Go Back   MP3Car.com > Mp3Car Technical > Software & Software Development
Old 04-24-2007, 10:01 AM   #46
Maņana's Avatar
Maņana is on a distinguished road
Quote: Originally Posted by athomemedia View Post
Do you mean the window position? Sounds doable, but would help if we understood why you wanted it to do that? A simple implementation would be to remember the last window position then you can drag it where you want. Are you running some kind of multiple screen setup?
Well, close to. I suppose you know about the problem with getting the integrated graphics on epia mobos to output 800x480 to 7" widescreen displays?
I found a workaround. If I make my mobo output 800x600, I can then (with some bios settings) make the screen think its 800x400 in a way that it cuts the top eight and botton 112 pixels so that it displays 800x480. That gives a clear image with mapped pixels, and it works very well as long as I'm possible to force the frontend to just use those 800x480 pixels.
My carputer
Old one
Maņana is offline   Reply With Quote
Old 04-26-2007, 12:55 PM   #47
akberpaf is on a distinguished road
Very nice front end
Hi, I am newbie and was looking for a frontend for my car. I am using UMPC Samsung Q1 with pentium processor. I bought it so it can be mounted in my Fj. I am hoping you will finalize this frontend with Iguidance 3.0 as soon as possible.
Thanks again for the effort.
Will this work with Xp tablet?
thanks.
akberpaf is offline   Reply With Quote
Old 04-26-2007, 02:29 PM   #48
HitmanZ is on a distinguished road
Currently using Roadrunner...but checked mediate ice... this is a bad *** front end.... I LOVE it...but would love it more if it pointed to a gps location
HitmanZ is offline   Reply With Quote
Old 04-26-2007, 06:01 PM   #49
bug
I installed it on my umpc and for the most part it work ok. the only problem is that i am unable to change the color from the setup menu. it just doesnt select any color. i installed and reinstalled several time without any change. Please help.
thanks
Old 04-26-2007, 07:45 PM   #50
thanks
Sorry wrong place .....
Old 04-28-2007, 11:47 PM   #51
Thumbs up Gps integration request
Hi
Are you planning to put a button for gps integration, especially Iguidance 3.0? Please please put that in there and may be some option to change the color of the text like the Ultimate RR skin has on it.
That would make it perfect for me...
Thanks alot for the effort this is the fastes front end i have seen ....
thanks again.
Old 04-29-2007, 03:53 AM   #52
Maņana's Avatar
BUG
Well, I just ran into something... I tried installing mediate on my carputer, but when I run it it says:
"Critical DirectX error encountered.
Failed to find suitable alpha blended texture format."
I do have DX9 installed...
Logfile:
Code:
09:37:13:095 INFO: mediate Preference settings are as follows: 09:37:13:095 INFO: <?xml version="1.0" encoding="iso-8859-1" ?> 09:37:13:095 INFO: <ClientPreferences> 09:37:13:095 INFO: <ThemeName></ThemeName> 09:37:13:095 INFO: <DVDVideoFilter></DVDVideoFilter> 09:37:13:095 INFO: <DVDAudioFilter></DVDAudioFilter> 09:37:13:095 INFO: <AudioDeviceName></AudioDeviceName> 09:37:13:095 INFO: <DisplayFrequency>0</DisplayFrequency> 09:37:13:095 INFO: <DisplayAdapter>0</DisplayAdapter> 09:37:13:095 INFO: <ScreenWidth>800</ScreenWidth> 09:37:13:095 INFO: <ScreenHeight>480</ScreenHeight> 09:37:13:095 INFO: <ScreenRefreshRate>0</ScreenRefreshRate> 09:37:13:095 INFO: <TextureFormat>0</TextureFormat> 09:37:13:095 INFO: <VideoRenderer>0</VideoRenderer> 09:37:13:095 INFO: <VideoFrameThrottle>1</VideoFrameThrottle> 09:37:13:095 INFO: <FullScreen>no</FullScreen> 09:37:13:095 INFO: <WideScreen>no</WideScreen> 09:37:13:095 INFO: <HideWindowBorder>yes</HideWindowBorder> 09:37:13:095 INFO: <MaximizeWindow>no</MaximizeWindow> 09:37:13:095 INFO: <TimeFormat>h:nn am/pm</TimeFormat> 09:37:13:095 INFO: <DateFormat>dddd dx mmmm</DateFormat> 09:37:13:105 INFO: <LoggingLevel>INFO</LoggingLevel> 09:37:13:105 INFO: <LoggingFileCache>yes</LoggingFileCache> 09:37:13:105 INFO: <ShowDiagnostics>no</ShowDiagnostics> 09:37:13:105 INFO: <SaveGraphToFile>no</SaveGraphToFile> 09:37:13:105 INFO: <KeyBindingProfile>default</KeyBindingProfile> 09:37:13:105 INFO: <ShowMouseCursor>2</ShowMouseCursor> 09:37:13:105 INFO: <MouseRightButton>0</MouseRightButton> 09:37:13:105 INFO: <ScreenSaverFile></ScreenSaverFile> 09:37:13:105 INFO: <ScreenSaverDelay>600</ScreenSaverDelay> 09:37:13:105 INFO: <SlideshowDelay>5</SlideshowDelay> 09:37:13:105 INFO: <SlideshowPanZoom>yes</SlideshowPanZoom> 09:37:13:105 INFO: <SlideshowFading>yes</SlideshowFading> 09:37:13:105 INFO: <SlideshowBorders>yes</SlideshowBorders> 09:37:13:105 INFO: <SoundEffects>yes</SoundEffects> 09:37:13:105 INFO: <VideoExtensions>.AVI,.MPEG,.MPG,.WMV</VideoExtensions> 09:37:13:105 INFO: <AudioExtensions>.CDA,.MID,.MIDI,.MP3,.WAV,.WMA</AudioExtensions> 09:37:13:105 INFO: <PlaylistExtensions>".ASX",".M3U",".PLS"</PlaylistExtensions> 09:37:13:105 INFO: <ProxyHost></ProxyHost> 09:37:13:105 INFO: <ProxyPort>80</ProxyPort> 09:37:13:105 INFO: <ProxyUserName></ProxyUserName> 09:37:13:105 INFO: <ProxyPassword></ProxyPassword> 09:37:13:105 INFO: <CheckUpdates>yes</CheckUpdates> 09:37:13:105 INFO: <GroupDirectories>no</GroupDirectories> 09:37:13:105 INFO: <ThemeSettings> 09:37:13:105 INFO: </ThemeSettings> 09:37:13:105 INFO: </ClientPreferences> 09:37:15:349 WARN: Failed to load image: C:\Program\@home media\themes\ice\Resources\
My carputer
Old one
Old 04-29-2007, 08:54 AM   #53
Any news on GPS integration ? thanks...
