The MP3car.com Store
Go Back   MP3Car.com > Mp3Car Technical > Software & Software Development
Thread Tools Display Modes
Old 09-13-2007, 08:05 PM   #256
taylorgauss's CarPC Specs
taylorgauss's Avatar
Vehicle: 2004 BMW 325ci
My Photos: (0)
Hey mine just arrived. I have read through this post but am unable to find the Xerces-c_2_7.dll file. Can someone help me out. Thanks
EDIT Found it deep in the archives. XML Time
taylorgauss is offline   Reply With Quote
Sponsored Links
Old 09-14-2007, 12:47 AM   #257
inh
Vehicle: 91 CRX Si
My Photos: (0)
Quote: Originally Posted by guizai View Post
thanks INH, your work , CherryBomb's and Sama's have been awesome!!!
INH: I did everything you said, I only have the volume up and down working with the buttons. I used the config that you posted earlier. Does it matter what skin is being used? I will have to sit down and read through the whole config file. I'm prolly just doing something simple wrong. Thanks.
I need to clean up the config.xml a bit, i think. Actually.. In my skin files, i have a lil code to send a message to the app to switch contexts. I use digitalfx 2.0 skin in roadrunner, so when im in the media player or most things, i want it to control the media player, but when im on the games screen, i want it to behave like a mouse =]
let me dig up the code..
Space Navigator - 6 Axis input device: Take it apart - Driver App
RRCam - Video/webcam capture, text overlay, and recording: 2.0 Stable
inh is offline   Reply With Quote
Old 09-14-2007, 02:22 AM   #258
My Photos: (0)
inh,
Im using your config file too and have the same controls as guizai. I am not quite sure how to configure that file to my liking. I don't need it to behave as a mouse currently I mostly just want media control. I see where you have the controls in the file. Does positive and negative refer to opposite movements like forward and backward where forward could be up and backward could be down? If i changes the contexts do i need to change the actions as well? Sorry for my lack of knowledge in this area. I hope to learn though! THanks
Old 09-14-2007, 02:23 AM   #259
inh
Vehicle: 91 CRX Si
My Photos: (0)
No problem, give me a few mins, and ill post up a better config for you, as well as the way to have it do differnt things. I also try and explain things a lil better
Old 09-14-2007, 02:26 AM   #260
My Photos: (0)
Great I really really appreciate your help, and look forward to your wisdom!
Sponsored Links
Old 09-14-2007, 02:50 AM   #261
inh
Vehicle: 91 CRX Si
My Photos: (0)
Ok, i guess this will be the start of my SpaceNav driver guide.. Attached are two config.xml files. One is the one I am currently using, which was really just a test to get the app to do different things based on where i was in the roadrunner skin. The second is one that will just act as a medai controller all the time.
Now, In the config i use that supports context switching you will see this code, in which it defines the two contexts i use, media controlling and mouse simulting:
Code:
<deviceContexts> <deviceContext name="Media" device="SpaceNavigator"> <axe threshold="200" type="binary" posAction="" negAction=""/> <!-- axe 0 pan left/right --> <axe threshold="200" type="binary" posAction="" negAction=""/> <!-- axe 1 pan foreward/back --> <axe threshold="500" type="binary" posAction="RR Play/Pause" negAction=""/> <!-- axe 2 push/pull --> <axe threshold="200" type="binary" posAction="" negAction=""/> <!-- axe 3 tilt foreward/back --> <axe threshold="200" type="binary" posAction="RR Prev" negAction="RR Next"/> <!-- axe 4 tilt left/right --> <axe threshold="100" type="exponential" startPulse="1" endPulse="20" posAction="RR Volume Up" negAction="RR Volume Down" /> <!-- axe 5 Twist --> <buttons> <button downAction="RR Mute" upAction="" /> <button downAction="RR FullVisu" upAction="" /> </buttons> </deviceContext> <deviceContext name="Mouse" device="SpaceNavigator"> <axe threshold="200" type="binary" posAction="" negAction=""/> <!-- axe 0 pan left/right --> <axe threshold="200" type="binary" posAction="" negAction=""/> <!-- axe 1 pan foreward/back --> <axe threshold="500" type="binary" posAction="" negAction=""/> <!-- axe 2 push/pull --> <axe simulateMouseMove="y" threshold="50" divisor="30" /> <axe simulateMouseMove="x" threshold="50" divisor="30" /> <axe threshold="200" type="binary" posAction="" negAction=""/> <!-- axe 5 twist --> <buttons> <button simulateMouseButton="left" /> <button simulateMouseButton="right" /> </buttons> </deviceContext> </deviceContexts>
The DeviceContextName is the name of the context, and the device is the interface. You can choose differnt interfaces, but in both configs i only have the space navigator setup, so they will always be the same.
