The MP3car.com Store
Go Back   MP3Car.com > Mp3Car Technical > Software & Software Development
Thread Tools Display Modes
Old 02-14-2007, 06:45 AM   #1
FreeDrive Creator
CdRsKuLL's CarPC Specs
CdRsKuLL's Avatar
Vehicle: Ferrari 360 (nearly)
My Photos: (5)
Help needed to alter Video Driver Refresh Rate
ok.. I have a commell 677 motherboard and Cartft posted some intel drivers which you can use to get true 800 x 480. The only problem is my xenarc tft doesnt like the refresh rate there running (defaults to 600 x 480) So I had a quick look and I am thinking I might be able to change this here... I have also attached the full file just incase
CdR
Code:
;=============================================================================== [ssigd_SoftwareDeviceSettings_wht] HKR,, InstalledDisplayDrivers, %REG_MULTI_SZ%, igddis HKR,, MultiFunctionSupported, %REG_MULTI_SZ%, 1 HKR,, VgaCompatible, %REG_DWORD%, 0 HKR,, PcfVersion, %REG_DWORD%, 0x0400 HKR,, No_D3D, %REG_DWORD%, 1 HKR,, PortDrivers, %REG_SZ%, "ch7009 ch7017 fs454 lvds ns2501 ns387 sii164 th164" HKR,, PcfVersion, %REG_DWORD%, 0x0400 HKR, pd , sii164, %REG_DWORD%, 0 HKR, pd , ch7009, %REG_DWORD%, 0 HKR, pd , tl955, %REG_DWORD%, 0 HKR, pd , ns2501, %REG_DWORD%, 0 HKR, pd , th164, %REG_DWORD%, 0 HKR, pd , fs454, %REG_DWORD%, 0 HKR, pd , ns387, %REG_DWORD%, 0 HKR, pd , lvds, %REG_DWORD%, 0 HKR, pd , ch7017, %REG_DWORD%, 0 HKR, Config\1 , Comment, %REG_SZ%, "CTF400/700/800" HKR, Config\1 , name, %REG_SZ%, "CarTFT.com (www.CarTFT.com)" HKR, Config\1\General , DisplayConfig, %REG_DWORD%, 8 HKR, Config\1\General , PortOrder, %REG_SZ%, "5,2" HKR, Config\1\vbios , common_to_port, %REG_DWORD%, 503000 HKR, Config\1\vbios , PostDisplayMsg, %REG_DWORD%, 5 HKR, Config\1\vbios , oem_string, %REG_SZ%, "CarTFT.com (www.CarTFT.com)" HKR, Config\1\vbios , oem_vendor_name, %REG_SZ%, "CarTFT.com" HKR, Config\1\vbios , oem_product_name, %REG_SZ%, "CTF400/700/800" HKR, Config\1\vbios , oem_product_rev, %REG_SZ%, "Standard" HKR, Config\1\vbios , default_refresh_0, %REG_DWORD%, 60 HKR, Config\1\vbios , default_refresh_1, %REG_DWORD%, 60 HKR, Config\1\vbios , default_mode_0, %REG_DWORD%, 276 HKR, Config\1\vbios , default_mode_1, %REG_DWORD%, 276 HKR, Config\1\vbios , default_vga_height, %REG_DWORD%, 600 HKR, Config\1\Port\3 , name, %REG_SZ%, "DVI" HKR, Config\1\Port\3\General , Rotation, %REG_DWORD%, 0 HKR, Config\1\Port\3\General , Edid, %REG_DWORD%, 1 HKR, Config\1\Port\3\General , EdidAvail, %REG_DWORD%, 5 HKR, Config\1\Port\3\General , EdidNotAvail, %REG_DWORD%, 5 HKR, Config\1\Port\3\General , MultiDvo, %REG_DWORD%, 1 HKR, Config\1\Port\3\Dtd\1 , PixelClock, %REG_DWORD%, 33600 HKR, Config\1\Port\3\Dtd\1 , HorzActive, %REG_DWORD%, 800 HKR, Config\1\Port\3\Dtd\1 , HorzSync, %REG_DWORD%, 37 HKR, Config\1\Port\3\Dtd\1 , HorzSyncPulse, %REG_DWORD%, 8 HKR, Config\1\Port\3\Dtd\1 , HorzBlank, %REG_DWORD%, 88 HKR, Config\1\Port\3\Dtd\1 , VertActive, %REG_DWORD%, 480 HKR, Config\1\Port\3\Dtd\1 , VertSync, %REG_DWORD%, 15 HKR, Config\1\Port\3\Dtd\1 , VertSyncPulse, %REG_DWORD%, 3 HKR, Config\1\Port\3\Dtd\1 , VertBlank, %REG_DWORD%, 34 HKR, Config\1\Port\3\Dtd\1 , Flags, %REG_DWORD%, 0 HKR, Config\1\Port\5 , name, %REG_SZ%, "VGA D-SUB15" HKR, Config\1\Port\5\General , Rotation, %REG_DWORD%, 0 HKR, Config\1\Port\5\General , Edid, %REG_DWORD%, 1 HKR, Config\1\Port\5\General , EdidAvail, %REG_DWORD%, 5 HKR, Config\1\Port\5\General , EdidNotAvail, %REG_DWORD%, 5 HKR, Config\1\Port\5\General , MultiDvo, %REG_DWORD%, 1 HKR, Config\1\Port\5\Dtd\1 , PixelClock, %REG_DWORD%, 33600 HKR, Config\1\Port\5\Dtd\1 , HorzActive, %REG_DWORD%, 800 HKR, Config\1\Port\5\Dtd\1 , HorzSync, %REG_DWORD%, 37 HKR, Config\1\Port\5\Dtd\1 , HorzSyncPulse, %REG_DWORD%, 8 HKR, Config\1\Port\5\Dtd\1 , HorzBlank, %REG_DWORD%, 88 HKR, Config\1\Port\5\Dtd\1 , VertActive, %REG_DWORD%, 480 HKR, Config\1\Port\5\Dtd\1 , VertSync, %REG_DWORD%, 15 HKR, Config\1\Port\5\Dtd\1 , VertSyncPulse, %REG_DWORD%, 3 HKR, Config\1\Port\5\Dtd\1 , VertBlank, %REG_DWORD%, 34 HKR, Config\1\Port\5\Dtd\1 , Flags, %REG_DWORD%, 0 ;===============================================================================
cheers
CdR
http://www.extremeoc.co.uk/
Building a new car soon - check it out !
