist ? that's normal if it seems laggy. For the instant it's not time based. Each time i could, i move from 1 pixel the label. That's not the correct way to do it, but it was the fastest for doing it in 1 mins.
For the load that don't work you mean : if you go in music, the browse then select a directory or a file then clic on the load button on left ? Does the page close & goes to the audioplayer screen ?
09-01-2006, 05:52 PM
#131
FreeDrive Creator
I think the speedo is out on the mc2.0 screen..cant remember how much.. if some one lets me know I wll fix it.. (1oo kmh or 100 mph would be a good value.. ie.. GPS speed = 92 speedo = 100)
CdR
09-01-2006, 08:27 PM
#132
when I refer to the laggy-ness, I mean while browsing my mp3s, I hit the down button and it takes give-or-take 5 seconds for the screen to move up/down... and then when I do find what I want, I click load and nothing happens.. it just sits there... I am however able to double-click on a parent folder and few the sub-folders/files
09-01-2006, 11:16 PM
#133
This is a very strange behavior. The only things for me is that the load button doesn't at least make you going back to the AudioPlayer.skin is an error while reading the AudioBrowser.skin.
If i have an error while parsing a page, i stop loading it and then load the next page. So if a button doesn't react that's because it was not loaded.
And peharps the error of the loading page makes the list acting strange as you seems to get it. 5 second to scroll is very very very very huge.
In the next version i will put skin parsing error in the log file.
Did you have the same audiobrowser.skin in your car than in your home ?
09-02-2006, 08:44 AM
#134
yah...
all i did was copy the files over and then change the settings in the ini file
09-05-2006, 08:28 AM
#135
V0.05 Is out.
http://www.enitalp.com/EniCarV0.05.rar
as usual it's an update from the previous version. Next version will be a full version for people getting it from here.
- Totaly rewrite the sound control code. Way much cleaner.
- Indicator Mute Done
- Fix a bug in bitmap display sometimes transparent.
- Label STATUS done
- Flash Label Transmission Done.
- Done some change in IG integration to be much safe.
- Album Art Label Done (mp3 & video, find the first jpeg in the media dir, if more than one jpg is found try to give the one with 'front' in the name)
- Fix a bug in time
- Some intern cleanup
- Totaly redone the window of Enicar, changed from Dialog to Window.
- Finaly fixed the IG crash, start is less clean than before but no more crash.
- Mute volume when IG "speaks"
- Fix crash when loading Brainz skin, doesn't work but at least it load.
- Better Mute Volume for IG.
The IG Mute works pretty well. Some tweak need to be done, for the instant the unmute will be 0.5s after the last start of a word, and the music/video volume will be decrease by 2/3. In the next version those parameters will be in the .INI to make it your taste.
| Thread Tools |
| Display Modes |
Linear Mode