Old 09-14-2007, 02:51 AM   #262
inh
Vehicle: 91 CRX Si
My Photos: (0)
Notice this code, for the media context:
Code:
This defines the actions to be used for each axis of the SN (space navigator.) If you want to just use the fifth axis, which is twisting, then you NEED to have 4 other definitions before it, because that is how the program determines which one is which, since they aren't defined. they just go in order.
posAction and negAction determine what to do when the device is moved that way on each axis. I dont recall which way is which for each control, but generally up is pos, and right is pos.. Just play with the control and you'll figure it out..
Now about the actions. They must be defined in order for the program to know what to do, hence the 'action' section
Code:
<actions> <sendWindowMessage name="Context Up" type="CopyData" window="SpaceNavigatorDriver" message="CONTEXT;Up"/> <sendWindowMessage name="Context Down" type="CopyData" window="SpaceNavigatorDriver" message="CONTEXT;Down"/> <sendWindowMessage name="RR Volume Up" type="CopyData" window="RoadRunner" message="VOL+"/> <sendWindowMessage name="RR Volume Down" type="CopyData" window="RoadRunner" message="VOL-"/> <sendWindowMessage name="RR Mute" type="CopyData" window="RoadRunner" message="MUTE"/> <sendWindowMessage name="RR Play/Pause" type="CopyData" window="RoadRunner" message="PLAY"/> <sendWindowMessage name="RR Next" type="CopyData" window="RoadRunner" message="NEXT"/> <sendWindowMessage name="RR Prev" type="CopyData" window="RoadRunner" message="PREV"/>
Basically, most of them just send a message to RR (roadrunner) the same way you would set a button code.
Context Swtiching:
TO enable the driver to send differnt commands dependig on what skin file is loaded (like the menu, or the audio player, etc) RR needs to send a message to the app. This is done with a few lines of code.
In each skin file you want to support, like menu.skin, games.skin, audioplayer.skin, etc, you need to add this line somewhere in there:
Code:
TMR,1
Then in exectbl.ini you need to add the following code:
Code:
"TIMER","SENDMSG;SpaceNavigatorDriver;CONTEXT;Media",Audio_Player.skin "TIMER","SENDMSG;SpaceNavigatorDriver;CONTEXT;Media",Menu.skin "TIMER","SENDMSG;SpaceNavigatorDriver;CONTEXT;Media",Menu2.skin "TIMER","SENDMSG;SpaceNavigatorDriver;CONTEXT;Mouse",Games.skin
Basically, this says that if Audio_Player.skin is loaded, send a message to the spacenavigatordriver app, which says "CONTEXT;Media" and then the app will look for a context named "Media" and start using it.
When the games skin is loaded, it tells the app to use the mouse context, in which it simulates a mouse =]
I think this covers everything...
myconfig.xml.txt is the one i use, mediaconfig.xml.txt is the one setup to just do media controls. It needs to be renamed config.xml and placed in the same folder as the space nav driver.exe program. Just overwrite the default one.