www.BluePC.co.uk Bolton PC Repair - New Business venture.. I need to earn some money :-)
CdRsKuLL is offline   Reply With Quote
Sponsored Links
Old 02-14-2007, 06:49 AM   #2
FreeDrive Creator
CdRsKuLL's Avatar
My Photos: (5)
just been looking through it. . and I was looking for something that said 72 as thats the refresh rate, but would these make any difference ?
they say 60 ?
never played with drivers before so any help please
Old 02-14-2007, 08:51 AM   #3
Confusion Master
Enforcer's CarPC Specs
Enforcer's Avatar
Vehicle: 1997 BMW E36 328I
My Photos: (1)
try playing with powerstrip.
Enforcer is offline   Reply With Quote
Old 04-16-2007, 09:29 AM   #4
My Photos: (14)
The actual lines that control the timing parameters are these:
Code:
HKR, Config\1\Port\5\Dtd\1 , PixelClock, %REG_DWORD%, 38550 HKR, Config\1\Port\5\Dtd\1 , HorzActive, %REG_DWORD%, 800 HKR, Config\1\Port\5\Dtd\1 , HorzSync, %REG_DWORD%, 40 HKR, Config\1\Port\5\Dtd\1 , HorzSyncPulse, %REG_DWORD%, 80 HKR, Config\1\Port\5\Dtd\1 , HorzBlank, %REG_DWORD%, 232 HKR, Config\1\Port\5\Dtd\1 , VertActive, %REG_DWORD%, 480 HKR, Config\1\Port\5\Dtd\1 , VertSync, %REG_DWORD%, 61 HKR, Config\1\Port\5\Dtd\1 , VertSyncPulse, %REG_DWORD%, 3 HKR, Config\1\Port\5\Dtd\1 , VertBlank, %REG_DWORD%, 142 HKR, Config\1\Port\5\Dtd\1 , Flags, %REG_DWORD%, 0
You can adjust the values in the INF file to the above numbers, which should do the trick.
Or, just download this driver package instead, which I built yesterday for 800x480 on Intel 945GM based onboard graphics:
http://moschini.org/945GM-800x480.zip
I've been able to confirm that the driver package works, and they were using a 7" Xenarc too.
The driver package I posted should work perfectly.
Giuliano is offline   Reply With Quote
Old 07-16-2007, 09:31 AM   #5
My Photos: (0)
Apologies for bringing a three month old thread back to life, but if I am unable to change refresh rates using Windows, is my last recourse changing registry information such as this? I have a VIA M10000 motherboard with an integrated graphics processor (VIA/S3G UniChrome), and it only seems to allow a refresh rate of 60Hz, whereas I need to change mine to 75Hz to solve a different issue.
Rabid Lemming is offline   Reply With Quote
Old 07-16-2007, 09:40 AM   #6
binary.h4x's Avatar
Vehicle: 2007 Honda Fit Sport
My Photos: (0)
Do you have the most recent set of video drivers?
binary.h4x is offline   Reply With Quote
Old 07-16-2007, 09:44 AM   #7
My Photos: (0)
I have yet to get the proper drivers. I attempted to install new drivers this morning before work, but it was not compatible with my chipset. I will have to actually find the drivers while I am in the car, so that I can use some online detection utilities. I am also going to try using powerstrip, but must do some research first.
Old 07-16-2007, 09:53 AM   #8
binary.h4x's Avatar
My Photos: (0)
Have you tried these by chance?:
http://www.via.com.tw/en/products/ma...herboard_id=81
Old 07-16-2007, 10:23 AM   #9
My Photos: (0)
I will attempt this later. It seems that I have to flash my BIOS for this to work? I have such a loathing for BIOS flashes because for some reason, unless the flash utility is embedded in the BIOS, usually a floppy is required, and I do not have that in my car
Old 01-27-2008, 10:30 PM   #10
kelmk's Avatar
Vehicle: 2002 BMW 330ci vert
My Photos: (100)
Can you post these drivers again?
kelmk is offline   Reply With Quote
Sponsored Links
vB code is On
Trackbacks are Off
epia M mobo, video driver problems illycut General Hardware Discussion 10 04-04-2005 02:17 PM
M10000 & PCI Video Card Driver msumr282 LCD/Display 6 12-27-2004 06:16 PM
what resolution is needed for good video play back? kickercivic1 LCD/Display 6 09-06-2004 10:47 PM
epia M mobo, video driver problems illycut LCD/Display 5 07-28-2004 10:52 AM
web tv video driver Schnitz General Hardware Discussion 1 03-05-2001 08:09 AM
Sponsored Links
SEO by vBSEO 3.1.0
Ad Management by RedTyger
