05-15-2002, 12:13 AM
#1
winamp volume settings help
every time I start winamp the volume goes back to the defult 90% is there a setting that keeps the volume to the last place I change it to?
05-15-2002, 01:01 AM
#2
Vehicle: None
Re: winamp volume settings help
winamp gets its volume setting from the current WAVE OUT volume setting on your sound card. Its the same control that is managed when you double click that little yellow speaker in the right hand corner of the taskbar of windows and the mixer controls pop up.
Thus I would say that your soundcard mixer software is resetting this value when u start up windows..... winamp does not store the volume setting itself.....
Project - GAME OVER :(
05-15-2002, 06:19 AM
#3
Vehicle: '97 Mustang Cobra
not entirely true...Winamp Does store the last volume and so does the OS. For it to NOT store the last volume, tells me something is changing the value of "volume" in the winamp.ini file. Or on the other hand something might also be changing ur sound mixer volume
abcd-1
06-23-2003, 09:40 AM
#4
Vehicle: 90 / Mazda / MX-6
similar problem
I am searching for a solution to a similar problem, I dont have this problem all the time, just some times. I dont have a TFT screen in my car just a character LCD so it sucks cause i got to drag a monitor out to my car pull out my carputer, run extension cords and everything just to set the volume. its gheto. cause my volume is controled by the master volume with girder, so i just leave winamp volume at 100% but sometimes it will set itself to 0%. BLAH! I am thinking that there might somewhere out ther be a plugin that sets the winamp volume on load. but i have not found it yet if it exists
Anything worth doing, is worth doing right.
http://www.mp3car.com/vbulletin/showthread.php?s=&threadid=15017
06-25-2003, 10:09 AM
#5
Vehicle: Winter: "83 VW GTI" Vehicle: Summer: "71 VW Bus"
I use WinAmp 2.9 with no problems with volume control. If you kill the power to the computer then it will go back to the previous volume setting when you last shut down properly.
GTI - Palm IIIe controlled with Radio faceplate hack for keyboard control of WinAmp w/ Vocal Genre playlist loading.
VW Bus - 10.4" vga lcd. Loaded with same software as above.
06-26-2003, 12:27 AM
#6
Vehicle: 1993 Nissan Sentra XE
i am using 2.92 and the volume stays where it was the last time winamp was open. I usually leave it around 10% which is decent listening volume.
Project K4RPU73R
Via Epia-M 9000
256MB PC2100
40GB IBM Travelstar
7" Xenarc
DeLorme Earthmate GPS
06-26-2003, 01:56 AM
#7
Vehicle: Audi 90 -88, VW Polo CAB -81
it's inside winamp.ini, volume= where max is 255 and 0 is...well 0
06-29-2003, 05:21 AM
#8
hmmm is there any way to make a batch file that edits the volume line of winamp.ini so that it sets volume=240?
06-29-2003, 05:24 AM
#9
cfg_buf_ms=2000
cfg_dev=0
cfg_volume=1
cfg_altvol=0
cfg_resetvol=0
cfg_prebuf=0
cfg_trackhack2=0
I seen these in the bottom of winamp.ini... is the resetvol what is happening to me? It doesnt always set the volume all the way down. only sometimes. maybe one of these options would make it so that when it resets it resets to the appropriate volume instead of no volume
06-29-2003, 08:29 AM
#10
make a .bat that copies winamp_backup.ini into winamp.ini and overwrites w/o promt
07-29-2003, 10:11 PM
#11
its been so long since i have done that i will try but could someone post here how to do it incase i fail?
07-29-2003, 10:12 PM
#12
also parts of the file i dont want overided because this file contains my last played song and song position
07-29-2003, 10:19 PM
#13
Vehicle: 05 Acura TL 6sp Navi
You could try enabling/disabling the direct sound ouput. With direct sound disabled, the wav mixer control volume.
| Thread Tools |
Search this Thread |
| Display Modes |
Linear Mode