Old 09-14-2007, 03:02 AM   #263
incudie's CarPC Specs
Vehicle: 2007 / Honda / Civic SI 4 Door
My Photos: (9)
Wow thanks a lot Inh.
I have a much better understanding of how this thing works.
incudie is offline   Reply With Quote
Old 09-14-2007, 03:56 AM   #264
My Photos: (0)
Yeah, thanks a ton. I really appreciate it.
Old 09-14-2007, 03:57 AM   #265
inh
Vehicle: 91 CRX Si
My Photos: (0)
No problem guys. I've been meaning to write a guide since i think im the only person besides the author that understands it
Let me know if you guys get it working =]
Old 09-14-2007, 10:12 AM   #266
My Photos: (9)
Yeah I got your config working right after you posted it (Using it for Volume control and as a mouse under the games section). Only problem I had was clicking. Left/Right buttons on SN did not execute MouseClicks. When I get home tonight I'll try and figure it out then adjust it for my own needs and if it works, post the config for anyone that might be interested. (In my car I'm hoping to use it as the primary input device and have it be a mouse 24/7 but also keep volume control for RR. (Not sure if its possible yet but well see...).
Old 09-14-2007, 11:50 AM   #267
cherrybomb's CarPC Specs
cherrybomb's Avatar
Vehicle: 1999 Ford Explorer
My Photos: (0)
Frankly, I think you understand it better than I do, at least from a practical standpoint.
I'm too lazy/dense to memorize it all, and do intend to (eventually) write a config app. ;-)
Might actually have a spare moment or two to work on the few things you've mentioned this week. Yay me! :-)
'99 Ford Explorer Eddie Bauer
CarPC Progress ~= 97%. Everything is installed, and operational. Still need to tweak and tune, and do some "finish" fabrication.
CarPC Project Web Site
SpaceNavigatorDriver SourceForge Project
Check out my blog.
cherrybomb is offline   Reply With Quote
Old 09-14-2007, 12:07 PM   #268
inh
Vehicle: 91 CRX Si
My Photos: (0)
You should definatly be able to control volume with a twist and the mouse at the same time, just add the axis commands in there. You'll have to set some of them to not to anything (like where i have them set as digital with no action defined) so that you can set axis 5 for volume.
About the buttons not working, no idea.. Might be something with your system..
Cherrybomb, im keepin my fingers crossed =] I finally figured out where I'm going to mount this thing, so I'm even more motivated
Old 09-14-2007, 12:23 PM   #269
cherrybomb's Avatar
My Photos: (0)
Yeah, I suspect once I actually try to use the thing in my vehicle I'll be more motivated as well.
Gotta get a USB hub installed in my center console, then I can start playing with it.
I'm just so happy to have a working setup finally, I'm a bit afraid to mess with it.. lol
Check out my blog.
Old 09-14-2007, 12:26 PM   #270
inh
Vehicle: 91 CRX Si
My Photos: (0)
hehe i know what ya mean! It's going to be a bit before I have a chance to install it, but just finding a place the bland it in where it would be in reach and look good was a challenge (take a look at some CRX interior pics and you'll see what I mean)
When i get a chance, I think I'm going to crack mine open again and see about changing LED colors, just for kicks. Hell.. maybe puts some RGB LEDs in there.. Now THAT would be awesome..
Sponsored Links
vB code is On
Trackbacks are Off
Find a List of Available Skins Here! ThunderStick RR Skins 0 10-17-2007 06:28 PM
Questions! Yellow-Snow Mobile Impact 4 06-10-2006 05:18 PM
iGuidance Font Size Fix summary thread Viscouse GPS 29 03-28-2006 06:21 PM
Hot Chicks Thread - NOT WORK SAFE ODYSSEY Off Topic 1 05-17-2005 09:38 PM
Request regarding the Offical Skin Presentation thread Confused MediaCar 3 01-07-2004 11:52 AM
Sponsored Links
SEO by vBSEO 3.1.0
Ad Management by RedTyger