Old 04-29-2007, 05:16 PM   #54
athomemedia is on a distinguished road
We've only seen that happen in two circumstances - either DX9 and or Gfx drivers aren't installed, or if the Gfx card doesn't have support for 32bit textures.
One of our test machines has pretty old Intel embedded gfx (circa 6yrs old) and that doesn't have support for 32 bit textures, only 16 bit. There is an option in the mediate advanced settings to use 16 bit textures - try turning that on and also enabling fullscreen exclusive mode.
We added 16 bit mode for compatibilty with older h/w - the gfx won't look quite so nice (you may see some colour banding) since there are far fewer colours available, but you should see something.
If that doesn't help, and you do have DirectX 9 installed isn't installed then there's an included utility dxdiag.exe (Start menu / Run / dxdiag). Run that and go through the Direct 3D tests on the Display tab to verify you have a suitable gfx driver installed (one which supports DirectX 9 acceleration).
Beta release now available: mediate ICE - http://www.mediateice.com
@home media limited
http://www.athomemedia.co.uk
athomemedia is offline   Reply With Quote
Old 04-29-2007, 09:10 PM   #55
Hi guys,
Is there any news on the gps stuff for this screen?? can someone please let me know....
Thanks....
Old 04-30-2007, 10:53 AM   #56
Maņana's Avatar
My bad. Forgot to install Vias 4in1 drivers when i formated. (they contain agp drivers, and therefore I had not proper DX3D support)
My carputer
Old one
Old 04-30-2007, 08:20 PM   #57
jazz13's Avatar
jazz13 is on a distinguished road
Video issues
Well I just came across a blocker. I 'was' going to use mediate in my car till my own front-end is up and running, but if it can't play my videos.... well....
Anywayz, when i go to play a video it comes up with a big red error saying that it can't play the video cause it's in an unsupported video/audio codec. Thing is the video plays fine in Windows Mediaplayer. The video is a DivX video so i would think that it should be able to play it.
jazz13 is offline   Reply With Quote
Old 04-30-2007, 10:08 PM   #58
taKuto's Avatar
taKuto is an unknown quantity at this point
it'd be nice to have the volume control connected to the master volume for the computer, or if you could just have it remember the previous volume level from last execution could work well too.
taKuto is offline   Reply With Quote
Old 05-07-2007, 06:39 AM   #59
Hi,
At present video playback is a little hardware dependent due to the way we're using the Video Mixing Renderer (VMR9) to blend video with the rest of the user interface. We're planning on implementing our own custom video renderer that should sort these issues, but in the meantime you could try setting the video renderer (see playback options in the advanced configuration settings) to VMR7 instead.
VMR7 works on a far wider range of h/w but is more limited - you won't get the video mixed with the user interface, or see the small preview window, or get toolbar buttons overlaid in the fullscreen view.
Also, for those of you that have asked, Navigation support is getting there but we're having a few fun technical issues to get round with embedding external applications.
So far we have PC Navigator running within mediate, scaled to fit nicely with a dark fade effect so it matches the feel of the rest of the ui. The sticking point is PC Navigator crashing each time we send it a mouse event in the routing screen :-(
We'll get there though. Thanks for waiting everyone...
@home media limited
Old 05-10-2007, 04:34 PM   #60
Sea Shadow is on a distinguished road
I just barely stumbled across this and have been playing with it for a little while now. I really like it so far, but I wish that when listening to music it would use the ID3 tag information to display song title (and artist/album information if possible). Some of us have different naming conventions for our audio files but the tagging is generally the same throughout.
Sea Shadow is offline   Reply With Quote
Why should I run a front end??? Slightly_Stoopi General MP3Car Discussion 13 06-28-2006 03:32 PM
This is an awesome front end, and here is why: WhiteRabbit NeoCar Media Center 47 08-27-2005 10:43 PM
Web Based Front End Zenith_Warrior Software & Software Development 10 07-02-2005 07:03 PM
Looking for Front End Wiredwrx Software & Software Development 7 05-25-2005 05:00 PM
Front end needed for semi commercial venture Orange Bus Software & Software Development 10 04-28-2005 02:59 AM
