Quote: Originally Posted by
ClanLee
I'm trying it out and it's the best intuitive front end I've used. Everything looks good. Great work!
Requests:
1. Want to change the Time Format to AM/PM.
2. Want to change the Date Format to MM/DD/YYYY (for those of us across the pond).
3. Phone support through bluetooth.
4. Anyway to disable the startup sound when launching mediateICE?
Otherwise, I will keep watching this thread for updates.
Thanks!
Okay, most of these we can sort...
1. Open the base-LanguageDescriptor.xml file in C:\Program Files\@home media\themes\ice.
Look for the string "system.timeformat" as shown below:
<Text name="system.timeformat">h:nn</Text>
Change this to read
<Text name="system.timeformat">h:nn am/pm</Text>
Save the file and restart mediate.
2. Open the same file and change "system.dateformat" from:
<Text name="system.dateformat">d/m/yy</Text>
to
<Text name="system.dateformat">mm/dd/yyyy</Text>
3. Bluetooth support is planned, but will be after the theme designer and radio support gets added.
4. Simplest way (other than switching off all sound effects in the settings menu) is to delete the file "startup.wav" in C:\Program Files\@home media\themes\ice\resources
You can also replace that file with another with the same name if you wish - WAV format only.
The theme designer is about 60% complete now and looking pretty good. Once its done changes such as these can be made really easily without having to edit the XML. The new theme is also coming along as we develop the two in tandem to prove the theme designer works. Stick with us, this will be here in a few more weeks time.
Cheers,
@home media
